Forum rules
 Post subject: Modify CHS on a Seagate 7200.12
PostPosted: January 6th, 2018, 21:23
Hey All,
I'm working to recover some data on a drive that I think has been infected. When mounting the drive in linux, it appears the geometry has been modified to 'lock' me out of some of the partitions on the drive. Currently the CHS is set to 1013 44 62, but should be 30401 255 63 by default.
I have access to the serial line and normal linux tools, but have not yet found a way to change the Geometry sizes. The serial terminal correctly shows 1d1c5970 LBA's (== 250gb).
Any ideas?
 Post subject: Re: Modify CHS on a Seagate 7200.12
PostPosted: January 6th, 2018, 21:39
Is there an HPA defined ? Mhdd or hdat2 could clear that.
PostPosted: January 6th, 2018, 22:02
heres the output:
root@testsys:/# hdparm -N /dev/sdb
/dev/sdb:
SG_IO: bad/missing sense data, sb[]: 70 00 05 00 00 00 00 0a 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
max sectors = 2764800/1(65538?), HPA setting seems invalid (buggy kernel device driver?)
root@testsys:/# hdparm --dco-identify /dev/sdb
/dev/sdb:
DCO Checksum FAILED!
DCO Revision: 0x0001
The following features can be selectively disabled via DCO:
Transfer modes:
udma0 udma1 udma2 udma3 udma4 udma5 udma6(?)
Real max sectors: 4980813
ATA command/feature sets:
SMART self_test security
SATA command/feature sets:
(?): NZ_buffer_offsets interface_power_management
root@testsys:/#
PostPosted: January 6th, 2018, 22:05
Here's what im seeing...but i cant access the rest of my partitions for some reason.
Disk /dev/sdb: 1.3 GiB, 1415577600 bytes, 2764800 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Device Boot Start End Sectors Size Id Type
/dev/sdb1 2 2740224 2740223 1.3G c W95 FAT32 (LBA)
/dev/sdb2 4096000 38911999 34816000 16.6G c W95 FAT32 (LBA)
/dev/sdb3 40960000 79871999 38912000 18.6G c W95 FAT32 (LBA)
/dev/sdb4 81920000 485375999 403456000 192.4G c W95 FAT32 (LBA)
root@testsys:/# testdisk /dev/sdb
Disk /dev/sdb - 1415 MB / 1350 MiB - CHS 1013 44 62, sector size=512
PostPosted: January 6th, 2018, 22:17
Try R-Studio for Linux demo.
Are you sure the drive is not actually failing? Checked SMART?
PostPosted: January 6th, 2018, 22:20
yeah the drive is active, available with all smart commands working...smart is where I confirmed LBA as 1d1c5970.
if you have some smart commands i could try, im all ears....
PostPosted: January 6th, 2018, 22:30
I meant SMART attributes possibly indicating the drive is degraded/failed. In Linux, can use Smartmon tools or R-Studio Demo has a SMART feature
PostPosted: January 6th, 2018, 23:33
For any modern LBA drive, the CHS is (roughly) calculated by the OS, or the program that being used. You can't change it. So that would indicate that there is a limited LBA access problem, perhaps related to HPA, but most likely the drive has other issues.
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
PostPosted: January 6th, 2018, 23:57
so what in the firmware/else tells the OS how big the LBA is?
PostPosted: January 7th, 2018, 0:35
The OS gets its information strait from the identify device command results from the drive itself.
PostPosted: January 7th, 2018, 10:24
This is a 7200.12 drive, did you use any "m" command on it by terminal ? DO NOT DO THIS. If by any chance you did use some sort of commands to regenerate translator / format drive / clear defect lists by terminal (or ATA) you might be "locked" out from some LBA point till the end of the LBA range by partial access problem.
Just get MHDD and scan the drive. Can you scan the totality of the LBA space from start to end ? Do you get errors from one point up untill the end ?
What about S.M.A.R.T. ? Can yu post a S.M.A.R.T. screen capture / photo of MHDD "smart att" command ?
PostPosted: January 7th, 2018, 11:36
Since the OP is currently using Linux, here are a few commands to get some information.
The following command will get the basic information, we are looking for the LBAsects= number, which is the reported user addressable sectors:
hdparm -i /dev/sdb
This will show if there is a Host Protected Area to rule that out:
hdparm -N /dev/sdb
This will supply the SMART information, the important data is the attribute table, and most important are the raw values of Reallocated_Sector_Ct and Current_Pending_Sector:
smartctl --all /dev/sdb
PostPosted: January 7th, 2018, 11:55
Let's not forget that if the drive have a partial access problem then it will report the full LBA size but when accessing LBAs starting at one point up untill the end of the LBA space the drive will ABORT the read commands or will error and no data will be retrieved.
PostPosted: January 7th, 2018, 12:06
Yes, but from what was posted above it seems to be identifying with a limited capacity:
PostPosted: January 7th, 2018, 12:19
Ok, Sound reasonable.
At any rate MHDD should be able to confirm the totality of available LBA space and if that space can be scanned after all.
PostPosted: January 7th, 2018, 12:32
I completely missed the fact that he did the HPA command already (and even DCO), and it gave funky data. The SMART data still needs to be seen though to see if the drive is going bad.
PostPosted: January 7th, 2018, 12:38
According to the DCO results, the drive is reporting a max size of about 2.5GB
PostPosted: January 7th, 2018, 13:02
Since there has already been terminal access, I think the next two questions should be:
What terminal commands have been performed on the drive?
How important is the data? Is it worth paying for professional recovery?
PostPosted: January 7th, 2018, 13:17
If the drive have head(s) / pre-amp damage and if the drive is not properly accessing the firmware then maybe it's getting the capacity out from the PCB code instead, reporting incorrect size. This is very typical on F3 drive arch with bad heads or that can't load firmware.
