Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: rebuild mod47
PostPosted: June 29th, 2018, 19:30
This is the best I can do (see attachment).
That said, if both (?) the PCB and headstack were swapped, then wouldn't it be preferable to import the donor's channel, preamp and microjog adaptives into the patient's ROM?
47_rebuilt_from_40.rar [400 Bytes]
Downloaded 83 times
PostPosted: July 1st, 2018, 11:10
thanks fzabkar your generated 47 module it works,after writing 47 and repair damage modules the hard disk go's ready and i can access the data you are the best fzabkar
thank you very much.
PostPosted: July 1st, 2018, 11:37
Very cool !!!!
Thanks for letting us know that it did work !!!
:D
PostPosted: July 1st, 2018, 11:41
Did you end up testing MRT "function" to rebuild module 47 from module 40, etc ?
PostPosted: July 1st, 2018, 16:14
yes dear spildit i tested before that mrt rebuild all modules only the 47 end with error i want to contact mrt support but the case closed by fzabkar great help,really he is good in hex.
PostPosted: July 1st, 2018, 17:36
OK !!! Very cool !!!
The only point that we must note is that most likely you did try to rebuild 47 from copies of ROM MODULES in SA (that do not exist on your drive) instead of recovering from module 40, etc ...
Regards.
PostPosted: July 3rd, 2018, 2:29
Dear spildit mrt use two method the first trying load from sa backup and if fail go to method two is rebuilding the 47 from mod40 like the attached picture.
File comment: rebuild rom modules in mrt
PostPosted: July 3rd, 2018, 13:51
Thanks !
PostPosted: August 14th, 2018, 5:02
IMAGINE!??? If there was like.... a thing... with.... SQUIGGLES on it... almost like... LANGUAGE! Imagine if there was a book, not written in changlish -- that introduced the way the thing worked sufficiently to where people didn't consistently point out how difficult it is to learn given that absolute non-existence of documentation; video tutorials. Or even a tendency for tech support to reply within 3 days.
....Though I doubt they haven't in 30, I just gave up bothering to get a reply.
