 Post subject: Using the COM Port UART Adapter
PostPosted: April 29th, 2019, 15:35
I know this should be straightforward but I can seem to connect to the COM port on any of the hard drives I've got using the UART USB card. Is there a vido anywhere that shows not only how to connect it but what lights should be on the card and how it looks in program itself?
 Post subject: Re: Using the COM Port UART Adapter
PostPosted: April 30th, 2019, 8:43
Seems like it only happens with WD drives. I'll have to try a different connector.
PostPosted: April 30th, 2019, 11:03
edited due to being probably wrong...
PostPosted: April 30th, 2019, 20:26
What do you mean?
PostPosted: April 30th, 2019, 20:40
@alfarom, when you say "the UART USB card", what do you mean by "the"? The early card was limited to 3.3V I/O whereas the latest card can handle 2.5V and 1.8V.
PostPosted: May 1st, 2019, 14:44
The later card. Doesn't matter now it seems that I was only getting a problem with a couple of WD drives.
cron
