 Post subject: donor for seagate hdd
PostPosted: March 4th, 2019, 9:03
Hi guys I need a donor for this hdd 1TB barracuda 2.5" model st1000lm048 fw sdm1 site TK dom 11 may 2018 serial zdea0gzd part number 2e7172-500 thanks
 Post subject: Re: donor for seagate hdd
PostPosted: March 4th, 2019, 12:05
Nice :) good for you.
Is there a question or you just want to tell everybody that you need a donor?
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: March 4th, 2019, 12:28
it's a request
PostPosted: March 7th, 2019, 20:32
Hello Magnetepazzo, so you want us to give you drives with same parameters?
compatibility has nothing to do with these.
Some 1T rosewoods come with 2 platters, some with 1, i don't think that's noted in these numbers.
i usually just use what i come across at the moment, provided it fits mechanically.
then come some tricks to get the best out of the drive.
If you are unfamiliar with this family i recommend sending it to someone knowledgeable in the field.
Ebay is your friend when it comes to donors btw. But it is easy to screw these up with a single poweron after a head change.
No bitcoin donations :)
Users browsing this forum: Google [Bot] and 60 guests
