 Post subject: MRT software version 2.1.2.3 update log
PostPosted: June 7th, 2018, 22:23
MRT 2123 version, version: 2.1.2.3
– Upgrade the driver of Ultra, optimize the size of buffer
– Increase system stability
– This is a paid version.
WD utility, upgrade to 2.2.6.8
– Add USB decryption type of SW6316XTS (1927)
– Add support to new family PebbleB
– Add more series’ writing/reading ROM under Boot Rom mode, including series of 1640-003v,1574,1931 etc.
– Add function of loading module 411 to RAM (under function of loading LDR)
– Add function of enabling module 411
– Add function of disabling module 411
– Add function of collecting defects of user sector via CHS address
– Add function of enabling/disabling module 02
– Add function of enabling/disabling module 30
– Add reading/ writing by RAM shortcut button in right side toolbar, modules can be opened via RAM in module list
– Add shortcut menu of turning on and off the service area
– Add function of loading module list from disk and loading LDR automatically
– Add function of repairing slow response in RAM
– Add function of uploading module 02 to RAM (under function of loading module list from disk )
– Add function of closing SA access in RAM
– Add function of opening SA access in RAM
– Add function of creating new module
– Add function of modifying module size
– Add function of deleting module
– Optimize function of editing ROM head map, drives with 10 heads now can be supported
– Optimize SPT acquisition logic to support drives with 10 heads
– Optimize function of module list to support new module list structure
Samsung utility, upgrade to 2.0.1.7
– Add RAM head map editing function
– Add function of head map setting (in source download interface), can be used to shield head along with burn test function
– Add function of viewing ROM information, displaying ROM type, ROM verification, FIPS address size, Platform Id, headmap and other information
– Add function of reading FIPS module
– Add function of writing FIPS module
– Add function of clearing FIPS module
– Add function of entering/exiting Debug mode
-Optimize terminal reading and writing interface
– Optimize function of burn in test
– Modify family selection interface, add enter/exit Debug mode button and auto detect family button
Seagate F3 utility, upgrade to: 2.0.2.5
– Add support of unlocking to new families of: ID55(LM010), ID59(VM003), ID72(LM024), ID79(VM003), ID87(LM028,LM030), ID91(NM0055), ID94(DM002), ID9B(DM004,DM005)
– Add support of high baud rate in virtual start, reduce virtual start time (exclude families ID59, ID 94 etc.).
– Add support of virtual start to new families of: ID55(LM010), ID59(VM003), ID63(NM0033), ID75(LT012), ID76(LT032), ID81(LM033,LM034), ID87(LM028,LM030), ID8C(LM007,LM035,LM048), IDA5(LM035,LM048), ID94(DM002)
– Add virtual start option of Patch_ERR_WriteLDR to solve the problem that LM series can’t write LDR (ERR in SATA status), the specific families are ID81, ID87, ID8C, IDA5
– Added patch function of family ID72-Kahuna_5400-SSHD (LM000, LM014) to solve the problem that no commands can be executed in serial port
– Add support of reading/writing of drives with 4K service area
– Add support of writing system file via ABA mode, providing a new method to solve user sector access interruption malfunctions, the specific families are ID8C(LM035),IDA5(LM048)
– Add 4K detection of service area via ATA and serial modes
– Add head adaption of Yarra1D(5F), Yarrar5400(75), Moose(27)
– Add the number of drive heads that need to be initialized during initialization
– Add 8M judgment of ROM size of families ID81(LM033,LM034),ID87(LM028,LM030)
– Add function of head shielding of 9YN164 series of family ID58, and support to family ID59( shield head 0 is not supported, and must remain no less than 2 heads)
– Add function of head shielding of family ID40 (Currently only supports hard drives with four heads)
– Add function of modifying model of family ID75 (LT012) (by modifying module or corresponding system file)
– Add function of shielding ZONE ( by modifying ROM)
– Add function of shielding head automatically (only generation 12 can be supported)
– Add function of refreshing and writing of ROM tools
– Optimize the naming rules of ROM saving (Data+Serial Number+Time)
– Optimize the judgment rules of entering BootCode mode
– Optimize the judgment rules of creating LDR
– Fix LED malfunction when backup system file
– Fix malfunction when baud rate is over 460800
– Fix 4K address transition when adding defects to G-list
– Fix malfunction in virtual start that sometimes empty ROM will be written
– Fix malfunction that sometimes options of reloading modules, system files can’t be selected
– In family panel, it shows supported important features of each family
– Integrate functions of firmware unlock and modify model into ROM tools
– Integrate function of ROM adaption into ROM tools
– Add ROM tool, RAM operation into shortcuts bar
– Delete firmware unlock mode one
DE utility, upgrade to: 2.3.3.1
– Add map function
– Add function of exporting data to specified target hard drives
– Add function of exporting data to specified target folders
– Add function of exporting list map to binary format
– Add function of exporting binary to list map format
– Add function of choosing random image address
– Add function of file analysis calculator
– Add function of operating target tasks individually
– Add support of VHDX type of the target virtual disk
– Add support of target virtual disk under 64-bit system
– Add option to save bad file or not save
– Optimize function of mounting when browsing tasks
– Fix enumeration display of VHD devices under 64-bit system
– Fix the wrong name of the saved bad folder
Toshiba utility, upgrade to 2.0.4.0
– Add support of 3.5’’MG04ACA series
– Add support to 2.5”MQ03ABF075 series
Hitachi ARM utility, upgrade to 2.0.2.9
– Add 3.5”HU_7240AL series
– Add 3.5”HUA7230ALA6 series
– Database utility, upgrade to 1.0.1.8
-Optimize function of opening and closing logic
-Optimize function of searching
Email: sales@mrtlab.com
Skype: sales@mrtlab.com
QQ:3292109557
MRT Express & Ultra, Professional Data Recovery Tool
Email & Skype: sales@mrtlab.com
Whatsup: +8615827155998
 Post subject: Re: MRT software version 2.1.2.3 update log
PostPosted: June 8th, 2018, 10:59
A couple things to note:
1. This is another paid update
2. The new version will not open DE tasks created by previous versions. That said, I just wrote a blog on how to import the old sector map into a new DE task, the same way I would with PC3000, when my task gets corrupted.
Recovery Force Data Recovery
PostPosted: June 8th, 2018, 11:38
can it decrypt PeblleB family drives ?
Data Recovery Pakistan
PostPosted: June 8th, 2018, 22:00
Hi, PeblleB family is SATA HDD.
QQ:3292109557
PostPosted: June 8th, 2018, 22:22
Thanks for your efforts and hard working, you have explained it in details.
Users who want to do DE tasks created by previous versions can follow this guide.
QQ:3292109557
PostPosted: June 9th, 2018, 3:13
Another paid version!!!
Maybe better when update SSD futures...
Phoenix Computer Forensic Laboratory
http://www.databack.ir
PostPosted: June 9th, 2018, 7:17
I somehow missed the notice about all updates being paid, but it is only $120. I pay more than 20 times that much every year to keep my PC3K systems updated.
PostPosted: June 9th, 2018, 9:06
This version still cannot create head map on several Samsung drives cause of it still use "default module list"
Damn!
"Family: M8E 2.5''
Model:ST1000LM024 HN-M101MBB
Technology mode key : .....................: OK
Extend disk identify:
Load extend diskIdentify : ................: OK
Flash Version : ...........................: 2BA2gavM.d53
Heads Number : ............................: 4
SA SPT : ..................................: 1536
Module menu...
Load SA Module dir : ......................: OK
The default module list will be used! :roll: :roll: :roll:
Load GEO_TBL : ............................: OK
SA information...
Head map : ................................: 0 1 2 3
Get Part Number : .........................: Err
master password : .........................: not set
user password : ...........................: not set
Create translator......
Read Slist : ..............................: OK
Read Alist : ..............................: Err"
PostPosted: June 9th, 2018, 14:45
QQ:3292109557
what is the family of : WDC WD20NMVW-11C3NS2 ?
PostPosted: June 9th, 2018, 17:36
FBH15SL
http://firmware.hddsurgery.com/?manufacturer=Western%20Digital&family=FBH15SL
PostPosted: June 9th, 2018, 18:45
strange why pc3k detect it as Pebbleb ?
PostPosted: June 9th, 2018, 19:35
I'm confused. These excerpts are from a WD30NMVW-11C3NS2.
C5.rpm
00000000  52 4F 59 4C 01 80 30 00 C5 00 5F 02 91 44 EE C5  ROYL.€0.Å._.‘DîÅ
00000010  48 50 46 44 65 30 34 37 07 07 07 00 00 00 00 00  HPFDe047........
00000020  00 00 00 E0 05 00 00 00 00 00 00 00 00 00 00 00  ...à............
00000030  00 80 E9 00 02 80 01 30 01 10 1B 82 01 50 02 00  .€é..€.0...‚.P..
00000040  01 00 03 82 5A F2 04 80 08 10 50 45 42 42 4C 45  ...‚Zò.€..PEBBLE
00000050  42 00 01 81 01 10 00 00 81 01 10 00 02 81 01 10  B...............
11.rpm
000A12F0  00 01 00 00 00 00 00 00 00 01 57 44 43 20 52 4F  ..........WDC RO
000A1300  4D 20 4D 4F 44 45 4C 2D 50 45 42 42 4C 45 42 2D  M MODEL-PEBBLEB-
000A1310  00 00 20 20 20 20 20 20 20 20 20 20 20 20 20 20
000A1320  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
000A1330  20 20 20 20 20 20 20 20 20 20 00 01 20 20 20 20
000A1340  20 20 20 20 00 01 00 00 00 00 00 00 00 00 00 00
02.rpm
000000F0  06 00 60 0B 3B 00 9B 0B 2B 00 00 01 57 44 2D 57  ..`.;.›.+...WD-W
00000100  58 51 31 45 32 35 43 52 32 30 55 00 00 00 00 00  XQ1E25CR20U.....
00000110  00 60 00 57 58 51 31 45 32 35 43 52 32 30 55 20  .`.WXQ1E25CR20U
00000120  20 20 20 20 20 20 20 58 4C 47 54 30 32 33 30 37         XLGT02307
00000130  4D 43 30 30 30 34 32 30 30 36 20 37 33 32 48 36  MC00042006 732H6
00000140  49 31 35 49 33 39 53 38 20 20 20 20 20 20 20 00  I15I39S8       .
000005B0  03 01 00 01 00 00 00 00 00 00 00 01 57 44 43 20  ............WDC
000005C0  57 44 33 30 4E 4D 56 57 2D 31 31 43 33 4E 53 32  WD30NMVW-11C3NS2
000005D0  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
000005E0  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
000005F0  20 20 20 20 20 20 20 20 20 20 20 20 00 00 20 20
PostPosted: June 10th, 2018, 13:23
QQ:3292109557
It is strange that MRT guys said Pebbleb is a Sata Drive.
PostPosted: June 12th, 2018, 9:27
saltwater wrote:
[Create translator......
It looks like the drive has g-list problems hence there is no way to create a head map in DE. The hdd translator has to function properly in order to do head map on Samsung hdd.
www.datasave.ro
PostPosted: June 12th, 2018, 17:11
Same drive with older MRT (2.0.x.x) and no "The default module list will be used!" message in Samsung module can create head map in DE!
Using the "default module list" is cause that the modules entry points are wrong, and that's why reading A-list is failed when we try creating head map in DE.
PostPosted: June 13th, 2018, 1:13
Just tested on a unstable 1TB M8 drive and it works ....Head map was created in 9 sec in DE....Impressive....But you have to repower the drive many times if it's unstable and does not read all the modules at start-up.
www.datasave.ro
PostPosted: June 19th, 2018, 9:24
Hi!
Where can i find in this version the "Seagate auxiliary tool for changing ROM" menu?
Thanks!
PostPosted: June 19th, 2018, 21:16
Hi, you can find "Seagate auxiliary tool for changing ROM" in Tool →ROM tool.
MRT Sales Consultant--Pink
QQ:3292109557
