 Post subject: How to completely clear the ST4000NM0033 SMART error record
PostPosted: June 12th, 2019, 22:49
Hi,Guys 。How to completely clear the ST4000NM0033 SMART error record, N1 command can clear the use time and times, PC-3000 UDMA translator regeneration is not suitable for this kind of hard disk
 Post subject: Re: How to completely clear the ST4000NM0033 SMART error rec
PostPosted: June 13th, 2019, 14:08
But something like a HGST and put that thing on the garbage can ?
Maybe your S.M.A.R.T. "error" is caused for example by bad sectors that will affect the re-located sector count and pendings ector count and that can't be cleared by re-setting S.M.A.R.T. ... etc etc ....
Clearing S.M.A.R.T. will not fix the drive.
PostPosted: June 19th, 2019, 4:16
Thanks for share.yes, there are 79 error records on the surface of the record. The MHDD scan is normal but cannot be cleared, and the way to add defects is different from the common F3 family by PC3000 express
PostPosted: June 19th, 2019, 5:23
Smart302 wrote:
Thanks for share.yes, there are 79 error records on the surface of the record. The MHDD scan is normal but smart cannot be cleared, and the way to add defects is different from the common F3 family by PC3000 express
PostPosted: June 19th, 2019, 15:35
You would need to move G-List to P-List and re-format or clear G-List assuming the "errors" are re-located sectors or pending sectors and even so the drive is junk ...
http://www.hddoracle.com/viewtopic.php?f=2&t=2521
Buy new drive and if possible buy HGST drive or older Samsung (1TB Spinpoint or 500 GB). Those used to be very reliable. If you want bigger try HGST but don't buy modern He drives. The less capacity you can buy the better. The higher the capacity the more un-reliable will be the drive. Avoid modern drives. Modern drives are not yet very known and firmware tools will not support them if you need later to recover data. New is bad, the same as in computer security. Old and proved to be reliable is way better than new that no-one knows if it will be reliable or not.
Users browsing this forum: BuZa, MSN [Bot] and 28 guests
