 Post subject: raw drive
PostPosted: October 13th, 2018, 2:25
what are the viable solutions to convert raw drive back to ntfs? the story: i was trying to clone a ddrescued drive using easeus software but as the process was stuck, i interrupt it with end task and the drive turned raw. i read that there is a way to recover the files but if there is anyway to convert the whole drive back to ntfs? thxs all in advance.
 Post subject: Re: raw drive
PostPosted: October 13th, 2018, 14:34
Source drive shouldn't became "raw" just because you stop to clone. Cloning process shouldn't affect source drive, only destination ....
Maybe you did clone the other way around (destination to source) and now your data is over-written with the data on the destination drive ?
:shock:
Or the source drive did have further problems and now is gone ...
PostPosted: October 13th, 2018, 16:31
Just to make it clear, how many drives are there in the story ? If the corrupted drive itself contains a ddrescue recovery from a defective drive, do you still have that defective drive ? As per the second hypothesis above, did you make absolutely sure that the source and destination were correctly set before proceeding with the cloning ? If it is indeed a clone of a clone, why did you want to clone it again, just for safety, or because the recovery drive also seemed to have issues ? What is the SMART status of all the involved drives ? Do you know why the Easus software was stuck, was there any warning / error message ? Does that software keep logs somewhere ? Did you try scanning the “raw” drive with a reputed recovery software (R-Studio and DMDE are often recommanded here), or opening it and its partitions with WinHex or equivalent ?
@Spildit
If that were the case, even if the clone was partial, the system should recognize the partition(s) from the erroneously cloned drive, wouldn't it ? Unless the drive which should have been the destination and turns out to have been wrongly set as source was totally empty, which is unlikely.
PostPosted: October 14th, 2018, 8:48
Normaly i do zero fill the destination drives first. I use security erase. This helps to make sure that the destination drive is ok and also helps if you use a tool that will clone the ocupied sectors only of the source.
If you clone only the ocupied sectors (LBA) to a destination that does already have data on it and if your tool doesn't fill the empty sectors of the destination with zeros and doesn't fill a pattern like !BAD! or whatever for the sectors on the source that can't be copied later when you do run a full logic scan with something like R-STUDIO you will pick up the old data on the destination that was not over-written by the source...
You can contaminate the recovery and end up with data from another client on if you keep using this process.
For safety reasons i NEVER use a drive as destination that was not cleared first. Also i almost never use direct clone and i use image files instead as it's more easy for me to store several images in one big drive rather than using multiple drives.
PostPosted: October 14th, 2018, 20:52
I agree with all that, but the point here was trying to guess what happened in this particular case, a case where someone who is apparently a regular user, not a data recovery professional, did something wrong and is trying to fix it. But with no further input it's hard to say anything relevant... And considering the other thread created by the O.P., if both issues are related, there might be no easy fix, and possibly no fix at all.
cron
