Forum rules
Post new topic Reply to topic  [ 96 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: Marvell 88i6745n JTAG
PostPosted: May 7th, 2015, 11:06
Doomer wrote:
_dex_ wrote:
"Tiny Console" is activated!
Connect resistor 4k7 to P1 test point (+3.3v) and E6 test point.
So you made "5" (or maybe it was 0x1C00A84E)
If you make it "3" you'll get X-Modem
Great work
I am looking at some similar stuff, but on SSD. I believe the great Dex isn't with us anymore, which is sad.
I wonder if anyone can tell me... how does one come to the conclusion that a 4k7 resistor would need to be across there?
Is it some kind of knowledge of other systems that this is the case?
a guess?
something points to it in the firmware disassembly?
access to a manual?
access to inside info or another hacker?
I can fully se someone figuring out the JTAG pads, but this seems like not something that is accidently happened apon.
PostPosted: May 7th, 2015, 17:31
Post clear image(s) of the SSD board.
PostPosted: May 7th, 2015, 18:35
Samsung MZ-7PD128M
PostPosted: May 7th, 2015, 21:19
I would like to keep the post a couple back where I quoted Doomer and _dex_, but I would rather keep this thread true to _dex_'s content and I will start another thread for each of the SSDs I am looking at.
I don't want _dex_ and Doomer's work to be buried in a long meandering off topic thread.
If a Moderator wants to delete the above post with 2 pictures(or not) is fine by me. I will only post here again if it is very on topic.
PostPosted: May 11th, 2015, 17:35
I'm certainly not the expert, but those seven plated wholes are pretty suspect.
Assuming just a two sided board it looks like at least six of them have traces.
Could be jTAG, and, or, serial there.
Meter them out. See if some have the typical 3.3 or 1.8v logic levels.
PostPosted: February 27th, 2016, 5:58
Hi , i want make friend with you ! my QQ:1186046994
PostPosted: February 27th, 2016, 14:00
friend with who ?
if you mean the OP ?!
the OP don't have the ability to use QQ anymore :( (read page 4)
PostPosted: June 8th, 2019, 11:37
A better image to the Source Code of Marvell JTAG
R.I.P. dejan....
Its Hard to forget someone like you....
PostPosted: June 13th, 2019, 5:44
Sean, you asked me and i got the Tool Today.... :wink:
Really appreciate his recommendation
PostPosted: June 15th, 2019, 17:44
https://www.jtag.com/ru/product/jtag-live-controller/ :wink: :wink: :wink:
PostPosted: June 16th, 2019, 6:13
195 Euros? to do JTAG? Holy Shit, would want some pretty good features
PostPosted: June 16th, 2019, 7:42
Diff. screw drivers (brands) to do the same job :idea:
PostPosted: June 16th, 2019, 20:12
Kia's & Ferrari's... Gotchya! ;-)
PostPosted: June 17th, 2019, 3:35
If you're testing the waters, here is a JTAG identification tool (JTAGenum) for US$3, delivered.
JTAGulator vs. JTAGenum, Tools for Identifying JTAG Pins in IoT Devices:
https://www.praetorian.com/blog/jtagulator-vs-jtagenum-tools-for-identifying-jtag-pins-in-iot-devices?edition=2019
What are some other differences between the two options?
As far as hardware differences go the JTAGulator has built in level conversion and input protection. This is why I am releasing a shield for the Arduino which provides the exact same capabilities. The open hardware designs for the shield are available here:
https://github.com/dxa4481/inputProtectionShield
PostPosted: April 6th, 2020, 10:10
einstein9, I WANT SOME REVIEW IN THIS POST. TDO SIGNAL IS TOO HIGH ITS 2.70 .OPENOCD NOT GET ID
PostPosted: April 6th, 2020, 10:14
guru, anyone help me this topic. tdo signal is too high it is 2.7 volt .how to get id .pls help
