 Post subject: Post subject: Western Digital TTL Port
PostPosted: January 11th, 2018, 21:26
Hi!
Western Digital have ttl port? and how configurate RX,TX and Ground? 1292 IDE
a TTL adaptor to WD drives in order to use x-modem to write back the ROM to the PCB in case of damaged ROM.
For each pcb you short special points and with TTL connected and software running you upload ROM back to PCB???
short special points and with connected and PCB.??1292 IDE
1335
Hello everyone, sorry for my english, because am using google translator.
 Post subject: Re: Post subject: Western Digital TTL Port
PostPosted: January 12th, 2018, 15:41
Online
Can you post a picture of the PCB ?
Is it MARVELL based ?
What "software" are you using ? U-Command ? MRT PRO ?
You are correct, you can use TTL to programm ROM but U-Command "instructions" don't talk about PCB 12xx, only 13xx that you need to short E41 with E112.
Of course that if your PCB is not MARVELL then this will not work, Also shorting points most likely will NOT BE THE SAME as for 13xx
Does the drive have EXTERNAL ROM CHIP ?
PostPosted: January 12th, 2018, 19:27
Spildit, Can you post a picture of the PCB ? Yeah
What "software" are you using ? U-Command ? MRT PRO ?Yeah U-Command
1292
https://imgur.com/pejdHrO
https://imgur.com/yoiEUpE
1335
https://imgur.com/JNJaWhy
https://imgur.com/jm15jeH
https://imgur.com/lqpHHqx
https://imgur.com/HY4JxvF
1444
https://imgur.com/ISOyOVf
https://imgur.com/aDvxFNt
Thank you for replying
PostPosted: January 13th, 2018, 8:15
Online
Here :
http://www.hddoracle.com/viewtopic.php?f=22&t=217
13xx - Short E41 with E112
1444 and 1552 ground like P14 P15 E41 E112 access
:shock: :shock: :shock: :shock: (badly translated) lolol
And 1292 i don't have a clue.
Also check here - http://www.hddoracle.com/download/file. ... &mode=view
PostPosted: January 13th, 2018, 8:20
Online
At least some of your PCBs have EXTERNAL ROM CHIP at U12 !!!!
Why don't you use something like this ?
http://www.hddoracle.com/viewtopic.php?f=110&t=1738
:D :D :D
I don't know if U-Command will work on PCBs with external ROM. I did never try that.
Also make sure you have full version (not demo).
Good luck.
PostPosted: January 13th, 2018, 14:07
PostPosted: January 13th, 2018, 14:16
Online
No problem.
Please do let us know if it did work out for you !
Users browsing this forum: Majestic-12 [Bot] and 60 guests
