 Post subject: New info on DD3000
PostPosted: March 12th, 2019, 22:10
New info received from DD3000 on facebook page
https://www.facebook.com/HDDTOOLS/
Important: I don't know the seller nor the tool, just sharing new info.
Here is the documentation;
According to the seller on facebook there will be 2 version available, online priced at about 1000$, offline hardware around 1500$.Image . Not sure what online means though.
English still not available. should be soon.
The portable recovery device - DD3000 is introduced as follows:
DD3000 hard disk repair recovery function introduction:
01: Seagate hard drive firmware repair function
02: Western Digital Hard Disk Firmware Repair Function
03: Samsung hard drive firmware repair function
04: Toshiba hard disk firmware repair function
05: Hitachi hard disk firmware repair function
Introduction to DD3000 data mirror extraction function
01: Hard disk fast scan function
02: Disk radar mirroring function
03: Control target disk power
04: Directory file parsing DE module
05: Hard disk split mirroring function
06: Seagate hard drive auxiliary mirroring function
07: Mobile hard disk, U disk mirroring function
DD3000 server SAS hard disk function introduction (optional module)
01: Non-standard sector hard disk instant conversion function
02: Third-party software mapping function
03: Server SAS/FC/SCSI interface hard disk scanning function
04: Server SAS/FC/SCSI interface hard disk mirroring function
DD3000 additional professional tools
01: SQL database fragmentation merge recovery function
02: RAID array intelligent data recovery function
03: Video Fragment Recovery
04: SQL database has no log attachment function
05: word, excel batch rename
06: vhd_Z (image file to VHD)
07: Lei Chao Surveillance Video Pro
08: VMware Virtual Machine Demo
DD3000 offline cloning function
01: Standard cloning function
DD3000 accessory introduction (optional function)
01: Hot swappable power module (optional later)
02: Conversion card for connecting IDE hard disk (optional later)
03: Conversion card for connecting M.2 and mSATA SSDs (optional later)
04: Command module (current optional)
Product use precautions:
01: About USB3.0 data cable
02: About the power adapter
03: About 2 cards and 4 ports
DD3000 hard disk repair recovery function introduction :
The following is the main interface of the software, the specific steps are as follows:
The DD3000 has two ports: Port 0 and Port 1 are controlled by independent programs. Even if one of the processes is abnormal, it will not affect the normal operation of the other port. The core module of the DD3000 software was developed on the basis of the old version of the DD3000.
Highlights of the DD3000 software:
01: The industry's unique innovative technology (radar image), the so-called radar image is the side detection side mirroring, quickly find the scratched area of the magnetic medium, quickly skip. The benefits of radar mirroring are as follows:
Point 1: It can greatly reduce the further expansion of the scratch area of the disc;
Point 2: can effectively reduce the risk of head scrapping;
Point 3: can greatly reduce the cost of parts and time;
Point 4: Can help customers recover more data to the maximum extent;
02: Supports firmware repair of faulty hard disk, has firmware virtual loading function, supports firmware to search from database and folder, supports import and export of hard disk firmware database, supports head adaptation operation of faulty hard disk, and supports bad sector condition of hard disk. Under the data extraction.
03: Support split mirror image function.
04: Supports a variety of common hard disk partition formats, supports scanning of hard disk NTFS partition MFT, has the function of copying only valid data images, and supports two copy tasks at the same time.
05: Supports data extraction of 516, 520, 524, and 528-byte non-standard sectors. It supports the ability to instantly map the source disk to a 512-byte hard disk during data extraction, reducing the lengthy data conversion process. Save time and improve work efficiency.
06: Supports mapping of source disks to files and mapping to third-party software.
07: Supports mapping the hard disk to the operating system in read-only mode.
08: Support disk-to-disk, disk-to-file mirroring, and support target image files as compressed files, which can greatly save disk space.
09: Support mirror process interrupt protection, whether it is accidental power failure or crash restart, the current mirror parameters and mirror progress will not be lost, can continue to mirror after loading, the previous mirror results are not lost.
10: The supporting RAID array intelligent data recovery program can connect multiple hard disks through the system control port, and then intelligently analyze the logical algorithm of the RAID array, hard disk sequence, data block size, front offset, start strip, freshness, dirty Disk, hot spare disk, and then intelligently reorganize data according to the analyzed parameters, automatically expand the partition and file and directory structure, and selectively extract important data.
11: Currently supported RAID levels: RAID0, RAID1, RAID0+1, RAID5, etc.
12: For the RAID array, some faulty disks have bad sectors, and the user's valid data can be directly extracted. There is no need to map the entire disk, and the user can selectively image the valid data or extract data. Supports file bitmaps for used or unused sectors of metadata and file system data for selected files and folders.
13: Support for SQL database fragment extraction and merge, support SQL without log attachment, support SQL error repair.
Seagate firmware specialization module for Seagate F3 series hard drives. The firmware of the Seagate F3 series hard disk can be read and written. It is also possible to enter the command of the hard disk terminal through the command line COM port, and repair the firmware problem of the hard disk through the instruction, such as: slow start, long busy after first, no disk recognition, good before and after bad.
The Western Digital Specialized Program can operate on Western Digital firmware, read and write modules, read and write firmware and firmware modules. This feature can be used to fix some firmware problems common to Western Digital disks. Such as: slow start; do not recognize capacity, model; long busy not ready.
The Western Digital specialization module supports dozens of families and can automatically identify families. See the picture below for details:
Supports firmware reading and writing, ROM reading and writing, track reading and writing, and common disease repair. Simple and practical.
The Samsung specialization program can operate Samsung firmware, read and write firmware and firmware modules.
The Toshiba specialization program can operate Toshiba firmware, read and write firmware and firmware modules.
The Hitachi hard disk firmware specialization program can read the module and write the module to the firmware area of Hitachi hard disk.
The hard disk scanning function can detect the bad sectors of the hard disk and display the reading time in a very detailed way. Through the full disk scanning, you can understand the actual working state of the hard disk, and find the bad sectors and the false bad sectors with long reading time. The scanning report can also be done. An important part of the hard drive warranty test report and data recovery report. When scanning a hard disk, the software labels the blocks in different colors according to the read time. When there is a bad track in the block, the software can detect the specific location of bad sectors and the number of bad sectors in the block, so that the scan log is refined.
The DD3000's scanning function uses the latest factory-level scanning mechanism to detect only the track status and not read the track data, which increases the scanning speed by 2-5 times, and the mechanical hard disk can reach a speed of more than 200 MB per second. The hard drive can reach an amazing speed of 2-3GB per second. In the case of bad sectors, it will not be stuck in most cases. It protects the hard disk and improves the scanning speed. In the shortest time, it scans the hard disk for bad sectors and health. This is a relatively advanced one. Scanning technology.
The new version of the DD3000 has more advantages in mirroring! Due to the large number of optimizations in the drive acceleration of our R&D team, the DD3000 has basically reached the limit of the mechanical hard disk based on the quality of the original image.
The industry's only innovative technology (radar image), the so-called radar image is the side detection side mirror, quickly find the scratched area of the magnetic media, quickly skip. The benefits of radar mirroring are as follows:
1: greatly reduces the risk of expanding the scratch area of the disc;
2: Effectively reduce the risk of head scrapping;
3: Disguised saves the cost of the head assembly;
4: For hard disks with many bad sectors, the mirror speed is obviously faster than similar products, which effectively saves time;
5: Can help customers recover more data to the maximum extent;
So the DD3000 has a huge advantage when mirroring a slightly scratched or moderately scratched hard drive. For a severely scratched hard drive, the possibility of head damage cannot be avoided! For severely scratched discs, it is best to determine the approximate area of the scratch before restoring, set the mirror address, and skip the area.
When creating a mirroring task, click on the small lightning bolt to control the power of the target disk. This is a very convenient small function.
The directory resolution function is to parse the file extraction data, file mirroring, and valid data mirroring according to the directory mode of the B+ tree. You can selectively expand the disk partition according to the file directory during the mirroring, and selectively perform file mirroring or copy key data. Shorten the data extraction time and improve work efficiency, which is also an important function that everyone urgently needs.
Disk split mirroring function: The software separates the disk sectors according to their respective heads. When mirroring, only the sectors of the selected head are mirrored. Enable the disk split function to select the head with good mirroring status or the scratched head of the shielded disc to ensure the fast and efficient mirroring task. In the mirroring process, the state of each head and the disk of the disk can be judged according to the speed of each head image and the amount of bad sectors, etc., and provide a basis for subsequent operations such as opening and mirroring.
Everyone knows that if Seagate's hard disk encounters physical bad sectors when mirroring, it will often be busy. It must be reset after power supply. If there are many bad sectors on the hard disk, you need to do many power resets. After the mirroring is completed, the hard disk is no longer recognized. Some heads can be damaged, the head must be replaced and then mirrored. Some of the firmware is damaged, you need to repair the firmware again and then do the mirroring. Some simply can't fix it.
The DD3000 solves this problem perfectly in this respect. When the image encounters a physical bad track, the hard disk is changed by a special means before the hard disk becomes busy, and the physical bad sectors are quickly skipped. Two problems have been solved very well. First, encountering bad sectors will not become busy, greatly reducing the number of hard disk power resets, effectively protecting the hard disk and reducing the probability of hard disk damage again. Second, because the DD3000 encounters bad sectors, it can be skipped quickly, avoiding waiting for a long time after the power reset, greatly improving the mirror speed, and also mirroring more data. This is a highlight that is not available in similar software.
In short, this function can reduce the number of frequent resets of Seagate hard drives, indirectly protecting the magnetic head and preventing premature damage of the magnetic head. However, if the head is read to a severely scratched area, the head damage cannot be avoided.
Support data mirroring of mobile hard disk and USB flash drive with power reset function. It can mirror the mobile hard disk and U disk of the USB interface with bad sectors and bad sectors that need power supply reset. For the original USB mobile hard disk with bad sectors, there is no need to disassemble the shell and change the board (the board is changed to the SATA interface). U-disks with bad blocks do not need to disassemble the FLASH flash memory chip to read data. This function greatly improves the work efficiency.
Supports 516, 520, 524, 528-byte non-standard sectors of the hard disk, instantly mapped to 512-byte hard disk files, reducing the long data conversion process, greatly saving time.
This feature supports mapping of physical non-standard disks (which require access to this type of disk with a special protocol), logical non-standard disks, and mirror files for non-standard disks.
The DD3000 program mapping function maps the data in the hard disk connected to the port into a file. The user can directly load the file with data recovery software (such as winhex) and then recover the data. In the process of restoring data, when the data recovery area has bad sectors, the files accessed by the data recovery software are mapped out by the DD3000 program, which can effectively recover the data and ensure the stability of the system.
The SAS/SCSI hard disk scanning function (requires the user to configure the SAS card and the fiber card) can detect the bad sectors and read/write time of the hard disk in a very detailed manner. Through the full disk or custom sector size scanning, you can understand the actual working status of the hard disk and find the bad. The scan report can also be used as an important part of the hard disk warranty test report and data recovery report. When scanning the hard disk, the software marks the blocks in different colors according to the reading time. When there is a bad track in the block, the software can detect the specific location of bad sectors and the number of bad sectors in the block, so that the scan log is refined.
The parameters related to the DD3000 SAS/SCSI hard disk scanning function can be set by themselves:
The SAS/SCSI disk mirroring feature still uses radar mirroring, inheriting the advantages of radar mirroring. This function still needs to be used with SAS card and fiber card. When the hard disk is connected and recognized, open the port of the main program and mirror it by creating a new task or opening an established task, as shown below:
The task name is customized, and the source disk selects the SAS or fiber disk that needs to mirror the data.
Leichao Technology SQLSERVER fragmentation software is for the SQL SERVER database and library fragmentation scan reorganization, the internal principle of MDF fragmentation is actually sorted by page. The output log entry is the scope of the fragment page number and the location of the fragment. The software will locate and filter the interference data according to the internal structure and characteristics of the SQL to recover the mdf file, and then just press the found fragment. Sorting from small to large can form a complete reorganization of library files.
1. Support recovery of partitions, image files, and disks.
2. Support to define the scope of the search.
3. Support log output.
4. Support scanning information records. After the scan is interrupted, the last progress scan can be continued, and the last scan information is loaded.
Leichao Technology RAID Disk Array Intelligent Recovery Software is a tool for automatic analysis and reorganization of raid arrays.
1, support raid type: raid5, raid6, raid0, hp double loop, etc.;
2, supported file system: NTFS (windows), EXTx (linux);
3, automatic analysis of RAID, and output detailed analysis results (hot standby, lack of disk and dirty disk removal, etc.) for your reference;
4. Use the form tool to display the raid analysis result;
5, support Raid parameter output (pre-offset, disk order, structure, block size, freshness), reference to freshness users can know the approximate drop-off time of the dropped disk.
6, support exhibition directory.
The DD3000 also has good video fragment recovery capabilities. Currently, the main supported categories are: MXF/MPG/MTS/Canon MOV
The DD3000 software can analyze the video data in the source device by the frame scan method through the underlying features of each format video, and scan the fragments one by one. In addition, Canon MOV can not only scan for debris, but also support stitching it into a complete video. Customize source devices, custom partitions, custom ranges, and select image files.
The scanning process is as follows: You can select the type of video you want to scan. The middle part of the window is the total number of sectors (progress) that need to be scanned.
The DD3000's log-free add-on feature helps you automatically add database files to the corresponding version of the log-free database: users simply fill in the appropriate database properties. (The database file corresponds to the database version!)
Word, Excel renaming function is mainly for some data recovered by file type. Since the file name is a randomly generated number, the customer needs to manually click to open the file to identify the file that is needed by himself. Such time-consuming and laborious verification data is very annoying. Therefore, our software extracts the file title or part of the content by obtaining the internal information of the file, as the file name of the file, so that it can quickly identify whether it is the file that you need, which is very convenient.
Excel batch rename
Word batch rename
For some of our image files, we need to use R-studio or winhex to guide the data, but through our software we can directly convert the image file into a vhd virtual disk, which can be directly mounted to view data through system disk management. For some special analysis software, only the disk can be analyzed. In this case, only the image file can be converted into a virtual disk through our professional tools, and it can be used directly, which is very convenient.
For the mainstream monitoring in the market: Haikang, Dahua, WFS, Hanbang, Joan and so on have supported. Through our Leichao surveillance video professional version, you can restore video data through file system parsing and fragment scanning. You can choose according to your needs. We have integrated two types of Haikang: H264 and MSV2;
Dahua monitoring type; WFS0.4 (such as: imperial defense); Hanbang monitoring type; Joan monitoring class. For monitoring the fragmentation scan, you can set the time interval and sector interval to perform the special direction scan. You can also quickly scan the required monitoring position by first scanning the underlying layer to generate the monitoring time, channel, and size log.
Our products now also support the recovery of VMware virtual machines, which is a very good news for everyone! You can scan the partition function by reading the disk or image file, and expand the Vmware virtual machine directory to display the file size, type, creation time, and modification time. We not only support the analysis of VMware virtual machines, but also support the recovery of VMware virtual machine .vmdk, but these advanced recovery features are charged. (including: smart scan delete file function, virtual machine metafile load analysis function, snapshot write back function)
Offline one-click cloning: refers to the function of automatically cloning the hard disk by pressing the clone button without powering the computer host. The target disk must have a capacity greater than or equal to the capacity of the source disk. The target disk must be intact.
Currently, the only domestic support for offline clones with a small number of bad sectors.
Press and hold the clone button for 3-5 seconds, the source disk will be automatically cloned to the target disk. There are 5 triangle indicators to indicate the cloning progress. Each clone is 20% bright and one light is on. And when it does not flash, it means the image is completed.
At the same time, it can supply 8 mechanical hard disks, server hard disks and solid state hard disks with short circuit and overload protection.
The old hard disk used to connect the IDE / EIDE interface, data extraction, clone mirroring, bad track data extraction, firmware repair, etc. for the IDE/EIDE hard disk.
This adapter card can read the data in the M.2 SSD and mSATA SSDs, even if the SSD has bad blocks.
In the data recovery process, sometimes you need to use the COM port terminal command. For example, Seagate, Toshiba, Samsung, etc., some faults need to be connected to the terminal COM interface in addition to the need to connect to the SATA interface. In order to repair the hard disk firmware FW failure, the terminal COM interface can be used to connect the hard disk and issue commands.
The DD3000 data recovery tool provides a complete set of hard drive terminal COM port accessories, which consists of a USB terminal adapter board and multiple command heads.
1: USB3.0 data cable is recommended to use the original data cable we provide, non-original, damaged recommendations should not be used;
2: The number of plugging and unplugging is recommended not to exceed 500 times. It is recommended to replace the new data line with more than one.
3: The length of the USB data cable is recommended not to exceed 0.5 meters. If it is too long, there will be signal attenuation;
4: The data line cannot appear at a height of 90 degrees and below 90 degrees.
5: The end that requires the USB3.0 data cable to connect to the computer must be plugged into the USB3.0 interface of the motherboard. Do not plug it into the front interface of the chassis or the interface extended by the HUB. Otherwise, signal attenuation will occur.
1: It is recommended to use the original power adapter;
2: The DC output interface (connector) of the power adapter must be 5.5x2.5;
3: The power adapter must be a large brand, the DC output voltage must be between 16V ~ 24V, and the total power is not less than 90w;
4: Do not use the power of the cottage brand;
In the 1:2 port card, the 0-a port is inserted into the fault disk, and the 0-b port is inserted into the backup disk, so only one fault disk can be operated at the same time.
2: 4-port card, 0-a port and 1-a port are inserted into the fault disk, 0-b port and 1-b port are inserted into the backup disk, so only two fault disks can be operated at the same time.
https://cslpc.ca/
 Post subject: Re: New info on DD3000
PostPosted: June 17th, 2019, 4:36
Hello
ICCSYS official re-seller of DD3000
Company: ICCSYS
Email: iccsystem@yahoo.com
ICQ: 626146286
QQ: 2766349138
Mobile: 00201002359000
PostPosted: June 17th, 2019, 18:16
Hi there !!!
Is there already any English version of this ?
What would be the current price of the off-line full version ?
PostPosted: June 24th, 2019, 13:48
Well,
Did Someone Read All This Crap Written Above :lol: ,Kindly Show It To Us Working In a Youtube Video And Save US Poor Mortals From Reading All of This ,Some of My Friends Have Crossed Age 40 And Have Poor Eyesight :mrgreen:
PostPosted: June 25th, 2019, 14:11
Amarbir[CDR-Labs] wrote:
Well,
I know what you know, just sharing what I know
https://cslpc.ca/
PostPosted: June 26th, 2019, 14:22
Well,
Well,
Until Tried Never Be Sure ,BTW What Do You Know That i Know ,Cos Even My Aged Wife Does Not Know All What I Know ,Its Been a Secret
PostPosted: June 30th, 2019, 8:34
Well,
Well,
Less than what your wife knows
https://cslpc.ca/
PostPosted: July 12th, 2019, 10:47
Spildit wrote:
Hi there !!!
Hi dear Spildit
The seller is the Sediv seller, this seems to be an improved Sediv with hardware.
You can contact him from Sediv page on facebook for more detail
https://www.facebook.com/iccsys.net
They seems to start selling it
Translated
Peace be
Dear customers, the offer period has been extended to our to
4 PORT £ 10000 for a short time
Hurry up to book your copy now
All current clients are advised that very soon the English version will be released
As for the support forum, it will be completed very soon.
We are working hard to meet the needs of all clients
I swear to God the good and
https://cslpc.ca/
PostPosted: August 23rd, 2019, 8:07
Hello all
English version already released
More information
en.iccsys.net
ICCSYS
Company: ICCSYS
ICQ: 626146286
QQ: 2766349138
