 Post subject: Samsung HD204UI spins up, then down.
PostPosted: January 10th, 2019, 13:22
Hi!
I have the above mentioned 2TB HDD which spins up, but at a higher pitched sound then normal.
It sounds like it it releases the actuator to position read heads, but just stops and makes a slightly vibrating sound until the drive spins slowly back down.
Is this something anyone has any experience with?
I am really wondering if it might be a physical problem with the mechanics, the PCB or if it is a firmware problem.
Any help is appreciated, thank you!
 Post subject: Re: Samsung HD204UI spins up, then down.
PostPosted: January 10th, 2019, 13:32
Only a guess.
Maybe spindle motor problem
A Recovery Service In Turkey . Veri Kurtarma Türkiye https://www.digitalverikurtarma.com
Donor Drives hdddonormarket.com
PostPosted: January 10th, 2019, 16:09
What about connecting the drive to TTL and check the log ?
Users browsing this forum: Majestic-12 [Bot] and 38 guests
