 Post subject: Head swap maxtor diamondmax plus 9 80 GB PATA
PostPosted: October 10th, 2018, 15:31
hi guys, today I entered a new case of this disk that emits noises inside, from noise and clicks I think to the head. The disk has the following data plate: code: yar41bw0 n, m, c, d
s.n y325yj0e
6y080l0032013
made in singapore 12 aug 2003
Is it possible to get advice on how to identify a head donor?
I had found this product in September 2003 according to you it is possible to use the heads?
 Post subject: Re: Head swap maxtor diamondmax plus 9 80 GB PATA
PostPosted: October 11th, 2018, 4:17
Hi!
Do you have more information about your donor?
PostPosted: October 11th, 2018, 9:45
the donor it's in photo , I have found on ebay
PostPosted: October 11th, 2018, 14:13
Does it produce head clicking sounds or a kind of melody?
Faulty head sound:
https://www.youtube.com/watch?v=pavE77Yussk
Voice coil melody:
https://www.youtube.com/watch?v=JCmLdi3_16I
PostPosted: October 11th, 2018, 14:34
MAXTOR Hard Drive Match Criteria (for Head Stack Assembly replacement) :
1. Full Model Number. Example: 6H500F0, 4R160L00420P1, 2F040L0
2. Code. Example: RAMB1TU0, VAM51JJ0
3. Four characters (sometimes three). Example: N,F,G,D / N,M,B,B
http://hddguru.com/articles/2006.02.17- ... k-Q-and-A/
Maxtor (all families)
Firmware + Country + Third character in alphabetic code type X, X, X, X should match
PostPosted: October 11th, 2018, 14:36
I would say your donnor will NOT work ...
PostPosted: October 11th, 2018, 14:50
You got info on your other post...reading involved.
viewtopic.php?f=1&t=37390&hilit=swap+heads+on+maxtor
http://www.rescue-it.se
PostPosted: October 12th, 2018, 1:26
Faulty head sound:
Voice coil melody:
No melody, click
PostPosted: October 12th, 2018, 1:46
The real problem is finding an identical unit, I tried on ebay looking at over 200 units image after image. I found only units with 6y08l04 and not 003 it almost seems that Maxtor has only built this one that I have LOL, how do you do in these cases? Do you pray to the god of hard disks? : -}
PostPosted: October 12th, 2018, 4:17
guys after so much research I found this hdd, does not have all the same parameters but the model is very similar, according to you can be good? thank you.
Difference : patient have code YAR41BW0 code on donor yar41vw0
letters on patient : nmcd letters on donor : kmcd
sn on patient : y325tjoe sn on donor : y31rvxae
model patient : 6y080l0032013 made in singapore a2 model donor 6y080l0030403 made in singapore c51
PostPosted: October 12th, 2018, 15:03
Most likely it will not work as well but if you can't find any other donor i guess you can try it out ....
PostPosted: January 7th, 2019, 23:28
Hi Magnetepazzoo, was your head swap on Maxtor succsessful? I am up for platter-move (stuck rotor) on similar 160gb drive (was sitting for 10 years) and was looking for tips.
PostPosted: January 8th, 2019, 15:37
What is the full model of your drive ? Can you post a picture of the label ?
Did you open the drive already ? Did you open it inside a HEPA 100 aseptic room ?
Are you sure the problem is spindle related ?
PostPosted: January 8th, 2019, 20:07
I've done open surgery before, but on single-platter 2.5" IBM drive, not on multi-platter/Maxtor, hence question on any pointers on this drive.
Code: YAR41BW0 N,M,C,D
SN: Y41FQ98E
6Y160P0041201
Yes, I opened it to inspect, and though not in cert. clean room.
I have exact donor (actually 2).
Thanks!
PostPosted: January 9th, 2019, 1:23
Platter by platter move will not work. You have to unstuck rotor or remove all platters with spindle assembled and put it to donor. It is only possible way as I remember.
PostPosted: January 9th, 2019, 4:41
Have had varying levels of success with unsticking motor by force, but it’s worth a shot IMHO.
PostPosted: January 10th, 2019, 5:31
there is a way how to do it platter by platter but you need to know some tricks how to do it. I am not sure if those tricks were in public.
PostPosted: January 10th, 2019, 9:35
(Maxtor 6Y160P0041201 with stuck motor)
I was going to use platter-stack compression removal. Rather than buying, can someone borrow/lease compression tool?
Users browsing this forum: Google Adsense [Bot] and 15 guests
