 Post subject: Zone allocation table : ........................: Err
PostPosted: December 26th, 2018, 8:33
WD3200BEVT-75A23T0
in MRT Show Error
Any Solutions
 Post subject: Re: Zone allocation table : ........................: Err
PostPosted: December 26th, 2018, 10:43
What's the drive behavior? (Clicking)?
ATA registers shows nothing? Is the drive spin down?
If yes, then most likely a head/s problem.
PostPosted: December 26th, 2018, 11:08
hard drive sping ok
head test ok
no clinking sound
PostPosted: January 7th, 2019, 2:40
Banned User
Module test ok ? Your information is not enough to make further diagnosis
PostPosted: May 19th, 2019, 19:46
I found this solution in another forum. I will try this tomorrow in a hard disk with same problem....
http://www.hddoracle.com/viewtopic.php? ... +rom#p8198
PostPosted: July 22nd, 2021, 17:46
Spildit wrote:
Block SA access at start up by shorting points on PCB. Load overlay, load DIR to RAM (initialize dir). Try to check modules.
Similar procedure with WDMarvel (you need to adapt it to MRT) :
http://www.hddoracle.com/viewtopic.php?f=193&t=2339
If it doesn't work :
http://www.hddoracle.com/viewtopic.php?f=193&t=2343
If you get servo errors, etc you might have bad head(s) and/or pre-amp.
Please "adapt" my guides to your MRT tool as i've written my guides to WdMarvel / HRT.
Hi, these links are broken, do you have saved examples?
PostPosted: July 22nd, 2021, 18:24
You can download the whole web site (3GB) here:
https://drive.google.com/drive/folders/1CD8h7q9cYNVCltqB87-kSBzMRnq3-yU6?usp=sharing
PostPosted: July 22nd, 2021, 20:28
Thank you so much :D
PostPosted: July 22nd, 2021, 20:37
Thanks should go to @maximus.
PostPosted: July 23rd, 2021, 4:22
I knew that hddoracle would went down since Spildit left the scene.
I'm sad, it was a very good site and Spildit was a cleaver user :( ...i will download the backup too.
Thank you @Spildit, @fzabkar and @maximus.
My firmware database:
https://mega.nz/folder/O01DkBRI#MxP2J6ZNqXDcrX40I8MoQQ
PostPosted: August 18th, 2021, 15:36
Thank you.
