 Post subject: Sata converter for mz-flv2560 !
PostPosted: September 16th, 2018, 6:09
Any one tried working converter for Samsung mz-flv2560 comes out of Microsoft surface 2 . i have may converters for m2 . but all it's socket are shorter about 2 mm than the device
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
 Post subject: Re: Sata converter for mz-flv2560 !
PostPosted: September 16th, 2018, 7:29
aren't these mSATA? not M.2? pretty sure they are standard
PostPosted: September 16th, 2018, 9:28
It's a Form Factor M.2 2280 NVMe...some ordinary adapters won't take them.
Check if your motherboard has a M.2 slot...if so, it will probably fit.
http://www.rescue-it.se
PostPosted: September 16th, 2018, 9:33
thanks for replay
the microsoft surface main pcb is died .and even ACE m.2 adapter is not fit to the drive . the 2mm larger than the adapter soket
Tawfeek Mokhtar
PostPosted: September 16th, 2018, 9:34
i think it's m.2 NGFF but not sure . i attached the drive picture .
Tawfeek Mokhtar
PostPosted: September 16th, 2018, 10:32
here is one, it should be fine.
have bought this and 10 more from China.
will search the contact info.
Data Recovery Pakistan
PostPosted: September 16th, 2018, 11:16
Are you sure it is a surface 2? even surface 3 had mSATA. I am thinking a surface Pro 4..?
PostPosted: September 16th, 2018, 11:32
that's what customer said . he just bring us the SSD to take the data
Tawfeek Mokhtar
PostPosted: September 16th, 2018, 17:01
All my Google searches for PM951 or MZ-FLV2560 identify the SSD as PCIe x4.
PostPosted: September 17th, 2018, 0:10
if that is the SSD, datecode of 2016 implies that maybe not a surface 2. they stopped production in 2015 of them.
Model :MZFLV256HCHP
Capacity(GB) : 256GB
Interface Type: M.2 NGFF PCIe x4
also:
and it would be the M.2 with "M" key in the slot
https://www.pugetsystems.com/labs/articles/Overview-of-M-2-SSDs-586/
PostPosted: September 17th, 2018, 1:57
The function of an M.2 card is determined by 4 CONFIG pins (CONFIG 0 - 3).
M.2 format identification:
http://www.hddoracle.com/viewtopic.php?f=106&t=2506
PostPosted: September 18th, 2018, 8:39
This adapter will never work with this model
I had a similar cases, Thnx to Michal (Arvika) for his tips... case closed.
Users browsing this forum: Google [Bot] and 49 guests
