 Post subject: WD 1tb not spinning
PostPosted: July 11th, 2018, 11:55
Newbie here.
So my imac wouldt turn on. I pressed power button a few times and heard a pop and then smelt burnt smell. Unplugged it and let it sit.
Now im trying to recover data. I removed hard drive and got a SATA cable. When I plug it in the light flashes on then off and that is it nothing. I cant hear anything.
The model number is WD1001fals-403AA0
Not sure what to do from here?
I have seen that i might be able to replae the board on the HD but not sure?
 Post subject: Re: WD 1tb not spinning
PostPosted: July 11th, 2018, 14:54
If you hear absolutely nothing than it is possible that the board may be fried. Can you take a picture of the component side of the PCB. You will need a Torx T8 to take off the board.
Unfortunately you cannot just swap the board from another like drive and have it work. ( unless you get very lucky it is the same rom version). If it is a bad board you would need to swap the rom information over to a donor board.
But it is possible that this PCB has a TVS that has fried and it could be an easy fix to get the drive up to recover your data, but not for continued use.
PostPosted: July 11th, 2018, 14:55
There's a chance that the issue is just a blown TVS diode on the drive. That model typically has PCB number 2060-774640 which has TVS diodes on both the 5V and 12V rails.
Get yourself a multimeter and check for resistance across these two components. If either one reads dead short measured in both directions, it can simply be removed.
Just be sure you're running on a clean power supply, preferably plugged into a UPS battery, since removing that will expose other components to power surge damage.
PostPosted: July 11th, 2018, 15:00
Thanks DM, I could not find one handy to take a picture and show. Usually the one I see damaged the most is the one on the far right at the edge of the PCB
PostPosted: July 11th, 2018, 16:20
Ok here is a picture. Also I tested resistance and it works oneway but not the other is that correct? Or am I doing something wrong?
PostPosted: July 11th, 2018, 17:03
@SSStang, are you saying that both diodes test the same way?
Can you give proper resistance readings for the diodes and zero-ohm resistors?
http://www.hddoracle.com/download/file.php?id=5420&mode=view
You can read the instructions in my FAQ:
http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
PostPosted: July 11th, 2018, 22:36
So I guess I was doing something wrong. Read instructions and I get resistance on both diodes.
Not sure where to go from here.
Thanks for the help
PostPosted: July 11th, 2018, 23:59
Power Up In Standby (PUIS)?
PostPosted: July 12th, 2018, 9:31
Just to avoid misunderstandings, can you post the measures you read from both diodes ?
PostPosted: July 12th, 2018, 14:55
Replace the PCB and move the ROM chip ?
PostPosted: July 12th, 2018, 16:37
I don't think so, the op says
SSStang wrote:
.....and then smelt burnt smell.
you should check again the measurements of the TVS or change pcb + ROM
Users browsing this forum: No registered users and 14 guests
