This J5 has a base OS of 6.0.1 so it should really have been encrypted unless it was never configured with a lock screen
If the device implementation supports a secure lock screen… then the device MUST support fulldisk encryption [Resources, 1 32] of the application private data (/data partition), as well as the application shared storage partition (/sdcard partition) if it is a permanent, non-removable part of the device.
For device implementations supporting full-disk encryption and with Advanced Encryption Standard (AES) crypto performance above 50MiB/sec, the full-disk encryption MUST be enabled by default at the time the user has completed the out-of-box setup experience. If a device implementation is already launched on an earlier Android version with full-disk encryption disabled by default, such a device cannot meet the requirement through a system software update and thus MAY be exempted.
Encryption MUST use AES with a key of 1 28-bits (or greater) and a mode designed for storage (for example, AES-XTS, AES-CBC-ESSIV). The encryption key MUST NOT be written to storage at any time without being encrypted.
I did see some cases without it, but on brand like Samsung with base OS of 6.0.1 or higher, I do not recall any that did not have encryption. It is useful to know that not 100% of devices are crypted, but if a device is 'dead' then it will always be a risk to remove chip and in most cases will result in encrypted partition
