 Post subject: How to hide first Sectors on hdd ?
PostPosted: September 26th, 2018, 13:53
So i have the drive that have right from the 0 LBA couple
bad sectors, and the rest of the drive is fine/smooth.
I had an idea to Cut the first few Gig with DCO or HPA and
then use as usual. But i tried HPA, and it cuts drive from the
back[ with hdat2].
Q: Is it possible and how to hide area Starting from 0 LBA ?
Thanks.
 Post subject: Re: How to hide first Sectors on hdd ?
PostPosted: September 26th, 2018, 16:36
The ATA standard provides an "address offset" feature, but I believe that these settings are volatile, ie they don't survive a power cycle. In any case, not all drives support this feature.
PostPosted: September 27th, 2018, 1:29
Thanks,
will look into it.
PostPosted: September 27th, 2018, 4:44
For different brands it's different. No easy solution.
PostPosted: September 27th, 2018, 16:27
IIUC, the OP is looking for a universal method using standard ATA commands, not VSCs.
PostPosted: September 27th, 2018, 22:29
in 1990 we used to use pctools for skipping 0 sectors.
But now have completly forgotten the procedure. Anyone can remember now????????????????
PostPosted: September 28th, 2018, 2:56
If you had an MFM drive, then you would have had to low level format it and enter the defects manually. These were printed on the label.
PostPosted: October 2nd, 2018, 14:48
back[ with hdat2].
Thanks.
What is the full model and brand of your drive ?
If you have (vendor specific) firmware tools or if you know special vendor specific ATA commands for your drive you might translate those LBAs to physical location on platter and add those defects to P-List. Depending on the drive you might have to regen translator, format all sectors, etc but with specialized tools it should be very easy to "hide" a bunch of defects as long as the P-List is not full ...
Executing a "Cosmetic Fix" on drives with Bad Sectors :
Assigning slow sectors to the P-List :
PostPosted: October 2nd, 2018, 14:52
Not likely that the rest of the drive is fine ....
Try to WRITE to those first sectors !!!! If the drive is fine those sectors will be re-located as there will be entries on G-List telling the drive to swap those defective sectors by spares !!!
If you do write zeros to those damaged sectors and if the drive doesn't swap them for spares most likely you are out of spares (full G-List) or you did patch firmware to disable re-location, etc .... and if that is the case the drive is anything but in a fine condition ...
PostPosted: October 16th, 2018, 6:27
HDD is HGST 500GB 5400RPM Z5K500-500 HTS545050A7E680
At starting mhdd, i getting for 30secs
"error reading partition table drive 01 sector 0".
I did try couple of times mhdd.erase and some of the lba at
beginning changed from UNC to "red".
Also to confirm that the rest of the disk is <3ms read.
I would like to learn, and this hdd is good for practicing, so
i will try your good suggestions. Thanks
PostPosted: October 16th, 2018, 16:24
Try :
1 - Use mhdd and "erase".
2 - Use mhdd and issue the fast erase (security erase).
3 - Use something like dban to write a pattern of data to the sectors.
4 - Check the drive with mhdd/victoria. Check S.M.A.R.T. . Were the sectors moved to G-List ? Do you have bad sectors or errors ?
5 - If your drive no longer have sectors that are showing error, abort, etc you can try Format Unit to move G-List to P-List :
http://www.hddoracle.com/viewtopic.php?f=21&t=2068
6 - If your drive no longer have bad sectors but still have red or orange slow sectors (or even green ones) and if you do want to get rid of them the cheapest alternative is to pocket out $350 for a SeDiv and use the option to add the Victoria log to the P-List. You can make Victoria log slow sectors (like green, etc) and then use SeDiv (assuming it supports your specific model) to place those sectors on the P-List. Other alternatives (more expensive) are the PC-3000, MRT, etc ... Personaly i do "refurb" my HGST drives with HRT and "defectoscope" that will place the "slow sectors" on the P-List but that tool is almost impossible to buy now.
PostPosted: November 17th, 2018, 6:35
Did secure erase using PMagic and it went well, but
then booted into mhdd, and on F2 says that
'ATA Password locked'.
PostPosted: November 17th, 2018, 6:40
hdat2 says security/enabled/high
PostPosted: November 17th, 2018, 6:57
Gsmartcontrol says "ATA Security ENABLED, PW level HIGH, **LOCKED** [SEC4]" and
in dialog for 'secure erase' "not frozen"
PostPosted: November 17th, 2018, 7:24
Unlocked device unsing hdat2 permanently, but now
now each sector shows error when i try to
F4 with mhdd. Before when i started scan from
100mil.lba scan was smooth at 110mb/s and no
slow sectors.
Is it a heads ?
Can i do something with that or only with the
special tools ?
PostPosted: November 17th, 2018, 10:45
Are you sure the drive is no longer locked ?
Do EID with MHDD and check if it's indeed unlocked.
Maybe the drive was already in a very poor condition and doing the security erase did end up killing it like damaging the head(s) or placing too many defects on the G-List, etc ....
Again better to buy a new drive if you don't have better tools to deal with it.
PostPosted: November 17th, 2018, 11:11
I did Shift+F2 = Unlocked [ did after power-cycle]
I keep detailed log of every step, so i have a record
of scanning with mhdd starting from 700mil.lba and
it did run smooth, and after ATA SE strait from 700
each lba 'Error'=UNC, but then i set 800m.lba and
it's ok. Not worrying about this disk= practicing on it, but
it looks like some parts of the hdd is ok and other
just UNC.
So i just want to understand, is it surface, heads ?
PostPosted: November 17th, 2018, 12:22
Might be a damaged head or patches of surface that are bad (bad zones), etc ...
Without some sort of firmware tool it's hard to tell.
This is a HGST unit so you might want to try the format unit command as well but most likely you will not get much better results ...
PostPosted: November 17th, 2018, 12:50
Ok, thanks for lessons.
HGST 500GB 5400RPM Z5K500-500 HTS545050A7E680 - for parts/donnor
PostPosted: November 17th, 2018, 14:00
This is very hard to tell what the problem indeed is without having the drive with me. Might be a damaged head so you see patches of good sectors alternated with patches of bad sectors. It might be that just some bad sectors are present.
You would need to check G-List, see if you could move defects to P-List (if not full) and scan for more deects, etc ...
I don't have any way to cut zones on your drive so .... Yes ... You most likely can re-sell the PCB ....
Users browsing this forum: Google Adsense [Bot] and 26 guests
