 Post subject: Unrecoverable Error Reported at Seagate ST3250318AS
PostPosted: April 6th, 2018, 14:14
(D) SATA Reset
F3 T>
Rst 0x08M
(P) SATA Reset
PASS
RW: Error processing Performance Parameter File: 203C
Send Status: COMRESET seen
InitiateMarkPendingReallocateRequest for disc_lba: 00001448
InitiateMarkPendingReallocateRequest for disc_lba: 00001449
InitiateMarkPendingReallocateRequest for disc_lba: 0000144A
InitiateMarkPendingReallocateRequest for disc_lba: 0000144B
InitiateMarkPendingReallocateRequest for disc_lba: 0000144C
InitiateMarkPendingReallocateRequest for disc_lba: 0000144D
InitiateMarkPendingReallocateRequest for disc_lba: 0000144E
so on and so on...
F3 T>V40
Nonresident GList 7 entries returned
Total entries available: 7
PBA Len Flags Phy Cyl Hd PhySctr SFI
1418 2 20 2 0 D0 7AA96
141E 1 20 2 0 D6 7B66C
1421 1 20 2 0 D9 7BC9F
145D 1 20 2 0 115 834DA
14A8 1 20 2 0 160 8CB3B
256D 1 20 3 0 881 6C638
257B 1 20 3 0 88F 6E265
F3 T>/7
F3 7>X
Head 00 Resistance 00F6
F3 T>F"BGMSFlags",00,22
Drive AMPS Configuration has been modified from compiled defaults.
Drive must be re-initialized to controller firmware defaults by re-downloading c
ontroller firmware
DO NOT SHIP WITHOUT FIRST RE-DOWNLOADING CONTROLLER FIRMWARE OR RESETTING TO DEF
AULTS!
(D) SATA Reset
Byte:011C: BGMSFlags = 00
F3 T>F"RWRecoveryFlags",01,22
ontroller firmware
AULTS!
(D) SATA Reset
Byte:00A2: RWRecoveryFlags = 01
F3 T>F"PerformanceFlags",043C,22
ontroller firmware
AULTS!
(D) SATA Reset
Byte:056C: PerformanceFlags = 04 3C
F3 T>F"ReadRetries",00,22
ontroller firmware
AULTS!
(D) SATA Reset
Byte:00A3: ReadRetries = 00
Power Off and On
Rst 0x08M
(P) SATA Reset
PASS
ontroller firmware
AULTS!
on device manager right click to detect changes
drive come back.partitions is visible now. but only 5 minutes. then disappear again.
Set Transfer Mode selected
PIO selected
Multiword DMA selected
Disable Reverting to Power-On Defaults selected
Enable Write Caching selected
Write Caching supported, so enable
ProcessRWError -Read- at LBA 0000B700 Sense Code=40000087
ProcessRWError -Read- at LBA 00032800 Sense Code=40000087
ProcessRWError -Read- at LBA 00032840 Sense Code=40000087
ProcessRWError -Read- at LBA 0E8FC000 Sense Code=40000087
ProcessRWError -Read- at LBA 1D1C57FF Sense Code=40000087
is this head issue?
 Post subject: Re: Unrecoverable Error Reported at Seagate ST3250318AS
PostPosted: April 6th, 2018, 14:17
Try to clone with hardware based tools ?
PostPosted: April 6th, 2018, 14:23
which is the best? is there a free tool?
or is that useful?
i tried hddsuperclone with no success before at seagate st2000dm001.
actually i don't need data now...
PostPosted: April 6th, 2018, 14:27
Replace the drive and don't use Seagate F3 arch drives ever again.
PostPosted: April 10th, 2018, 15:43
i upgrade firmware to CC49.
these all peculiar messages disappeared.
but sectors inaccessible yet.
looks like partial access problem... But NRG list contains 7 entries..
PostPosted: April 10th, 2018, 15:46
If you don't need the data just replace the drive ...
Users browsing this forum: Google [Bot] and 43 guests
