Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: New Mrt User, please guide me How to Connect Wd Hard Dis
PostPosted: April 18th, 2019, 14:20
MANY THANKS !!!!
PostPosted: April 18th, 2019, 17:26
If this "BSY problem" persists, the following modification should make things easier:
PostPosted: April 18th, 2019, 18:03
Thanks for your input.
I do understand the logic behind your suggestion and would like to try it, but struggling to locate a source of a small enough SMD SPST switch in small enough quantities.
Happy to try it for curiosity but don’t wanna spend too much!
PostPosted: April 18th, 2019, 20:25
Use an ordinary sized switch and run wires to the pads. No need for smt.
If the PCB allows it, there may be a way to drill a hole to accommodate the switch, or you may be able to anchor it at one of the screw holes.
PostPosted: April 18th, 2019, 21:00
Farnell have all kinds of small switches you could buy for next to nothing and epoxy to the PCB.
PostPosted: April 18th, 2019, 21:40
An alternative solution would be to short the pads of R3 with tweezers. This will pull the SEL pin high and disconnect both SATA pairs. This procedure should be safe, although inelegant. However, it would serve as proof of concept prior to embarking on any modifications.
Users browsing this forum: No registered users and 0 guests
