Post new topic Reply to topic  [ 72 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: ATA enhanced secure erase takes long time to complete
PostPosted: December 27th, 2018, 9:15
This is a 160 GB rotational drive. Non-enhanced secure erase took about an hour and a half to complete. Enhanced secure erase is taking hours (more than a day) to complete, even though, the estimated completion time is 54 minutes (for both enhanced and non-enhanced erasure). Is this fine or should I be concerned?
 Post subject: Re: ATA enhanced secure erase takes long time to complete
PostPosted: December 27th, 2018, 10:31
Enhanced will do a multiple pass erase and will also include remapped bad sectors. If there are a lot of remapped sectors on the drive, it seem plausible that it could take a long time to complete.
RAID Data Recovery
PostPosted: December 27th, 2018, 11:21
Yeah, it does have a lot of bad sectors, higher than 12000. It's a long story, 3 HDDs of mine suddenly "bricked" while I was using Phoenix OS (one of them apparently survived, an external HDD). It looks like this OS somehow corrupts HDDs' firmware, I say that because CrystalDiskInfo shows this disk's health status as 'Unknown' and I remember it used to show as 'Caution' (the drive had about 56 sectors remapped). The first drive which this OS "bricked" had NONE remapped sectors and suddenly a bunch of sectors got remapped. Some weird thing I noticed aswell is that I have used testdisk app to check for filesystems which was erased, it found a BSD filesystem with 2 TB of storage, the disk's original size is 160 GB
File comment: This is what GSmartControl shows,
realize there are 'cloned' attributes there. Don't mind the high raw values, GSmartControl doesn't shows them properly; CrystalDiskInfo does
PostPosted: December 27th, 2018, 12:45
The OS is unlikely to have corrupted the drive's firmware. Running a drive that is failing is likely what caused firmware damage. That is, the firmware is stored on the platters and is just as vulnerable to bad sectors as the rest of the drive. When the health status of a drive is showing caution, that is a good time to backup the data and replace the drive and put it to pasture.
RAID Data Recovery
PostPosted: December 27th, 2018, 13:35
Sorry, I haven't informed properly. The external HDD actually was plugged in a laptop (which has none remapped sectors), it was running Phoenix OS aswell. The illness it got was literally the same from these other 2 HDDs, but somehow it survived and still works flawlessly. I never used this external HDD on my desktop computer. And if I recall correctly, this issue happened on kernel version 4.9, I always used to change to the version 4.4 since it was more stable
PostPosted: December 27th, 2018, 14:17
I read somewhere that by running enhanced secure erase, as it overwrites bad sectors it can actually recover them (if it's not badly damaged) and reset the G-List. Hence why I ran it on this drive. Is this true though?
PostPosted: February 13th, 2019, 13:44
So, I ended up putting the drive in the freezer four times or so, that didn't solve the issue. But then I thought about using a magnet and it worked! I have no idea why but after magnetizing the drive there are no more read failures. Though, I still think there is something botched in the drive's firmware, S.M.A.R.T. data's attributes got randomized a couple of times after freezing the drive. This is not new though, it used to get randomized very few times even before I froze the drive. But stopped after using a magnet
PostPosted: February 14th, 2019, 6:18
and you are going to use this drive? wow.
PostPosted: February 14th, 2019, 9:54
Great, you got the drive running.
Now, do you want a DR lab to help you get the data soon, right?
http://www.pclab.com.pt facebook.com/PCLAB.Assistencia.Tecnica
ACELab partner
PostPosted: February 17th, 2019, 16:21
Is this a joke ?
Goes without saying using a "magnet" would have destroyed servo and the drive wouldn't work anymore ....
Aslo the OS wouldn't kill the firmware neither the drive. Maybe a bad quality power supply ?
PostPosted: February 19th, 2019, 11:08
No, that wasn't a joke. And I don't really care about data. I don't think the drive died at all, this issue happened after using that OS called Phoenix OS (version 1.5.0, 32 bits) which somehow botched 2 drives of mine. One of those drives had NONE reallocated sectors, no S.M.A.R.T. attributes showing errors/failures, the drive was alive and kicking. I was using the OS normally, but the 'illness' was injected after rebooting/shutting down the PC. It almost killed my father's external hard drive aswell (which would be the third drive killed). At first, I thought it was my computer but after trying it on a laptop I realized it was the OS. I used the external drive on that laptop, using the same OS version and the same thing happened like as the other 2 drives (except S.M.A.R.T. wasn't botched. Probably because it is a USB device, not an actual SATA). Anyways, I have been using the drive for a month or so and is still working properly
PostPosted: February 19th, 2019, 17:44
1 - It's impossible for a OS to brick the drive. In worst case you would need something like a malware/virus that would gain kernel access to send direct I/O to the drive and use VSCs to kill the firmware, etc .... Meaning ... There is NO WAY for the OS itself to "damage" the drive even more in the way you describe (progressive damage over time with changed S.M.A.R.T. data).
2 - If you put a magnet on the top of the drive if you are lucky not to damage the heads you will end up damaging the platter anyway. Servo marks will be gone, heads will not find servo and drive will just click ..... The freezer and other junk that you did write will only make matter worse.
I will not comment any further just if someone is thinking of doing something like this to refurb or ressurect a drive just forget, IT WILL NOT WORK. EVER.
This is BS.
PostPosted: February 19th, 2019, 20:39
Why you say it's bullshit? I literally put the magnet (which wasn't powerful at all like those in a microwave) around the drive for 3 or 4 times (I haven't disassembled it), without exceptions. That was the only thing which 'ressurected' the drive. Also, if you don't believe the OS 'bricked' then give I try yourself on Phoenix OS 1.5.0. Use another SATA HDD with it. You don't even need to erase your current OS to use Phoenix. Btw, the drives were bricked with ext4 filesystem. But I think FAT32 would brick it aswell since the external drive was screwed by it with FAT32
PostPosted: February 20th, 2019, 16:02
Cool !!! Why to bother in buying a $10000 PC-3000 unit if Phoenix OS 1.5.0 can access the drive's firmware and brick it ? :mrgreen: :mrgreen: :mrgreen:
PostPosted: February 23rd, 2019, 8:19
obviously the magnet pulled all the bits that had fallen over upwards. Science.
The Freezer trick doesn't work on Android based OS's, that's just stupidity. Its only Apple gear... once a MAC detects it is not cool, it don't work right. Windows doesn't really care.. about anything. It doesn't need you at all really. Linux? well It isn't the year of Linux on the desktop. Yet.
who would have thought that the people that put up a site such as http://www.phoenixos.com/en_US/ and is still in chinese, would have an OS that isnt 100% stable?
The trouble with idiots is they pull you down to their level then beat you with experience.
I am just verifying if Phoenix OS v1.5.0 (even though it is up to over v3) will brick my drive... no doesnt seem....
Kzshhhh Kzshhhhh Kzshhhh Kzshhhhh
PostPosted: February 23rd, 2019, 16:50
100% BS!
PostPosted: February 23rd, 2019, 19:19
hello, im new in this forum and i was curious about this topic… well, i had an old conserved drive here with 80 gb of storage and decided to give a try on this… my drive also bricked after using phoenix. bios takes 10 seconds to recognize drives but ends up not recognizing this one anymore… i also thought the guy was saying bs but i have to confirm it does bricks drives since it bricked mine… i will later try to use a magnet to check if the drives gets alive again…
PostPosted: March 1st, 2019, 12:51
Krush206,
hello Krush,, i no able to download HDTA2 version 2018,, website .com is offline ..
can you do post to me for googledrive?
:wink: :wink:
PostPosted: March 2nd, 2019, 12:26
Nvidea wrote:
Krush206,
:wink: :wink:
Here
PostPosted: March 3rd, 2019, 12:37
Thanks much,,
from Prosoft MediaTools Wipe 1.2 Build 130626 you know where find Keygen?
Users browsing this forum: MSN [Bot], saltwater, Tomset and 33 guests
