 Post subject: ST3500312CS With SC13 Not detected
PostPosted: September 30th, 2018, 7:13
HDD with model ST3500312CS with FW. SC13.
When connected with terminal Shows only
Rst 0x08M
Then nothing but hdd is spinning without clicks.
Changed PCB and transferred ROM then also Same result.
What is the problem?
 Post subject: Re: ST3500312CS With SC13 Not detected
PostPosted: September 30th, 2018, 7:55
Sounds like a firmware problem.
http://www.rescue-it.se
PostPosted: September 30th, 2018, 10:30
Did you try sending? Ctrl Z
PostPosted: September 30th, 2018, 11:35
likely firmware problem as mentioned by spokk
Data Recovery Pakistan
PostPosted: September 30th, 2018, 14:17
Can you give more information?
What utility do you use ?, do you have access to the SA? etc.
PostPosted: October 1st, 2018, 4:31
Problem Solved.
By Blocking Motor Got T Prompt. Tried to clear Smart but got LED: CD error
Then tried with
1. Arrived T Prompt
2. Checked V4 and V40 Nothing
3. Tried with m0,6,3,,,,,22 but got Diag error 500D
4. Applied m0,2,1,,,,,22 then m0,2,2,,,,,22
5. Cleared SMART
6. Data Ready
PostPosted: October 1st, 2018, 5:42
Congratulations and thank you for sharing the solution.
PostPosted: October 1st, 2018, 16:54
DO NOT do this on 7200.12 drives and later. It's .... "rather ok" for 7200.11 and OP was lucky with that pipeline but .... just DON'T DO IT ...
Users browsing this forum: Google Adsense [Bot] and 32 guests
