 Post subject: Western Digital Dragon / Draco head-assembly compatibility
PostPosted: May 24th, 2018, 6:10
Regarding WD Dragon and Draco disks:
I'm just curious to know whether anyone has tried head assembly changes between these two versions of drives? I've been inspecting the 3TB, which use 8 heads.
The data of manufacture is usually very close, and it looks as if the main revision between the two is the change of the type of PCB which was used. I looks like the media density is the same. Has anyone had success using donor heads from one Dragon in Draco or vice versa?
John
0161 408 4857
 Post subject: Re: Western Digital Dragon / Draco head-assembly compatibili
PostPosted: May 24th, 2018, 7:26
PM sent
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 77 guests
