 Post subject: 2Tb WD HDD
PostPosted: February 10th, 2018, 13:29
Technology mode key : ..........................: OK
RAM:
Read HDD Info : ................................: OK
Heads number : .................................: 4
Head map : .....................................: 33
SA Cyl Count : .................................: 256
Serials Mark : .................................: 0xFE16
Control version : ..............................: A5C0
Zone allocation table : ........................: Err
ROM:
Read Rom Infos : ...............................: OK
ROM Data Size : ................................: 512 Kb
ROM version : ..................................: 01.55C
ROM generation : ...............................: 01.55C
Link table version : ...........................: 02.55
ROM Firmware version : .........................: 00010055
ROM Modules:
Flash ROM dir reading : ........................: OK
Switched off heads : ...........................: Yes
Heads number in use : ..........................: 4
heads map : ....................................: 0,1,4,5
SA Module Dir Loading...
Load SA Module dir : ...........................: Error, suggest to load from the file
Configuration reading : ........................: Err
I need Data , please suggest next steps for recover data
 Post subject: Re: 2Tb WD HDD
PostPosted: February 10th, 2018, 15:01
Send the drive to a proper data recovery firm ? Start by learning the basic stuff first with test drives and only then move to client drives ?
Block SA access by shorting points, try to see if in Kernel you can re-initialize DIR and read native FW. If so when you get the modules load 11 to RAM. Check damaged modules and start from there.
This assuming the drive is spinning, calibrating and keeps on spinning. If the drive clicks and / or spins down you might have other issues like damaged heads.
PostPosted: February 11th, 2018, 2:39
The Drive is keep Spinning
PostPosted: February 11th, 2018, 6:43
Block SA access (easy way by shorting points) and then try to re-initialize dir (if you can read it from the drive). If DIR is damaged try to load it to RAM from file. Can you access modules now ?
PostPosted: February 13th, 2018, 20:04
I don't have MRT but the procedure with WDMarvel would be something like this :
http://www.hddoracle.com/viewtopic.php?f=193&t=2339
I will write one for SeDiv as well but it's almost the same ...
PostPosted: February 14th, 2018, 10:03
And here :
http://www.hddoracle.com/viewtopic.php?f=182&t=2340
I've written the same sort of guide for SeDiv as well.
Users browsing this forum: saltwater and 0 guests
