 Post subject: NAND Flash Reader with BGA272 BGA316 adapter
PostPosted: April 10th, 2017, 21:47
NAND Flash Reader with BGA272 BGA316 BGA224(8bit/16bit) adapter , support 4CE and 8CE chips, only used Flash Extractor,All tested ok, If you are interested please contact with SKYPE:13378120549 (49335007@qq.com) , JAKC LEE.
 Post subject: Re: NAND Flash Reader with BGA272 BGA316 adapter
PostPosted: April 10th, 2017, 22:04
BGA272 8BANK Testing.
PostPosted: April 10th, 2017, 22:35
BGA272 8CE ECC TEST OK.
PostPosted: April 10th, 2017, 22:57
BGA224 8bit Testing.
PostPosted: April 10th, 2017, 22:58
BGA224 8bit Tested ECC OK.
PostPosted: April 11th, 2017, 1:03
BGA316 4CE Testing.
PostPosted: April 11th, 2017, 1:07
BGA316 Tested OK
PostPosted: April 13th, 2017, 23:57
Hi Lee ,
I Wanted To Know If You Sell The Actual Flash Extractor Reader Also .I Am Interested To Buy That With the Following Adapters .
1 : Basic TSOP48 Adapter X 1 Unit
2 : TLGA Adapter 18x14mm X 1 Unit
3 : BGA 152 18x14mm X 1 Unit
4 : Monolith Adapter X 10 Units
PS : I Also See You Have Few Other Adapters ,I Would Not Mind Getting These Cost Also
PostPosted: April 14th, 2017, 22:55
Sorry we do not your adapter.
Amarbir[CDR-Labs] wrote:
Hi Lee ,
PostPosted: May 13th, 2017, 6:34
Well done,Mr.LEE.
May I know how much your socket sell? :D
PostPosted: April 18th, 2018, 0:06
UP!!UP!!UP!!
PostPosted: April 18th, 2018, 3:24
Anyone actually tested and tried those?
PostPosted: May 18th, 2018, 12:03
I don't know very much about this - and I get that this could be a completely absurd question; but is it not possible to do this with IP Box2 ? It'll read a chip, data dump, etc - from NAND. Isn't it going to the the SW that re-integrates it?
The cost about $200... I just assumed you'd need the PC 3000, too.
https://www.ebay.com/i/162812694908?chn ... 1852557203
PostPosted: January 19th, 2019, 5:00
UP !! UP!UP!
PostPosted: January 19th, 2019, 17:39
einstein9, tested. Works :)
Odzyskiwanie danych
PostPosted: January 20th, 2019, 2:32
Yup, perfect set added, :druunk:
Users browsing this forum: Google [Bot] and 17 guests
