 Post subject: SLOW RESPONSE basic question (....not so basic)
PostPosted: April 5th, 2018, 9:53
Question is about serious SLOW RESPONSE problem on WD.
Some time disk is totally locked and use function "SLOW RESPONSE PROBLEM" in MRT seem very difficult because disk dont respond and still busy.
I'm starting to work (also) with MRT after years of PC3000 using and in PC3000 this basic problem can solve in 10 seconds:
>Isolate contact heads from PCB > Identify disk > lock SA access > upload DIR and LDR in RAM> so can use SOLVE SLOW RESPONSE.
I'm pretty sure MRT have a similar procedure but I can't find any documentation about.
Someone can explain me procedure or link some document about it?
 Post subject: Re: SLOW RESPONSE basic question (....not so basic)
PostPosted: April 5th, 2018, 13:44
Instead of insulating PCB try shorting points on PCB is way more practic and easy.
http://www.hddoracle.com/viewtopic.php?f=86&t=2278
Now if you have something like WDMarvel :
http://www.hddoracle.com/viewtopic.php?f=193&t=2339
I would bet that you could do the same or something similar with MRT ...
PostPosted: April 7th, 2018, 14:08
Thanks Spildit, useful informations.
Someone know the procedure for MRT?
PostPosted: April 7th, 2018, 15:02
Read module 02 and patch it by hand if you can't find any option on the software to do the fix ?
I would bet that there should be an option somewhere to apply the fix without having to edit module 02 by hand ...
:shock: :shock: :shock:
PostPosted: April 7th, 2018, 15:06
I'm sure too ....but where? :?:
PostPosted: April 7th, 2018, 15:07
I don't know, i don't have MRT.
Post module 02 of your drive, i will patch it.
PostPosted: April 7th, 2018, 15:08
Or PM me teamviewer ID/Password of your MRT system and i will check.
This might be better.
PostPosted: April 8th, 2018, 3:45
Thanks but I no have this problem on a specific drive.
I solve this problem daily with my PC3000, just want know if have a similar procedure in MRT.
PostPosted: April 8th, 2018, 9:15
Yes, you can do that in MRT as well. If there is no direct option read and patch module 02 and write it back. Clear RE-LO. You will be good to go.
