 Post subject: Looking for cheap 2061-701477-200 AA PCB ....
PostPosted: April 25th, 2019, 17:08
Hi there. Does anyone IN EUROPE have a CHEAP WORKING 2061-701477-200 AA PCB that is willing to sell ?
2060-701477-002 REV A
For a WD5000AAVS-002TB0 "Spider" drive.
Original PCB doesn't make the drive spin at all, doesn't respond by ATA in any way even in "Kernel" outside the drive ( PCB connected to HRT alone without drive doesn't report DRDY and i can't read ROM ) and boot code mode by terminal to read ROM is not working as well.
It's like if the PCB doesn't have power at all.
Should be "easy" to read copy of ROM module from SA and if they are not present should still be possible to rebuild adaptives from module 40 to ROM module so I'm looking for a PCB that it's not very expensive but can be shipped faster than from China.
eBay have lots of them but they are $50 and above.
drivestar do have a very cheap one ( $6 USD only ) but it might take lot of time to get.
I'm looking to spend something like 5€ or 10€ in a PCB and if it's shipped from EUROPE should be fast and afoardable.
Thanks.
 Post subject: Re: Looking for cheap 2061-701477-200 AA PCB ....
PostPosted: April 25th, 2019, 17:36
Rather than buy the PCB, just buy a fairly close matched drive. It'll probably cost the same $50 and you'll have a working drive at the end you can resell if you don't want to keep it.
I almost never buy PCBs anymore. I always buy full drives. Then when I'm done with the PCB, the donor goes in stock for the next case or to sell to another lab via eBay.
PostPosted: April 25th, 2019, 18:51
Thanks for your suggestion ! If i can't fix the PCB and/or buy a cheap one i will do that (buy entire drive) .
PostPosted: April 25th, 2019, 20:52
I'll check tomorrow if I have a donor.
PostPosted: May 3rd, 2019, 1:14
701444 also works on this drive you can find this pcb on 160gb drive also
PostPosted: May 3rd, 2019, 17:42
Yes, i did figured that out and recovered the data !!!
Thanks !!!
http://www.hddoracle.com/viewtopic.php? ... =40#p20786
Users browsing this forum: Majestic-12 [Bot] and 4 guests
