 Post subject: Baracuda 7200.12 not detected in bios
PostPosted: March 5th, 2018, 1:02
Hello, I was hoping that maybe someone might could help me diagnose and possibly fix a problem I have with my Hard Drive.
I have a Seagate Barracuda 1TB ST31000528AS 9SL154-023 7200.12. So everything was fine last night, no problems. I wake up in the morning, turn on my pc, and basically bios was not detecting any hard drive. It just doesn't show up no matter what I do. Tried it in another pc, same problem. I hear nothing wrong with the hard drive at all, so I'm wondering if it may be a firmware issue like the 7200.11.
Any help would be appreciated. I would like to get some family photos and some of my digital artwork off of there. Any yes, I'm keeping back ups of my important files since this happened. I learned from my mistake. :D
 Post subject: Re: Baracuda 7200.12 not detected in bios
PostPosted: March 5th, 2018, 3:31
Hi
Since this is 7200.12, it doesn't suffer from the 7200.11 bug (but it has plenty of other ones). Do NOT attempt the 7200.11 fix you'll find on the internet, it can brick your drive.
Since drive does not produce clicking noise, most probably there is something wrong with the firmware. At this point it shouldn't be expensive if you consult a decent pro.
Alternatively, you can connect a TTL and post here terminal report. But DO NOT issue any commands.
If you value your data consult a pro.
WD Trusted Partners
PostPosted: March 18th, 2018, 15:55
You must check NRG list via T>V40 . if there is no entry you can try bsy-fix
PostPosted: March 18th, 2018, 15:57
Better not ....
PostPosted: March 18th, 2018, 16:13
northwind wrote:
Hi
this is a good piece of advise...
Data Recovery Pakistan
Users browsing this forum: Majestic-12 [Bot] and 38 guests
