 Post subject: ST1000LM014 SSHD
PostPosted: November 10th, 2018, 12:32
Hello
The drive in topic has PCB issue, I found a fully matched donor for PCB swap ( PCB number + FW ) are same.
After clearing NAND on donor drive ( O I )
I transfered the patient ROM to donor PCB. The drive spin up but still ID with donor SN and no user area access.
Thanks in advance.
 Post subject: Re: ST1000LM014 SSHD
PostPosted: November 10th, 2018, 12:39
The donor drive access SA and user area with it's native ROM and with patient ROM. :D
PostPosted: November 10th, 2018, 13:07
what was the symptom with original PCB ?
can we see terminal log ?
Data Recovery Pakistan
PostPosted: November 10th, 2018, 13:30
With native PCB+ROM the drive stays busy and no terminal output (no spin up)
PostPosted: November 10th, 2018, 14:27
SSHD always start reading ROM from copy embedded in NAND? is that right?
If yes, After erasing (donor NAND) and transfer patient ROM to donor PCB this should make the patient start from the external ROM?
PostPosted: November 16th, 2018, 7:06
No, it will still start from NAND. However, there is a way of getting it start from sfl of course.
No bitcoin donations :)
PostPosted: November 17th, 2018, 13:24
Here is the patient ROM:
Thanks in advance
ST1000LM014.rar [630.37 KiB]
Downloaded 52 times
PostPosted: November 18th, 2018, 12:11
Many many thanks to you Mr. Pepe. :good:
PostPosted: November 20th, 2018, 9:43
welcome
Users browsing this forum: jackass25, magnetepazzo and 10 guests
