 Post subject: WD30EFRX ROM needed
PostPosted: July 11th, 2018, 6:51
I have a WD30EZRX-00SPEB0 with the ROM damaged.
Unfortunatly I do not have any compatible ROM.
Does someone have a compatible disk that can send me the ROM to try if it is compatible.
WD30EXRX-00SPEB0
27 MAY 2015
HANNHTJCAB
S/N WCC4...
PCB: 771945-002 Rev.A
Thanks.
 Post subject: Re: WD30EFRX ROM needed
PostPosted: July 11th, 2018, 7:25
are you sure about the model ?
what family is it ?
is the ROM completely damaged ?
what do you get when read it an external programmer ?
PostPosted: July 11th, 2018, 9:49
Yes it is that model. I think family is Diablo 3S.
I cannot read the ROM with the external programmer.
PostPosted: July 11th, 2018, 10:08
cant be both
the title says WD30EFRX
and
Miss Di wrote:
I have a WD30EZRX-00SPEB0...
and latter it says
Miss Di wrote:
WD30EXRX-00SPEB0
27 MAY 2015
HANNHTJCAB
S/N WCC4...
PostPosted: July 11th, 2018, 10:15
Family is Giant
Mikippp
File comment: 20-MAY-2015
ROM_01-83C_01-84C_02-62.zip [760.38 KiB]
Downloaded 39 times
ROM_01-8BC_01-8CC_02-67.zip [761.07 KiB]
Downloaded 36 times
PostPosted: July 11th, 2018, 10:19
try this one (adapt the ROM if needed its from A WD40)
ROM_WD40.zip [238.03 KiB]
Downloaded 38 times
PostPosted: July 11th, 2018, 12:36
Thanks for all your answers and sorry for the confusion about the model. The correct one:
WD30EZRX-00SPEB0
27 MAY 2015
HANNHTJCAB
S/N WCC4...
PostPosted: July 11th, 2018, 14:42
nothing has been changed
my reply stays the same
try the ROM I've attached
PostPosted: July 19th, 2018, 21:44
Online
WD30EZRX-00SPEB0
27 MAY 2015
HANNHTJCAB
S/N WCC4...
FYI:
http://myfwcloud.com/resource/10119
http://firmware.hddsurgery.com/?manufac ... Sadle%20G6
