 Post subject: Slow responding ST1000DM003
PostPosted: July 12th, 2018, 7:42
Hey,
can some one help me out? I have a Seagate ST1000DM003 drive. The drive initialises normally, but stays busy for a while.
The first thing I did was, I patched sysfile 93. After the patch, the drive gets ready right after initialisation, but when I try to read the drive id, again I get the busy signal. Can some one tell me, what I can try?
 Post subject: Re: Slow responding ST1000DM003
PostPosted: July 12th, 2018, 7:55
If you can publish the terminal report it will help diagnose the problem,
Maybe a problem with the DOS table?
PostPosted: July 12th, 2018, 8:01
Sure and thank you for your help:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
RAW OFF
PASS
MCMainPOR: Start:
User Data Base  00441140
Check MCMT Version: Current
MCMainPOR: MCTStateFlags 0000002A  MCStateFlags 000000C1
MC061: MainPOR: MC off and MCMT empty
MC057: MainPOR: EXCEPTION: POR Failed General  Tms 00000040
MC062: MainPOR: Feature Disabled...
MSP MainPOR: Feature Disabled by AMPS
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
FYI, I set the additional messages flag in the sysfile 93. And that's it.
PostPosted: July 12th, 2018, 13:26
What tools do you have?
PostPosted: July 12th, 2018, 13:27
PC3k
PostPosted: July 12th, 2018, 14:31
Do you have access to a terminal?
Have you checked that glist is not full?
PostPosted: July 13th, 2018, 5:14
Yes, I have access to the Terminal.
I checked the G-List and it was full, so I cleared it with i4,1,22
After this, I was able to access the User Area. Currently I have the problem that the drive is still relocating the sectors, right after I powered the drive on and while imaging. Even though I have turned auto relocation off in edit HDD ID.
(DOS) Read Error - 43110081
InitiateMarkPendingReallocateRequest for disc_lba: 0007A97A53!
(DOS) Read Error - 0007A97A53
WTR: Outer Timer Expired
(DOS)ABT
(DOS) NEED: 0x0007A97A54-0007A980DB - 0x00023D93-00023D96 Count 2098
(DOS) Refresh Start.
(DOS) Marginal Read: 0007A97A54
InitiateMarkPendingReallocateRequest for disc_lba: 0007A97A54!
(DOS) Read Error - 0007A97A54
(DOS)ABT
(DOS) NEED: 0x0007A97A55-0007A980DB - 0x00023D93-00023D96 Count 2098
(DOS) Marginal Read: 0007A97A55
InitiateMarkPendingReallocateRequest for disc_lba: 0007A97A55!
(DOS) Read Error - 0007A97A55
(DOS)ABT
(DOS) NEED: 0x0007A97A56-0007A980DB - 0x00023D93-00023D96 Count 2098
(DOS) Marginal Read: 0007A97A56
InitiateMarkPendingReallocateRequest for disc_lba: 0007A97A56!
(DOS) Read Error - 0007A97A56
(DOS)ABT
(DOS) NEED: 0x0007A97A57-0007A980DB - 0x00023D93-00023D96 Count 2098
(DOS) Marginal Read: 0007A97A57
InitiateMarkPendingReallocateRequest for disc_lba: 0007A97A57!
(DOS) Read Error - 0007A97A57
(DOS)ABT
(DOS) NEED: 0x0007A97A58-0007A980DB - 0x00023D93-00023D96 Count 2098
And after a while the G-List is full again.
PostPosted: July 13th, 2018, 14:58
Can I see 2a(93)?
PostPosted: July 13th, 2018, 16:46
Try to disable re-location by congen.
Issue the following commands to make your life easy :
http://www.hddoracle.com/viewtopic.php? ... =60#p10834
PostPosted: July 13th, 2018, 21:26
Unfortunately, this is what it is (it is a SEAGATE drive....)
This helps, but disabling the relocation will not make the damaged sectors disappear.
Change the head block, you can check them out, I don't think it's going to get much better either.....
Unless you want to recover 1TB of data (or nearby) you would also not try to make a full-image of this drive, you may die in the attempt.
It would be better to clone at the same time as the important data is being retrieved, the first pass with very short waiting times and the next passes increasing the waiting time ( and refreshing all sectors except those read successfully).
Every now and then when the G-list is full, then re-clean and continue with the recovery.....
Good luck, you'll need it.
PostPosted: July 14th, 2018, 7:44
... Drive shouldn't add defects to G-List just by reading even more if you disable re-location process ...
PostPosted: July 15th, 2018, 8:15
drHDD wrote:
Can I see 2a(93)?
Sure....
Thank you for the support!
93.bin.zip [1.71 KiB]
Downloaded 75 times
PostPosted: July 15th, 2018, 21:35
try this one
93.7z [946 Bytes]
Downloaded 93 times
Users browsing this forum: Google [Bot], oelimtrila7 and 71 guests
