 Post subject: SAMSUNG ST500lm012 HD that is not recognized by the BIOS
PostPosted: October 3rd, 2018, 23:30
Guys, I have a SAMSUNG ST500lm012 HD that is not recognized by the BIOS.
Notebook FIC DIAMOND PCA46
Could someone help?
The HD runs on another notebook perfectly.
 Post subject: Re: SAMSUNG ST500lm012 HD that is not recognized by the BIOS
PostPosted: October 4th, 2018, 1:59
Have you tried another HD on this notebook?
PostPosted: October 4th, 2018, 6:36
Yes and works perfectly.
PostPosted: October 4th, 2018, 7:05
It is quite rare, but sometimes an old laptop may sometimes recognize a unit and sometimes not, especially with the SSD.
Always in these cases it is recommended to do a BIOS update at the beginning. The manufacturer sometimes says that the update is to fix a certain failure, but other failures not described are usually fixed.
If it used to work on this laptop before and not now. Try removing the battery and charger and having the power button pressed for 30-40 seconds, and then turn it on ..
I'm sorry I did not give you another help.
PostPosted: October 4th, 2018, 16:16
Hardware compatibility issues:
https://ata.wiki.kernel.org/index.php/Known_issues
SATA 3.0 (6Gb/s) devices may not be detected on Intel 5 series and mobile 5 series southbridge
Problem description
Handshake between SATA device and SATA controller on Ibex Peak PCH southbridge may not complete after booting from ACPI G2, G3 state or after resuming from ACPI S3, S4 state and thus device will not down-shift to 3Gb/s speed resulting in undetected device.
Root cause
Southbridge erratum #21.
Affected southbridge
3400, 3420, 3450, B55, H55, HM55, P55, PM55, H57, HM57, Q57, QM57, QS57
Solution
None, reset the system until device is detected.
PostPosted: October 4th, 2018, 16:35
I reset, but the BIOS does not identify!
This is SATA 2.
PostPosted: October 4th, 2018, 16:41
https://http2.mlstatic.com/hd-sata-2-500gb-samsung-5400rpm-st500lm012-notebook-dell-D_NQ_NP_844901-MLB27363027081_052018-F.webp
This is SATA 2!
PostPosted: October 4th, 2018, 16:46
https://http2.mlstatic.com/hd-500gb-gb-samsung-st500lm012-notebook-ps3-xbox-seagate-D_NQ_NP_710639-MLB25694830375_062017-O.webp
PostPosted: October 4th, 2018, 17:23
I do not know if this can help you?
Users browsing this forum: Abdul Rauf and 31 guests
cron
