Ok ... Let's see ---
First of all read here : -
http://www.hddoracle.com/viewtopic.php?f=56&t=2750 - this shows the importance of doing thigns correctly THE FIRST TIME.
Now let's scare you off. Read here : -
http://www.hddoracle.com/viewtopic.php?f=56&t=1427 - this is what happend when you do mess it up.
Now let's read a little more about your drive - Seagate F3 "Junk" : -
http://www.hddoracle.com/viewtopic.php?f=2&t=2521 ...
Assuming that DATA is of value you have cheap alternatives to DO-IT-YOURSELF like my services. Firmware fix service : -
https://www.ebay.com/itm/Seagate-Hard-D ... 3023689172 and you will get for free the data extraction service -
https://www.ebay.com/itm/Logical-Data-R ... 3016948382 (as i'm feeling happy and generouse today).
But goes without saying you want a do-it-yourself sollution anyway so ...
Now that i did publish some advertize to myself here we go ...
Connect your drive to TTL like this :
http://www.hddoracle.com/viewtopic.php?f=6&t=193You have a F3 ARCH drive as your FIRMWARE version doesn't have a dot (.) separating the first number of the firmware like on ST-10 ... so .... power the drive on with the terminal connected and POST the LOG that the drive output to TTL/terminal software at power up ... Goes without saying open the terminal first and power the drive later.
If you do have a log that doesn't show any major problem and if there is no need to correct for example DOS table you can go directly to attempt to apply congen commands but you must be aware that translator might be damaged, etc ... so it's important to know the log of the drive first and to know if the drive is stuck on BSY with vitoria or if full LBA space is accessible and detected, etc .....
You can try to apply the following commands : -
http://www.hddoracle.com/viewtopic.php? ... =80#p14731 - many of them will be invalid for your drive. Power off the drive and on again. Enable READ cache with victoria. Attempt to clone the drive with hddsuperclone.
If you manage to clone the drive then extract the data out of the clone using DMDE or R-STUDIO, etc ...
Good luck !
