Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: WD5000BMVW-11S5XS0
PostPosted: July 4th, 2017, 18:40
To the OP, is there a chip at U7 near the spindle motor pins (J6)?
PostPosted: July 4th, 2017, 19:13
I will check it tomorrow when i get to the office if it exist or no and post the result.
Thank you Mr. Frank.
PostPosted: July 5th, 2017, 3:07
I may be introducing a red herring, but Samsung's "RRO1x" (repeatable runout?) data look very similar in nature to WD's adaptives. That is, the data occur in pairs, and the values can be positive or negative.
Need DR professional help with Samsung HM100UI/UZ4:
viewtopic.php?f=1&t=29701
PwrOn RRO1x @ H0
Table) cos = -446464, sin = 655360 (-0x6D000, 0xA0000)
Coeff) cos = -69509, sin = -3977 (-0x10F85, -0xF89)
DiskSlip : 97 [SrvTrk] (0x61)
DiskSlip : 94 [SrvTrk] (0x5E)
PwrOn RRO1x @ H2
Table) cos = -447488, sin = 652288 (-0x6D400, 0x9F400)
Coeff) cos = 85611, sin = -108729 (0x14E6B, -0x1A8B9)
DiskSlip : 121 [SrvTrk] (0x79)
PwrOn RRO1x @ H4
Table) cos = -450560, sin = 652288 (-0x6E000, 0x9F400)
Coeff) cos = -119334, sin = 23064 (-0x1D226, 0x5A18)
DiskSlip : 104 [SrvTrk] (0x68)
PostPosted: July 5th, 2017, 6:02
U7 exist
PostPosted: July 5th, 2017, 12:31
I think that your drive WD5000BMVW-11S5XS0 - FireBird is a downsized 1TB HDD with two heads deactivated. The normal Firebirds are WD10JMVW-11S5XS0 with 4 heads. You have to figure out the head map of your drive and just then to try reading of SA.
PostPosted: July 5th, 2017, 17:10
This PCB (from a Hubble_LT) has the same MCU and motor controller. FWIW, U7 is unpopulated. The adaptive section is similar to that of the WD1001X06X-00SJVT0. Perhaps there is a clue here?
    88i446-NDB2
    Nautilus
    WD5000LPVX-22V0TT0
    HUBBLELT
    2060-771959
    unpopulated U7
    1 shock sensor
    2 heads
    SATA
http://ep.yimg.com/ay/yhst-14437584971410/2060-771959-000-14.gif
module 4F
00000190                    00 00 90 AA 00 00 00 00 70 0C
000001A0  00 00 28 0C 00 00 00 00 00 00 00 00 00 00 18 00
000001B0  00 00 F8 FF 00 00 00 00 00 00 00 00 00 00 00 00
000001C0  00 00 00 00 00 00 00 00 00 00 00 00
head 0   head 1
0000700C 0000280C 00000000 00000000
00001800 0000F8FF 00000000 00000000
PostPosted: July 6th, 2017, 19:22
WD5000BMVW-11S5XS0, ver 0003003V, 3 heads, head map 00001110
000001F0                    00 00 90 AA 00 00 00 00 00 00
00000200  A3 65 91 08 D3 D8 5A 08 57 89 91 08 00 00 00 00
00000210  00 00 00 00 00 00 00 00 4E 2A D4 07 4D AD FF 07
00000220  F3 E2 CC 07 00 00 00 00 00 00 00 00
head 0   head 1   head 2   head 3
00000000 A3659108 D3D85A08 57899108 00000000 00000000
00000000 4E2AD407 4DADFF07 F3E2CC07 00000000 00000000
PostPosted: July 8th, 2017, 16:12
Just a curious observation ...
The most recent patent on the OP's drive (manufactured in 2013) was assigned on 11 Sep 2001:
https://www.google.com.au/patents/US6289484
Did WD cease printing their patent numbers on their labels after this day, perhaps as a mark of respect?
PostPosted: September 17th, 2018, 16:48
I'm reasonably certain that U7 is a barometric pressure sensor. It appears to consist of a Wheatstone bridge with 4 piezoresistive elements.
http://www.hddoracle.com/viewtopic.php?f=100&t=2483&p=18107&hilit=barometric+pressure+sensor#p18107
This post is interesting:
http://forum.acelaboratory.com/viewtopic.php?t=9854&p=35545#p35545
AJ2008 wrote:
... these drives implement additional adaptive data for dual actuators in ROM module 4F - without original ROM it is not possible to restore access to data.
PostPosted: September 18th, 2018, 7:37
It IS possible to recover data without native ROM.
No idea why people say something is impossible... that's a very strong and rude word to use here.
Why don't they say 'we don't know...' ?
No bitcoin donations :)
PostPosted: December 24th, 2018, 16:29
Doomer wrote:
ShrekLT does not have dual actuators, but I must admit I mistakenly thought that important adaptives in 4F are dual-actuators related(they aren't) and even probably convinced some people of it.
Nevertheless the adaptives are important and w/o them drive won't read anything. They can be restored but it's a grueling process. There is no way to do it with PC3K.
http://forum.acelaboratory.com/viewtopic.php?t=9854&p=36097#p36097
Users browsing this forum: Google Adsense [Bot] and 39 guests
