I don't need to erase the drives. I just should not be possible to write data but I still want to read it.
I did some more research and found some SSDs with more pins. Some are advertised as having write protection and hardware purge features. Though it looks like in some cases also a custom firmware would be necessary.
Hardware purge:
https://us.transcend-info.com/Embedded/Essay-19These Transcend SSDs have JTAG, Serial and 3 other pins which are probably used with a jumper to either write protect or erase the device. Anyone came across those or knows more about these pins?
https://ozon-st.cdn.ngenix.net/multimed ... 299165.jpghttps://www.transcend-info.com/Products/No-632https://www.transcend-info.com/Files/ED ... N_1710.pdfI also came across these similar SSDs from different manufacturers:
https://ae01.alicdn.com/kf/HTB1sIuNArSY ... esktop.jpghttp://www.zheinossd.com/photo/ps193925 ... active.jpgThey don't seem to have a serial connection but JTAG and three jumpers. One being labeled ROM but no information about the other ones.
These ones have a ROM jumper and one labeled QE.
http://www.zheinossd.com/photo/ps183760 ... _flash.jpgThese are mostly msata SSDs, I could also find some real SSDs with enclosure which have additional pins for different erase functions (some including firmware) and write protection. But I guess they are going to be pricey.
https://www.apro-tw.com/Databank/2017%2 ... MSTCMB.pdf
