 Post subject: WD20EZRX-00DC0B0 recover?
PostPosted: January 9th, 2019, 9:02
Hi all!!
Any possibility to fix this SATA 2TB WD HDD?
It sounds and spins good but device is not correctly recognized by windows.
Disk manager shows an uninitialized unknown disk of 1342117728,00 GB of capacity.
Also through CRC errors when tried to initialize from windows disk manager. Any other tool used do not detect it.
Could I fix by myself the right capacity o reflash the firmware?
Thanks a lot in advance!!
 Post subject: Re: WD20EZRX-00DC0B0 recover?
PostPosted: January 9th, 2019, 15:51
Sorry ...
If you do need the data out of the drive you will need to consult with a specialized data recovery firm (and NOT a regular computer repair shop).
If you don't want to pay a huge sum of $$$$ you can try something like this : - https://www.ebay.com/itm/Western-Digita ... 2696046071
But ... IF the drive does have bad head(s) or pre-amp this will NOT HELP.
Also HDD is not like cellphone, you can't simply "flash" firmware to "fix it".
viewtopic.php?f=16&t=12671
viewtopic.php?f=16&t=6562
PostPosted: January 10th, 2019, 5:21
Thank you @Spildit for your quick response.
I've tried to exchange the drive controller board so I have 2 identical units but with same results. It seems board is good.
I attatch a pic of disk manager showing wrong capacity detected.
PostPosted: January 10th, 2019, 8:16
And this is how it shows from MacOS disk utility.
144 PetaBytes and won't initalize anyway.
Thanks!!
PostPosted: January 10th, 2019, 16:08
Agree ... not a PCB problem. Consult with a data recovery firm ...
PostPosted: January 11th, 2019, 3:16
Data recovery firm?
What do you mean?
I've tried TESTDISK setting right C/H/S values and write new MBR and boot sector but it raises error. Also did not find any partition on it.
C/H/S setting was: 243201/255/63 with sector of 512bytes
Thanks a lot!
PostPosted: January 12th, 2019, 7:58
How is it detected in BIOS?
Correct capacity?
PostPosted: January 12th, 2019, 14:12
if your file system is MAC native (HFS, HFS+, etc...) and
If you keep playing with testdisk you can start saying goodbye to your directory tree.....
Teskdisk is not a bad tool, but believe me, in this case will not help you anything and can complicate data recovery (if not already done ...)
Where does the disk come from?? is it an internal disk or a "my book" enclosure?
PostPosted: January 12th, 2019, 14:18
No problem. HDD does not contain important data.
It cames from a WD myBook Studio II raid 1 enclosure. It is the A disk.
Thanks!
PostPosted: January 12th, 2019, 14:33
Here was the answer to your questions.
Now... Well, if you don't need the data, initializing and creating a new volume, you may recover the disk....
PostPosted: January 12th, 2019, 15:18
Noooo SD RAID software mark it as defective and it is wrong-recognized attached directly to SATA cable or through USB box to Win or Mac system.
System detects a 144 PetaBytes disk. ????
I'am considering a broken head or other hw issue.
Thanks!!
PostPosted: January 12th, 2019, 17:48
Drive have firmware issues to say the least. Most likely will have bad sectors as well.
By a data recovery firm i do mean specialized houses/business that do data recovery and have stuff like PC-3000 and HEPA 100 aseptic room.
If the drive was in RAID 1 array (mirror) just recover the data from the other drive as it should be an exact clone of the failed one.
If you are willing to pay to get your data back you will need to seek help from a pro (not free). Otherwise say goodbye to the data unless you can recover it from backups or from the other "mirror" drive.
PostPosted: January 12th, 2019, 22:18
Well, this would be expected.
Then, throw it in the trash and if you need the data, recover from the other RAID 1 disk
Users browsing this forum: Google [Bot], yychern92 and 4 guests
