 Post subject: I NEED FIRMWARE 00650075 OF WD
PostPosted: July 10th, 2019, 10:23
I'm looking for this firmware and I can not find it.
Can they provide it to me?
Thank you.
 Post subject: Re: I NEED FIRMWARE 00650075 OF WD
PostPosted: July 10th, 2019, 13:51
Maybe if you could provide the model and family it would help!
PostPosted: July 10th, 2019, 15:03
The model is WD3200UUCT-63TWBY0 is a JAMAIKA 4KV.
I have loaded a rom of the 00650074 and the LDR 00650074 and I have done a sweep of the SA and I already have the LDR.
The problem is that the 2 copies of the SA have many defects.
I'm going to see what I can do, it only has 2 heads.
Thanks PCIMAGE and MIKIPPP.
11.rar [209.25 KiB]
Downloaded 170 times
PostPosted: July 15th, 2019, 12:45
I'm still trying to recover this hard drive.
I have made an intelligent hot exchange, after rebuilding the SA, and now I can read sectors but with many errors.
I have tried 3 sets of heads and same symptom.
Any ideas?
Thank you.
PostPosted: July 15th, 2019, 18:37
In the end I was able to read over 95% of the data of the hdd.
I think that the sectors located in the periphery of the plate fail, I still think that the strong vibrations deform the plates and the most vulnerable area is the periphery, in fact the 2 heads begin to read well practically at the same time.
The zone with errors I give for lost.
A greeting.
PostPosted: July 15th, 2019, 19:42
I am not sure about a possible misunderstanding due to language translation, but I don’t think it is platter vibration, if that is what you are saying. I have a theory that in some cases when one head encounters physical damage, it then does cause vibration in the head stack, which can cause difficulty for the other heads to read. I do not have any proof of this, but have seen at least a couple log files from ddrescue or hddsuperclone that would indicate this event.
http://www.sdcomputingservice.com
Home of HDDSuperClone and HDDSuperTool
Users browsing this forum: Google [Bot] and 47 guests
