Post new topic Reply to topic  [ 69 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: SAFE MODE HITACHI???
PostPosted: January 13th, 2019, 15:03
Spildit wrote:
And by the way on this PCB what points did you short ?
If I lift the PCB or cut the reading channel, the HDD does not read the F copy and I can not restore copies 0 and 1
PostPosted: January 13th, 2019, 15:10
With your modded NVRam i can't restore copy 0 as well. It restores the modules on another / wrong place. Did you restore by writing modules ? If so did you patch something on RAM to restore the original NVRAM ?
PostPosted: January 13th, 2019, 15:13
Do you want to connect and we make an example?
PostPosted: January 13th, 2019, 15:16
Yes !!!!
Send me in TV details
PostPosted: January 13th, 2019, 15:39
jajajaja !
Now drive is broken .... Same as mine ...
Let me know if you do manage to figure out how to revive it !
PostPosted: January 13th, 2019, 15:57
After starting the HDD you have to do an SA STRUCT TEST, and after giving an error in all the modules, you will write the modules and write them.
PostPosted: January 13th, 2019, 16:07
Did it work ?
PostPosted: January 13th, 2019, 16:15
If I have it working. The only thing that takes a second more than leaving BSY.
PostPosted: January 13th, 2019, 18:25
Ok ... I will test that .... You say to test SA first with region blocked on NVRam ?
PostPosted: January 13th, 2019, 18:36
If after changing the values of the SA entries in the NVRAM, the SA test is performed and if the RSVDs give OK and the others all errors, the modules can be recorded.
PostPosted: January 13th, 2019, 19:07
Are you changing back the NVRam to original code or you do that only when you finish to record the modules back ?
PostPosted: January 13th, 2019, 19:08
Did you recover the drive that we did damage some moments ago ?
PostPosted: January 13th, 2019, 19:20
Yes, I have recovered the HDD.
I have to broach the access to the copies of SA modifying the NVRAM before doing the test.
I modify NVRAM.
I turn on the HDD and enter RDY.
I charge the LDR.
I do the SA test. (If it gives OK in the RSVD, it is a good signal).
I write the modules.
a greeting
PostPosted: January 13th, 2019, 20:41
RRRssssss
It's writing to the NEW address and not to the old .....
But wait ....
This is quite stupid .... If i can write to a new track/SAT place to start with even without code there ....
I will try to load from safe mode with PCB lifted (i relieve 2 screws near the head connector and drive don't read SA) then if i screw the screws they will make contact and drive will be exactly like it is with changed regions but ... with correct regions ....
Then i should be able to WRITE to SA ....
Let me try.
PostPosted: January 13th, 2019, 20:56
What read points do you short on the 5432xxxx9A PCB ?
PostPosted: January 14th, 2019, 3:05
Once the NVRAM is changed you do not have to lift the PCB at all or the HDD will not read the copy F. If you want later in the evening, in our schedule we can make another TV, if it is not any inconvenience for you.
I find a problem after this and that is that the MRTLAB is not able to read the F copy after recovering the HDD, but if it is to rewrite and then read.
PostPosted: January 14th, 2019, 14:43
I know that !!!
The "problem" is that your MRT somehow either send a correct NVRam to RAM or account for the shift on the firmware. With SeDiv if i change the regions and then if i WRITE modules back I CAN WRITE but they are written to WRONG LOCATION so if i change regions back to original drive still clicks and if i change regions back to patched value modules that i did write are still there !!! Writing with SeDiv with patched NVRam doesn't write copy 0 to original copy 0 location of modules, it does write to another place/track on SA !!!
PostPosted: January 14th, 2019, 14:44
So either i do short the PCB and write the modules with native NVRam loaded or i can try to account for the changes with vendor specific commands ... or i can try to see what is going on on RAM with HRT....
PostPosted: January 14th, 2019, 15:31
Where can I get HRT?
PostPosted: January 14th, 2019, 16:14
You can't. No longer on sale and no longer updated since many years now. Used units are close to impossible to buy as well ....
:D
Please tell me what points did you short on the PCB to prevent reading. I want to try that.
Users browsing this forum: Google [Bot], Google Adsense [Bot], StockEdde and 43 guests
