 Post subject: Changed BIOS but no response ( Help!)
PostPosted: December 7th, 2018, 19:47
I've replaced my non-working WD 2,5" HDD's PCB with the new PCB i'd bought from China. (Replaced the BIOS')
I am sure that i havent made a soldering mistake but no response from the HDD :(
Is it possible that my old BIOS could be the problem?
Shall i use the new BIOS to save the hardware for a new start. (Np for my old data)
Thanks.
 Post subject: Re: Changed BIOS but no response ( Help!)
PostPosted: December 7th, 2018, 23:28
What was the reason for PCB swap in the first place? Does the drive spin with the original PCB/ROM? Does the drive spin with replacement PCB/ROM?
If 'Yes' to question 2 and 3 and if the donor PCB is the same as patient PCB, I'd check your soldering job...and/or make sure you're swapping the correct IC.
PostPosted: December 7th, 2018, 23:39
It had suddenly stopped working. No spinning and no sound. When i'd checked the back of the PCB it was really hot, burning...
Now, also the drive doesnt spin with the replacement PCB/ROM. :(
PostPosted: December 7th, 2018, 23:48
What I meant was to try the original drive with the replacement PCB AND ROM that the replacement PCB came with. If the drive spins, then yes the patient ROM may be bad.
PostPosted: December 8th, 2018, 1:08
Ok, I'll do the solder/desolder and try this.
Thank you.
PostPosted: December 8th, 2018, 2:06
Well, i guess this is a progress.
I've soldered my old ROM again. This time it worked :roll: First time i had made a bad solder i guess.
But motherboard couldnt recognize it.
The disk was spinning and stopping. Making a "click" sound and it loops.
What i am a gonna supposed to do next?
PostPosted: December 8th, 2018, 17:29
What you should have done to start with ....
Send it to a REPUTABLE data rcovery firm (and NOT a regular computer repair shop) if you need to see your data again ... If not replace the drive with a anew one ....
Clicking and spinning down .... not only the PCB was having "trouble" but now head(s) and pre-amp are gone as well ...
Assuming your "chinese" PCB is indeed in good shape and is compatible with your drive/old PCB i would say the drive does need clean room work (inside HEPA 100 asepti room) and have the head stack replaced by someone with practice so end for do-it-yourself and as more you power on the drive the less the chances are for the data to be recovered later ...
PostPosted: December 9th, 2018, 7:12
thanks for sharing ...
