 Post subject: seagate st500lt012 strange case, Head issue ?
PostPosted: February 11th, 2019, 7:51
Hi guys, I have this strange situation with this drive. When power it on the disk spin normally and go online, no click. Whit MRT I can see serial number, model, sysfile ext. I have backupped all resourced no problem but whe i try to open partition the disk can't read, When I try to scan surface a see only red sector, When i try to use separate copy I see only black sector with head 0 and 1. Suggestion ? Thanks
 Post subject: Re: seagate st500lt012 strange case, Head issue ?
PostPosted: February 11th, 2019, 10:22
What's it showing in the terminal when you first try to read a sector? Also, is it staying BSY after you try reading a sector?
PostPosted: February 11th, 2019, 10:36
Thanks for reply, this is the terminal log :
F3 T>
Set Transfer Mode selected
Ultra DMA selected
ProcessRWError -Read- at LBA 00000000 Sense Code=40000087
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
SP is invalid
InitiateMarkPendingReallocateRequest for disc_lba: 00000000!
Unrecoverable Error CB
ProcessRWError -Read- at LBA 00000020 Sense Code=40000087
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
SP is invalid
InitiateMarkPendingReallocateRequest for disc_lba: 00000020!
ProcessRWError -Read- at LBA 00000040 Sense Code=40000087
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
SP is invalid
InitiateMarkPendingReallocateRequest for disc_lba: 00000040!
ProcessRWError -Read- at LBA 00000060 Sense Code=40000087
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
SP is invalid
InitiateMarkPendingReallocateRequest for disc_lba: 00000060!
ProcessRWError -Read- at LBA 00000080 Sense Code=40000087
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
SP is invalid
InitiateMarkPendingReallocateRequest for disc_lba: 00000080!
ProcessRWError -Read- at LBA 000000A0 Sense Code=40000087
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
SP is invalid
InitiateMarkPendingReallocateRequest for disc_lba: 000000A0!
ProcessRWError -Read- at LBA 000000C0 Sense Code=40000087
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
SP is invalid
InitiateMarkPendingReallocateRequest for disc_lba: 000000C0!
Starting LBA of RW Request=000000E0 Length=FFFFFFFF
ProcessRWError -Read- at LBA 000000E0 Sense Code=C4090082 EDACBlkAddr 0000000000000166
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
tbg_n:0x0055
tbg_r:0x0043
RAP tbg_n:0x009A
RAP tbg_r:0x0053
RAP RegTBGN0x009A
RAP RegTBG0xA60E
TBA0x0000641A
Update Channel
SP is invalid
InitiateMarkPendingReallocateRequest for disc_lba: 000000E0!
PostPosted: February 13th, 2019, 9:06
My bet it is a translation issue.
PostPosted: February 13th, 2019, 9:16
I'm in standby to receive a dono to swap head. I have try more time to clear smart and rebuild translator
PostPosted: February 13th, 2019, 9:35
Have you tried reinitialize Media Cache?
F3 T>/C
F3 C>U1
F3 C>U2
F3 C>U3
.....and i hope you backed up all important sys files before you did anything
PostPosted: February 13th, 2019, 10:06
Yes buckup first everytime
PostPosted: February 13th, 2019, 12:11
F3 T>/C
F3 C>U1
F3 C>U2
F3 C>U3
F3 C>U1
Invalid Diag Cmd
PostPosted: February 15th, 2019, 3:21
I would look first at how many heads the HDD has.
Then make a copy of the system files and if you can read the copy 0 and 1, in principle those heads are fine.
If it does not make you strange noises I would wait before opening the HDD.
If you receive the donor you can try changing the PCB before. It is rare that it is that but it is very easy to do and you discard some other problem.
I suspect that the HDD area is damaged.
It's just an opinion of what I would do. Greetings.
PostPosted: February 15th, 2019, 4:03
I think heads are OK. Some FW problem.
PostPosted: February 15th, 2019, 5:57
thanks to all for the answers, according to my client this hdd started to become slow, after a few hours he noticed this problem the hdd was virtually unusable. When I was delivered, I backed up the ROM and the firmware without problems, I then opened DE and saw the partitions but when I tried to read the contents the disk was reading error, so slowly even stopped seeing the partition. If it were a damaged area of the disk during the scan I would notice some green, some yellow and some red, here it's all red, it does not read at all. That's why I thought of the heads, but of course it is my hypothesis and for this reason I asked for your help, it seems a strange case.
PostPosted: February 15th, 2019, 7:30
I think you have a case very similar to the one I opened. I did not have access to the user area either.
You can see the last comment I have made, it may help you.
PostPosted: February 15th, 2019, 10:10
Try to patch sysfile 93 ?
PostPosted: February 15th, 2019, 10:12
Agree ---
Update Channel
SP is invalid
PostPosted: February 15th, 2019, 10:13
I would do the "normal" patching AFTER BACK UP ALL SYSFILES, ETC ... Then i would clear MC manualy, try to restore DOS table, patch 93 sysfile to disable all un-necessary stuff and if it still doesn't work try to regen translator.
PostPosted: February 15th, 2019, 15:01
I have backup again the sysfile when copy some sysfile i see an error, this is the log :
Save to Folder: C:\UserDataFile\Seagate F3 Arch\Yarrar_5400-75\ST500LT012-1DG142-1002YAM1-W3P2YN0X\Data\SysFile\
Sys file volume0, FID:0, Copy:1 : ...................:Err
Sys file volume3, FID:1, Copy:0 : ...................:OK
Sys file volume3, FID:1, Copy:1 : ...................:OK
Sys file volume3, FID:19, Copy:0 : ..................:OK
Sys file volume3, FID:19, Copy:1 : ..................:OK
Sys file volume3, FID:1A, Copy:1 : ..................:OK
Sys file volume3, FID:1A, Copy:0 : ..................:OK
Sys file volume3, FID:1B, Copy:1 : ..................:OK
Sys file volume3, FID:1B, Copy:0 : ..................:OK
Sys file volume3, FID:1C, Copy:0 : ..................:OK
Sys file volume3, FID:1C, Copy:1 : ..................:OK
Sys file volume3, FID:1D, Copy:0 : ..................:OK
Sys file volume3, FID:1D, Copy:1 : ..................:OK
Sys file volume3, FID:1E, Copy:0 : ..................:OK
Sys file volume3, FID:1E, Copy:1 : ..................:OK
Sys file volume3, FID:1F, Copy:1 : ..................:OK
Sys file volume3, FID:1F, Copy:0 : ..................:OK
Sys file volume3, FID:20, Copy:1 : ..................:OK
Sys file volume3, FID:20, Copy:0 : ..................:OK
Sys file volume3, FID:28, Copy:0 : ..................:OK
Sys file volume3, FID:28, Copy:1 : ..................:OK
Sys file volume3, FID:29, Copy:0 : ..................:OK
Sys file volume3, FID:29, Copy:1 : ..................:OK
Sys file volume3, FID:35, Copy:0 : ..................:OK
Sys file volume3, FID:35, Copy:1 : ..................:OK
Sys file volume3, FID:36, Copy:0 : ..................:OK
Sys file volume3, FID:36, Copy:1 : ..................:OK
Sys file volume3, FID:37, Copy:0 : ..................:OK
Sys file volume3, FID:37, Copy:1 : ..................:OK
Sys file volume3, FID:3F, Copy:0 : ..................:OK
Sys file volume3, FID:3F, Copy:1 : ..................:OK
Sys file volume3, FID:52, Copy:0 : ..................:OK
Sys file volume3, FID:52, Copy:1 : ..................:OK
Sys file volume3, FID:65, Copy:0 : ..................:OK
Sys file volume3, FID:65, Copy:1 : ..................:OK
Sys file volume3, FID:66, Copy:0 : ..................:OK
Sys file volume3, FID:66, Copy:1 : ..................:OK
Sys file volume3, FID:93, Copy:0 : ..................:OK
Sys file volume3, FID:93, Copy:1 : ..................:OK
Sys file volume3, FID:BC, Copy:0 : ..................:OK
Sys file volume3, FID:BC, Copy:1 : ..................:OK
Sys file volume3, FID:BF, Copy:0 : ..................:OK
Sys file volume3, FID:BF, Copy:1 : ..................:OK
Sys file volume3, FID:C0, Copy:0 : ..................:OK
Sys file volume3, FID:C0, Copy:1 : ..................:OK
Sys file volume3, FID:100, Copy:0 : .................:OK
Sys file volume3, FID:100, Copy:1 : .................:OK
Sys file volume3, FID:101, Copy:0 : .................:OK
Sys file volume3, FID:101, Copy:1 : .................:OK
Sys file volume3, FID:102, Copy:0 : .................:Err
Sys file volume3, FID:102, Copy:1 : .................:Err
Sys file volume3, FID:103, Copy:1 : .................:OK
Sys file volume3, FID:103, Copy:0 : .................:OK
Sys file volume3, FID:104, Copy:1 : .................:OK
Sys file volume3, FID:104, Copy:0 : .................:OK
Sys file volume3, FID:105, Copy:0 : .................:OK
Sys file volume3, FID:105, Copy:1 : .................:OK
Sys file volume3, FID:106, Copy:1 : .................:OK
Sys file volume3, FID:106, Copy:0 : .................:OK
Sys file volume3, FID:107, Copy:0 : .................:OK
Sys file volume3, FID:107, Copy:1 : .................:OK
Sys file volume3, FID:108, Copy:1 : .................:OK
Sys file volume3, FID:108, Copy:0 : .................:OK
Sys file volume3, FID:109, Copy:0 : .................:OK
Sys file volume3, FID:109, Copy:1 : .................:OK
Sys file volume3, FID:10A, Copy:0 : .................:OK
Sys file volume3, FID:10A, Copy:1 : .................:OK
Sys file volume3, FID:10B, Copy:0 : .................:OK
Sys file volume3, FID:10B, Copy:1 : .................:OK
Sys file volume3, FID:10C, Copy:0 : .................:OK
Sys file volume3, FID:10C, Copy:1 : .................:OK
Sys file volume3, FID:10D, Copy:0 : .................:OK
Sys file volume3, FID:10D, Copy:1 : .................:OK
Sys file volume3, FID:10E, Copy:1 : .................:OK
Sys file volume3, FID:10E, Copy:0 : .................:OK
Sys file volume3, FID:10F, Copy:0 : .................:OK
Sys file volume3, FID:10F, Copy:1 : .................:OK
Sys file volume3, FID:110, Copy:0 : .................:OK
Sys file volume3, FID:110, Copy:1 : .................:OK
Sys file volume3, FID:115, Copy:1 : .................:OK
Sys file volume3, FID:115, Copy:0 : .................:OK
Sys file volume3, FID:116, Copy:1 : .................:OK
Sys file volume3, FID:116, Copy:0 : .................:OK
Sys file volume3, FID:131, Copy:1 : .................:OK
Sys file volume3, FID:131, Copy:0 : .................:OK
Sys file volume3, FID:132, Copy:1 : .................:OK
Sys file volume3, FID:132, Copy:0 : .................:OK
Sys file volume3, FID:133, Copy:0 : .................:OK
Sys file volume3, FID:133, Copy:1 : .................:OK
Sys file volume3, FID:134, Copy:0 : .................:OK
Sys file volume3, FID:134, Copy:1 : .................:OK
Sys file volume3, FID:135, Copy:0 : .................:OK
Sys file volume3, FID:135, Copy:1 : .................:OK
Sys file volume3, FID:136, Copy:0 : .................:OK
Sys file volume3, FID:136, Copy:1 : .................:OK
Sys file volume3, FID:137, Copy:1 : .................:OK
Sys file volume3, FID:137, Copy:0 : .................:OK
Sys file volume3, FID:138, Copy:0 : .................:OK
Sys file volume3, FID:138, Copy:1 : .................:OK
Sys file volume3, FID:139, Copy:0 : .................:OK
Sys file volume3, FID:139, Copy:1 : .................:OK
Sys file volume3, FID:13A, Copy:0 : .................:OK
Sys file volume3, FID:13A, Copy:1 : .................:OK
Sys file volume3, FID:13B, Copy:0 : .................:OK
Sys file volume3, FID:13B, Copy:1 : .................:OK
Sys file volume3, FID:13C, Copy:0 : .................:OK
Sys file volume3, FID:13C, Copy:1 : .................:OK
Sys file volume3, FID:13D, Copy:0 : .................:OK
Sys file volume3, FID:13D, Copy:1 : .................:OK
Sys file volume3, FID:13E, Copy:1 : .................:OK
Sys file volume3, FID:13E, Copy:0 : .................:OK
Sys file volume3, FID:13F, Copy:0 : .................:OK
Sys file volume3, FID:13F, Copy:1 : .................:OK
Sys file volume3, FID:140, Copy:0 : .................:OK
Sys file volume3, FID:140, Copy:1 : .................:OK
Sys file volume3, FID:141, Copy:1 : .................:OK
Sys file volume3, FID:141, Copy:0 : .................:OK
Sys file volume3, FID:143, Copy:0 : .................:OK
Sys file volume3, FID:143, Copy:1 : .................:OK
Sys file volume3, FID:144, Copy:0 : .................:OK
Sys file volume3, FID:144, Copy:1 : .................:OK
Sys file volume3, FID:14E, Copy:1 : .................:OK
Sys file volume3, FID:14E, Copy:0 : .................:OK
Sys file volume3, FID:14F, Copy:0 : .................:OK
Sys file volume3, FID:150, Copy:0 : .................:OK
Sys file volume3, FID:151, Copy:0 : .................:OK
Sys file volume3, FID:152, Copy:0 : .................:OK
Sys file volume3, FID:153, Copy:0 : .................:OK
Sys file volume3, FID:154, Copy:0 : .................:OK
Sys file volume3, FID:155, Copy:0 : .................:OK
Sys file volume3, FID:156, Copy:0 : .................:OK
Sys file volume3, FID:157, Copy:0 : .................:OK
Sys file volume3, FID:158, Copy:0 : .................:OK
Sys file volume3, FID:159, Copy:0 : .................:OK
Sys file volume3, FID:15A, Copy:0 : .................:OK
Sys file volume3, FID:15B, Copy:0 : .................:OK
Sys file volume3, FID:15C, Copy:0 : .................:OK
Sys file volume3, FID:15D, Copy:0 : .................:OK
Sys file volume3, FID:15E, Copy:0 : .................:OK
Sys file volume3, FID:15F, Copy:0 : .................:OK
Sys file volume3, FID:160, Copy:0 : .................:OK
Sys file volume3, FID:161, Copy:0 : .................:OK
Sys file volume3, FID:162, Copy:0 : .................:OK
Sys file volume3, FID:163, Copy:0 : .................:OK
Sys file volume3, FID:164, Copy:0 : .................:OK
Sys file volume3, FID:165, Copy:0 : .................:OK
Sys file volume3, FID:166, Copy:0 : .................:OK
Sys file volume3, FID:167, Copy:0 : .................:OK
Sys file volume3, FID:168, Copy:0 : .................:OK
Sys file volume3, FID:169, Copy:0 : .................:OK
Sys file volume3, FID:16A, Copy:0 : .................:OK
Sys file volume3, FID:16B, Copy:0 : .................:OK
Sys file volume3, FID:16C, Copy:0 : .................:OK
Sys file volume3, FID:16D, Copy:1 : .................:OK
Sys file volume3, FID:16D, Copy:0 : .................:OK
Sys file volume3, FID:16E, Copy:1 : .................:OK
Sys file volume3, FID:16E, Copy:0 : .................:OK
Sys file volume3, FID:171, Copy:0 : .................:OK
Sys file volume3, FID:171, Copy:1 : .................:OK
Sys file volume3, FID:177, Copy:0 : .................:OK
Sys file volume3, FID:177, Copy:1 : .................:OK
Sys file volume3, FID:178, Copy:0 : .................:OK
Sys file volume3, FID:178, Copy:1 : .................:OK
Sys file volume3, FID:17D, Copy:0 : .................:OK
Sys file volume3, FID:17D, Copy:1 : .................:OK
Sys file volume3, FID:180, Copy:0 : .................:Err
Sys file volume3, FID:180, Copy:1 : .................:OK
Sys file volume3, FID:181, Copy:0 : .................:OK
Sys file volume3, FID:182, Copy:0 : .................:OK
Sys file volume3, FID:183, Copy:0 : .................:OK
Sys file volume3, FID:184, Copy:0 : .................:OK
Sys file volume3, FID:195, Copy:1 : .................:OK
Sys file volume3, FID:195, Copy:0 : .................:OK
Sys file volume3, FID:1D0, Copy:0 : .................:OK
Sys file volume3, FID:1D0, Copy:1 : .................:OK
Sys file volume3, FID:1D1, Copy:0 : .................:OK
Sys file volume3, FID:1D1, Copy:1 : .................:OK
Sys file volume3, FID:1D2, Copy:0 : .................:OK
Sys file volume3, FID:1D2, Copy:1 : .................:OK
Sys file volume3, FID:1D3, Copy:1 : .................:OK
Sys file volume3, FID:1D3, Copy:0 : .................:OK
Sys file volume3, FID:1D4, Copy:0 : .................:OK
Sys file volume3, FID:1D4, Copy:1 : .................:OK
Sys file volume3, FID:1EB, Copy:0 : .................:OK
Sys file volume3, FID:1EB, Copy:1 : .................:OK
Sys file volume3, FID:203, Copy:1 : .................:OK
Sys file volume3, FID:203, Copy:0 : .................:OK
Sys file volume3, FID:204, Copy:0 : .................:OK
Sys file volume3, FID:204, Copy:1 : .................:OK
Sys file volume3, FID:205, Copy:0 : .................:OK
Sys file volume3, FID:205, Copy:1 : .................:OK
Sys file volume3, FID:206, Copy:1 : .................:OK
Sys file volume3, FID:206, Copy:0 : .................:OK
Sys file volume3, FID:208, Copy:0 : .................:OK
Sys file volume3, FID:208, Copy:1 : .................:OK
Sys file volume3, FID:209, Copy:0 : .................:OK
Sys file volume3, FID:209, Copy:1 : .................:OK
Sys file volume3, FID:300, Copy:1 : .................:OK
Sys file volume3, FID:300, Copy:0 : .................:OK
Sys file volume3, FID:301, Copy:1 : .................:OK
Sys file volume3, FID:301, Copy:0 : .................:OK
Sys file volume3, FID:304, Copy:0 : .................:OK
Sys file volume3, FID:304, Copy:1 : .................:OK
Sys file volume3, FID:305, Copy:1 : .................:OK
Sys file volume3, FID:305, Copy:0 : .................:OK
Sys file volume3, FID:306, Copy:0 : .................:OK
Sys file volume3, FID:306, Copy:1 : .................:OK
Sys file volume3, FID:307, Copy:1 : .................:OK
Sys file volume3, FID:307, Copy:0 : .................:OK
Sys file volume3, FID:30A, Copy:1 : .................:OK
Sys file volume3, FID:30A, Copy:0 : .................:OK
Sys file volume3, FID:30E, Copy:0 : .................:OK
Sys file volume3, FID:30E, Copy:1 : .................:OK
Sys file volume3, FID:30F, Copy:0 : .................:OK
Sys file volume3, FID:310, Copy:0 : .................:OK
Sys file volume3, FID:311, Copy:0 : .................:OK
Sys file volume3, FID:312, Copy:0 : .................:OK
Sys file volume3, FID:317, Copy:1 : .................:OK
Sys file volume3, FID:317, Copy:0 : .................:OK
Sys file volume3, FID:318, Copy:1 : .................:OK
Sys file volume3, FID:318, Copy:0 : .................:OK
Sys file volume3, FID:319, Copy:1 : .................:OK
Sys file volume3, FID:319, Copy:0 : .................:OK
Sys file volume3, FID:31A, Copy:0 : .................:OK
Sys file volume3, FID:31A, Copy:1 : .................:OK
Sys file volume3, FID:31B, Copy:0 : .................:OK
Sys file volume3, FID:31B, Copy:1 : .................:OK
Sys file volume3, FID:351, Copy:0 : .................:OK
Saving sys file object completed!
cron
