 Post subject: ratio between vcc and vccq
PostPosted: January 23rd, 2018, 10:07
Hello Vnr users, how are you all ?
I have a case is a pendrive and the memorie is very damage after all night trying to correct one dump only correct half with 74% of error. Now the voltages in the reader are settings in vcc 2.3 V and Vccq 3.3 V. And now i am thinking to low the voltage to 1.8v of vcc but is necessary low the Vccq to and in a specific ratio between the 2 voltages.
Thanks very much
My best regards
 Post subject: Re: ratio between vcc and vccq
PostPosted: January 23rd, 2018, 11:35
depends on the chip. I wouldn't go lower thank 2.2 for vcc... never seen good results lower. Maybe read retry needs to be tinkered with, or vcc applied to other pins. have you tried lowering vccq and raising slightly vcc
You should add the chip part number and ID.
Are the pins nice and clean?
cheers
PostPosted: January 26th, 2018, 11:10
HaQue thanks very much to answer my question!!!!!
is possible improve the reading lowering the vccq and raise up vcc ? i belive the reading impreve when the voltage of the core are lower
Thanks very much
my best regards
PostPosted: January 26th, 2018, 12:12
Yes you can try that too. just don't raise VCC too much.
You should add the chip part number and ID to this post.
PostPosted: January 26th, 2018, 12:52
the id is 983A98A376
and the part number is fd32b08uch1-49
thanks very much HaQue
my best regards
Users browsing this forum: No registered users and 0 guests
