 Post subject: MK6021GAS
PostPosted: September 4th, 2018, 10:24
The drive in topic came to me with stucked heads. Then I found that the motor is jammed as well. :)
The problem that I want to do a platters swap, but I have only two donors with stucked motor too. :lol: :lol: :lol:
Any suggestions?
 Post subject: Re: MK6021GAS
PostPosted: September 4th, 2018, 10:33
You will need a donor with spinning platters and then do a platterswap...quite common on those drives.
http://www.rescue-it.se
PostPosted: September 4th, 2018, 12:50
Another alternative donor did the job perfectly with some modifications :D
MK8032GAX
