 Post subject: Soft ver error. Looking for a solution
PostPosted: December 26th, 2018, 14:43
Hi gurus!
Tinkering with these tools I just stumbled upon this error from time to time, and lately I figured that it happens because of the updates. Once you update your Sw you can work with it but you cannot get back to work with a previous version if you require it. It is much bothering and an additional limitation though, and happened to me mainly with two doctors: Seagate and Hitachi.
Any idea for fixing this particular issue? ;)
Thanks for your help
 Post subject: Re: Soft ver error. Looking for a solution
PostPosted: December 26th, 2018, 16:00
Just use the latest version available ?
Unless they do break functions that were working on older versions ...
PostPosted: December 26th, 2018, 16:30
This is the point spildit :)
For some drives older versions fits better, it is not a rule (i have a very limited experience with sd stuff) but sometimes i managed better using older versions. The last Hitachi sw (7.3) is declared as beta by the developers actually.
Hope to find a way for having this thing fixed
PostPosted: December 26th, 2018, 16:36
I hope that you do have something better than just SD tools ... At least something like SeDiv ....
You can't live on just with SD stuff ....
Might be VERY GOOD for OLD drives like MAXTOR and by all means get it even if you have MRT / SeDiv as you do need MAXTOR support that MRT / SeDiv doesn't have or is very poor but for ... MODER drives you need something way better than SD junk ...
PostPosted: December 26th, 2018, 18:23
Do these updates affect the firmware in the Doctor, or just the host software, or both?
PostPosted: December 26th, 2018, 18:25
Thanks for your reply and i got your point, nonetheless i'm trying to have them sorted out and, fixing issues is a good way for better understanding what we do normally (imo). I worked with ace stuff and actually there are so many things i used to and which i'm not able to replicate without it, but i'm trying to keep up ;)
PostPosted: December 26th, 2018, 18:47
Following my experience I'd say both, but some doctors are more critical than others. Seagate and Hitachi got much more issues in this case :?
PostPosted: December 26th, 2018, 19:04
Why don't you get cheap tools like SeDiv, WDMarvel and SHTR to compensate for the "problems" with those doctors ?
Also i think Data Compass can't image/clone drives bigger than 500 GB ...
PostPosted: December 26th, 2018, 19:56
I'm used to fix problems :) and trying to fix that one doesn't mean that I'm avoiding other tools for working (anyway i don't have those ones, but wdmarvel is a truly good one imo).
Data compass is a fair good imager, just slow as molasses!
PostPosted: December 26th, 2018, 20:04
Yeah .... try to image/clone 1TB drives (or bigger) with it ....
PostPosted: January 5th, 2019, 14:11
Hello everybody, I hope this new year got off to a pretty fair start for you all gurus ;)
There's anybody here who can help with this error?
Thanks so much
PostPosted: January 5th, 2019, 16:24
Thanks so much
I think that if you do update the box firmware to the latest version you will be "stuck" with the latest version of the software as well. If you do want to use old version of software do not update the box firmware and on that case you will not be able to use the newer software ... Guess that you can't have them all ....
Users browsing this forum: No registered users and 0 guests
