Re: Old Maxtor recovery - I/O error
August 11th, 2019, 11:26
I am following your guide.Your .deb installer seems not to work - it returns: the package system could not be initialized, your configuration may be broken.
Just an FYI, this error is something with your system, not the .deb installer. I can install it on a 19.04 live CD without issue. Your issue seems to be with package manager itself, and I cannot help with that. You may want to search your issue for a solution, if you intend to keep using that persistent USB for this and other things, as it could cause future headaches.
August 11th, 2019, 12:33
Yes, I suspected along the line it was a problem with who know what in my installation.
Here is how I solved it:
lubuntu@lubuntu:~/hddsuperclone.2.1.13.x64$ sudo apt-get install libusb-0.1.so.4
Reading package lists... Error!
E: Unable to parse package file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_disco_multiverse_binary-amd64_Packages (1)
E: Unable to parse package file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_disco_multiverse_i18n_Translation-en (1)
E: Unable to parse package file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_disco-updates_main_i18n_Translation-en (1)
E: Unable to parse package file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_disco-updates_restricted_binary-amd64_Packages (1)
E: Unable to parse package file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_disco-updates_restricted_i18n_Translation-en (1)
E: Unable to parse package file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_disco-updates_universe_i18n_Translation-en (1)
E: Unable to parse package file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_disco-updates_multiverse_binary-amd64_Packages (1)
E: Unable to parse package file /var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_disco-updates_multiverse_i18n_Translation-en (1)
W: You may want to run apt-get update to correct these problems
E: The package cache file is corrupted
lubuntu@lubuntu:~/hddsuperclone.2.1.13.x64$ sudo ./hddsuperclone-install-depends-deb.sh
lubuntu@lubuntu:~/hddsuperclone.2.1.13.x64$ sudo apt-get update
Ign:1 cdrom://Lubuntu 19.04 _Disco Dingo_ - Release amd64 (20190416) disco InRelease
Hit:2 cdrom://Lubuntu 19.04 _Disco Dingo_ - Release amd64 (20190416) disco Release
Hit:4 http://security.ubuntu.com/ubuntu disco-security InRelease
Hit:5 http://archive.ubuntu.com/ubuntu disco InRelease
Hit:6 http://archive.ubuntu.com/ubuntu disco-updates InRelease
Traceback (most recent call last):
  File "/usr/lib/cnf-update-db", line 26, in <module>
    col.create(db)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 93, in create
    self._fill_commands(con)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 127, in _fill_commands
    self._parse_single_commands_file(con, fp)
  File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 162, in _parse_single_commands_file
    if not tagf.step():
apt_pkg.Error: E:Unable to parse package file  (1)
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
lubuntu@lubuntu:~/hddsuperclone.2.1.13.x64$ sudo rm -rf /var/lib/apt/lists/*
lubuntu@lubuntu:~/hddsuperclone.2.1.13.x64$ sudo apt update
Err:2 cdrom://Lubuntu 19.04 _Disco Dingo_ - Release amd64 (20190416) disco Release
  Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
Get:3 http://security.ubuntu.com/ubuntu disco-security InRelease [97.5 kB]
Get:4 http://archive.ubuntu.com/ubuntu disco InRelease [257 kB]
Get:5 http://security.ubuntu.com/ubuntu disco-security/main amd64 Packages [173 kB]
Get:6 http://archive.ubuntu.com/ubuntu disco-updates InRelease [97.5 kB]
Get:7 http://security.ubuntu.com/ubuntu disco-security/main Translation-en [63.2 kB]
Get:8 http://archive.ubuntu.com/ubuntu disco/main amd64 Packages [995 kB]
Get:9 http://security.ubuntu.com/ubuntu disco-security/main amd64 DEP-11 Metadata [33.9 kB]
Get:10 http://security.ubuntu.com/ubuntu disco-security/main DEP-11 48x48 Icons [8743 B]
Get:11 http://security.ubuntu.com/ubuntu disco-security/main DEP-11 64x64 Icons [21.4 kB]
Get:12 http://security.ubuntu.com/ubuntu disco-security/main DEP-11 64x64@2 Icons [29 B]
Get:13 http://security.ubuntu.com/ubuntu disco-security/main DEP-11 128x128 Icons [52.0 kB]
Get:14 http://security.ubuntu.com/ubuntu disco-security/main amd64 c-n-f Metadata [2196 B]
Get:15 http://security.ubuntu.com/ubuntu disco-security/restricted amd64 Packages [2616 B]
Get:16 http://security.ubuntu.com/ubuntu disco-security/restricted Translation-en [800 B]
Get:17 http://security.ubuntu.com/ubuntu disco-security/restricted amd64 c-n-f Metadata [116 B]
Get:18 http://security.ubuntu.com/ubuntu disco-security/universe amd64 Packages [223 kB]
Get:19 http://security.ubuntu.com/ubuntu disco-security/universe Translation-en [57.2 kB]
Get:20 http://security.ubuntu.com/ubuntu disco-security/universe amd64 DEP-11 Metadata [14.6 kB]
Get:21 http://security.ubuntu.com/ubuntu disco-security/universe DEP-11 48x48 Icons [14.3 kB]
Get:22 http://security.ubuntu.com/ubuntu disco-security/universe DEP-11 64x64 Icons [35.9 kB]
Get:23 http://security.ubuntu.com/ubuntu disco-security/universe DEP-11 64x64@2 Icons [29 B]
Get:24 http://security.ubuntu.com/ubuntu disco-security/universe DEP-11 128x128 Icons [105 kB]
Get:25 http://security.ubuntu.com/ubuntu disco-security/universe amd64 c-n-f Metadata [1260 B]
Get:26 http://security.ubuntu.com/ubuntu disco-security/multiverse amd64 Packages [1172 B]
Get:27 http://security.ubuntu.com/ubuntu disco-security/multiverse Translation-en [632 B]
Get:28 http://security.ubuntu.com/ubuntu disco-security/multiverse amd64 c-n-f Metadata [116 B]
Get:29 http://archive.ubuntu.com/ubuntu disco/main Translation-en [509 kB]
Get:30 http://archive.ubuntu.com/ubuntu disco/main amd64 DEP-11 Metadata [499 kB]
Get:31 http://archive.ubuntu.com/ubuntu disco/main DEP-11 48x48 Icons [97.2 kB]
Get:32 http://archive.ubuntu.com/ubuntu disco/main DEP-11 64x64 Icons [179 kB]
Get:33 http://archive.ubuntu.com/ubuntu disco/main DEP-11 64x64@2 Icons [2962 B]
Get:34 http://archive.ubuntu.com/ubuntu disco/main DEP-11 128x128 Icons [417 kB]
Get:35 http://archive.ubuntu.com/ubuntu disco/main amd64 c-n-f Metadata [30.0 kB]
Get:36 http://archive.ubuntu.com/ubuntu disco/restricted amd64 Packages [14.0 kB]
Get:37 http://archive.ubuntu.com/ubuntu disco/restricted Translation-en [4960 B]
Get:38 http://archive.ubuntu.com/ubuntu disco/restricted amd64 c-n-f Metadata [348 B]
Get:39 http://archive.ubuntu.com/ubuntu disco/universe amd64 Packages [9065 kB]
Get:40 http://archive.ubuntu.com/ubuntu disco/universe Translation-en [5251 kB]
Get:41 http://archive.ubuntu.com/ubuntu disco/universe amd64 DEP-11 Metadata [3546 kB]
Get:42 http://archive.ubuntu.com/ubuntu disco/universe DEP-11 48x48 Icons [2759 kB]
Get:43 http://archive.ubuntu.com/ubuntu disco/universe DEP-11 64x64 Icons [8369 kB]
Get:44 http://archive.ubuntu.com/ubuntu disco/universe DEP-11 64x64@2 Icons [21.4 kB]
Get:45 http://archive.ubuntu.com/ubuntu disco/universe DEP-11 128x128 Icons [16.1 MB]
Get:46 http://archive.ubuntu.com/ubuntu disco/universe amd64 c-n-f Metadata [277 kB]
Get:47 http://archive.ubuntu.com/ubuntu disco/multiverse amd64 Packages [157 kB]
Get:48 http://archive.ubuntu.com/ubuntu disco/multiverse Translation-en [112 kB]
Get:49 http://archive.ubuntu.com/ubuntu disco/multiverse amd64 DEP-11 Metadata [51.3 kB]
Get:50 http://archive.ubuntu.com/ubuntu disco/multiverse DEP-11 48x48 Icons [10.8 kB]
Get:51 http://archive.ubuntu.com/ubuntu disco/multiverse DEP-11 64x64 Icons [221 kB]
Get:52 http://archive.ubuntu.com/ubuntu disco/multiverse DEP-11 64x64@2 Icons [1160 B]
Get:53 http://archive.ubuntu.com/ubuntu disco/multiverse DEP-11 128x128 Icons [421 kB]
Get:54 http://archive.ubuntu.com/ubuntu disco/multiverse amd64 c-n-f Metadata [9348 B]
Get:55 http://archive.ubuntu.com/ubuntu disco-updates/main amd64 Packages [228 kB]
Get:56 http://archive.ubuntu.com/ubuntu disco-updates/main Translation-en [89.2 kB]
Get:57 http://archive.ubuntu.com/ubuntu disco-updates/main amd64 DEP-11 Metadata [131 kB]
Get:58 http://archive.ubuntu.com/ubuntu disco-updates/main DEP-11 48x48 Icons [15.2 kB]
Get:59 http://archive.ubuntu.com/ubuntu disco-updates/main DEP-11 64x64 Icons [38.2 kB]
Get:60 http://archive.ubuntu.com/ubuntu disco-updates/main DEP-11 64x64@2 Icons [29 B]
Get:61 http://archive.ubuntu.com/ubuntu disco-updates/main DEP-11 128x128 Icons [92.8 kB]
Get:62 http://archive.ubuntu.com/ubuntu disco-updates/main amd64 c-n-f Metadata [2996 B]
Get:63 http://archive.ubuntu.com/ubuntu disco-updates/restricted amd64 Packages [3012 B]
Get:64 http://archive.ubuntu.com/ubuntu disco-updates/restricted Translation-en [840 B]
Get:65 http://archive.ubuntu.com/ubuntu disco-updates/restricted amd64 c-n-f Metadata [116 B]
Get:66 http://archive.ubuntu.com/ubuntu disco-updates/universe amd64 Packages [258 kB]
Get:67 http://archive.ubuntu.com/ubuntu disco-updates/universe Translation-en [82.3 kB]
Get:68 http://archive.ubuntu.com/ubuntu disco-updates/universe amd64 DEP-11 Metadata [59.6 kB]
Get:69 http://archive.ubuntu.com/ubuntu disco-updates/universe DEP-11 48x48 Icons [32.6 kB]
Get:70 http://archive.ubuntu.com/ubuntu disco-updates/universe DEP-11 64x64 Icons [84.1 kB]
Get:71 http://archive.ubuntu.com/ubuntu disco-updates/universe DEP-11 64x64@2 Icons [29 B]
Get:72 http://archive.ubuntu.com/ubuntu disco-updates/universe DEP-11 128x128 Icons [228 kB]
Get:73 http://archive.ubuntu.com/ubuntu disco-updates/universe amd64 c-n-f Metadata [1780 B]
Get:74 http://archive.ubuntu.com/ubuntu disco-updates/multiverse amd64 Packages [1172 B]
Get:75 http://archive.ubuntu.com/ubuntu disco-updates/multiverse Translation-en [632 B]
Get:76 http://archive.ubuntu.com/ubuntu disco-updates/multiverse amd64 c-n-f Metadata [116 B]
Reading package lists... Done
E: The repository 'cdrom://Lubuntu 19.04 _Disco Dingo_ - Release amd64 (20190416) disco Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Building dependency tree
Reading state information... Done
E: Unable to locate package libusb-0.1.so.4
E: Couldn't find any package by glob 'libusb-0.1.so.4'
E: Couldn't find any package by regex 'libusb-0.1.so.4'
Note, selecting 'libusb-0.1-4' for regex 'libusb-0.1'
The following NEW packages will be installed:
  libusb-0.1-4
0 upgraded, 1 newly installed, 0 to remove and 222 not upgraded.
Need to get 17.4 kB of archives.
After this operation, 58.4 kB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu disco/main amd64 libusb-0.1-4 amd64 2:0.1.12-32 [17.4 kB]
Fetched 17.4 kB in 0s (53.4 kB/s)
Selecting previously unselected package libusb-0.1-4:amd64.
(Reading database ... 215664 files and directories currently installed.)
Preparing to unpack .../libusb-0.1-4_2%3a0.1.12-32_amd64.deb ...
Unpacking libusb-0.1-4:amd64 (2:0.1.12-32) ...
Setting up libusb-0.1-4:amd64 (2:0.1.12-32) ...
Processing triggers for libc-bin (2.29-0ubuntu2) ...
make is already the newest version (4.2.1-1.2).
make set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 222 not upgraded.
gcc is already the newest version (4:8.3.0-1ubuntu3).
gcc set to manually installed.
Up and running now!!
I'll test the software on a test drive first and then shoot the 5 min log on the real one
August 12th, 2019, 6:11
It looks grim...
This might help assessing the status of the drive.
August 12th, 2019, 18:14
I based the idea that hddsuperclone could read it from the post where you showed that the drive listed with lsblk as having partitions, which would mean it identified and read at least sector 0. If this is still true (the screenshot would indicate that is likely still true), then the drive is locking up / going offline after that, which would likely indicate a firmware issue for some sort of busy / non-responding issue. That means it is time to get into the terminal connection and commands, which I don't do. Others here would need to help you with that.
August 13th, 2019, 4:04
maximus wrote:I based the idea that hddsuperclone could read it from the post where you showed that the drive listed with lsblk as having partitions
I was expecting that too :(
August 13th, 2019, 4:45
Thank you maximus and HaQue for your time
August 13th, 2019, 18:01
Well, at least all hope is not lost. Since it does appear to actually at least read sector 0 and get the partition table, it means it is still alive (or at least not totally dead). It probably has bad sectors, maybe a bad head, but there is still more that can be done DIY using the TTL adapter. If the firmware issues can be fixed, you should hopefully be able to get some data off it. Just don't send the wrong commands to it, or you could kill it for good.
August 14th, 2019, 12:37
Thank you for your reassurance. It seems I do not have other choice that to dive in - i am terrified :lol:
I haven't yet understood if and when is safe to power up or down the drive though. I know SATA supports hot plugging and it is clear I do have to power up the drive at some point after setting up the terminal, but when am I supposed to power it down? Powering it down while it is still processing some information is the last thing I want to happen and my worst fear at the moment. I've read that some commands might take time to show responses on terminal and that until then you shouldn't power down the drive.
August 21st, 2019, 8:47
I have taken my chances and plugged my test drive trough TTL.
Naturally I couldn't get the terminal to work. Not surprising..
I followed the instructions on how to connect the TTL adapter to the drive Spildit kindly gave me in his first post. I used Putty with the following settings:
Baud - 38400
Data Bits - 8
Parity - None
Stop Bits - 1
Flow Control - None
I have two TTL adapters:
Based on the CH340 module (https://www.aliexpress.com/item/3276142 ... 4c4dLsQxbf).
Based on CP2102 (https://www.aliexpress.com/item/3250301 ... 4c4dLsQxbf).
Both of them have two handy LEDs (one for transmission, one for reception) that show you what's happening. I anyway shorted RX and TX on both and tried them directly on terminal. They work!
I made sure both gave 3.3V (the first one can be manually switched to 5V).
I isolated with tape and slightly flatten the connectors to make sure they would adhere to the HDD pins without interference.
I read somewhere Spildit was recommending CP2104 for better compatibility, which seems close to my second adapter, at least name-wise.
So, I open the terminal with the aforementioned settings and then power up the drive. The terminal stays blank. In a following post Spildit was saying to check what log the HDD would be displaying on the terminal.
I had planned to input a few commands listed here: https://www.data-medics.com/forum/seaga ... 3242a6b8a1. Like Ctrl + a or Ctrl + l which seem to be harmless. Needless to say nothing is showed on terminal when I input those commands. I also tried to give Ctrl + z first and then any other command, but nothing happen. I noticed that when I type ctrl no light is shown on the TX corresponding LED unlike say the z key if I have to input Ctrl + z. Is that normal?
I am still not sure about when to power down the HDD. I assume anytime if nothing is showed on terminal and the heads are parked. I do not know whether I have to wait before or after inputting anything and if yes how long..
Perhaps some of you guys know already what I am doing wrong and if yes hope you can point me in the right direction.
Thank you :mrgreen:
August 21st, 2019, 17:20
Since there are no other replies yet, I will say a couple of things to try.
First and foremost, make sure those connectors on the hard drive are not shorting together at all. I did some testing with connectors just like that, and I had to be real careful to make sure the wires were positioned just right to keep them separated.
Second, try reversing the TX and RX on one end. My first attempt to connect to a Seagate drive failed because it was backwards. It shouldn't hurt if they are accidentally backwards, at least it didn't hurt anything in my case.
August 21st, 2019, 19:06
Thanks for replying maximus. I am positive connectors cannot touch one another, they are completely wrapped with thin transparent tape. As for inverting RX and TX I haven't tried it yet. Will try it tomorrow..
August 23rd, 2019, 11:43
Something actually happened as soon as I gave power
With CP2102 (some very quick head movements)
▒▒xx▒x▒xx▒x▒▒▒▒x▒▒▒▒x▒▒▒▒▒x▒xx▒x▒▒▒x▒xxxx▒▒▒▒xx▒▒▒xx▒▒x▒xx▒▒▒
▒▒xxx▒▒▒▒▒▒▒▒xx▒▒▒x▒xx▒▒▒▒x▒▒▒▒▒▒▒x▒x▒x▒▒xxx▒x▒▒▒x▒▒▒x▒x▒▒x▒▒▒x▒xx
xx▒xxx▒▒▒xx▒x▒xx▒x▒▒x▒x▒x▒xxx▒▒▒xx▒x▒xx▒x▒▒▒▒▒x▒x▒▒x▒▒x▒x▒xx▒
With CH340 (head movements negligible)
▒▒▒▒▒▒▒▒▒▒.@xr▒¤
Futile my attempts to get anything else out with Ctrl + a, l or z
August 23rd, 2019, 18:09
Back when I was playing around with the terminal connection, I seem to remember two things that caused garbage data like that. One was having the wrong baud rate, and the other was a ground issue.
August 24th, 2019, 9:42
In fact the baud rate was wrong. In Spildit's guide is written for 7200.10 the baud rate is 9600. My mistake, thank you for pointing it out.
Here is the output although it is not really relevant
Reset
4096k x 32 DRAM
GALAXY2D - 1_Disk    S-6B   06-29-06_12:39
Buzz HM SFI
(P)SATA Reset
(H)SATA Reset
(----->typing ctrl+a)
Eng Rev = .0EW
Compat/Hardware = .6D1
GALAXY2D - 2_Disk    3.AAD  06-29-06_12:42 AAD,GX_2D_4H_S,3A
CERT Rev = .0AP
NONE
Mask Rom Rev = S-6B
Orig Code = AAD3A0 TONKA2_GX_3A0.0EW.0AP
(----->typing ctrl+l)
Built for GALAXY2D,PITKIN,Redback,TI1810 PreAmp,Agere7531 PreAmp,McKinleyDT,2Disk,220 Servos,7200RPM,8Pole,133MHz,RwFeat=0002,VBAR
The output is identical with both TTL adapters.
Okay. It seems I am now ready to try the faulty drive.
dick wrote:Take note your drive to diagnose is a 7200.11 and your test drive is a 7200.10
Double checking the specs the drive appear to be a 7200.12
This time the baud rate should be 38400
And here it is ladies and gentlemen
Rst 0x10M
(P) SATA Reset
(----->typing ctrl+z)
ASCII Diag mode
F3 T>
Package Version: PH0G2D.CCD3.AA8400.CC38    , Package P/N: 100593077, Package Builder ID: AT,
Package Build Date: 09/18/2009, Package Build Time: 14:25:51, Package CFW Version: PH0G.CCD3.00205150.AT00,
Package SFW1 Version: D24C, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 09181425, CustomerRel: CC38, Changelist: 00205150, ProdType: PH0G.CCD3, Date: 09/18/2009, Time: 142551, UserId: 00236537
Servo FW Rev: D24C
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03
New Skews Pharaoh 0F with VTPI,RAP16,Common Code 3
Product FamilyId: 3F, MemberId: 05
HDA SN: 6VMAFKDM, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 2542EAB0, PreampType: 73 03
PCBA SN: 0000K0249WQS, Controller: YETIST_3_*/4_0(649B)(3-12-3-3), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 1000000
Servo FW Rev: D24C
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 disabled
August 30th, 2019, 14:40
I had a look around for the first line in the log: Rst 0x10M, but very little came up. Does anyone know its meaning?
Following the commands list the drive very kindly provided. Where could I start to investigate the source of the I/O error?
There are a lot of interesting entries I would like to try but I'd rather wait for your advice..
Thank you for your time
Rst 0x10M
(P) SATA Reset
ASCII Diag mode
F3 T>/c
F3 C>Q
Online CR: Rev 0011.0000, Flash,   Abort
Online ESC: Rev 0011.0000, Flash,   Abort Looping Command or Batch File
Online ' ': Rev 0001.0000, Flash,   Pause Output
Online '.': Rev 0011.0000, Flash,   Display Active Status
Online '?': Rev 0011.0000, Flash,   Display Diagnostic Buffer Information
Online '`': Rev 0012.0001, Flash,   Display Read/Write Statistics
Online '$': Rev 0012.0001, Flash,   Display Read/Write Statistics By Zone
Online '{': Rev 0011.0000, Flash,   Toggle EIB-Specific R/W Tracing
Online ^D: Rev 0011.0000, Flash,   Toggle R/W Tracing
Online ^N: Rev 0011.0000, Flash,   Toggle R/W Tracing
Online ^W: Rev 0011.0000, Flash,   Enable and Init RW Statistics
Online ^O: Rev 0001.0000, Flash,   Advance Servo Tracing State
Online '!': Rev 0011.0000, Flash,   Display Current Read Channel Settings
Online '<': Rev 0011.0000, Flash,   Decrement Read/Write Scope Sync
Online '>': Rev 0011.0000, Flash,   Increment Read/Write Scope Sync
Online '~': Rev 0011.0000, Flash,   Display Native Interface Command State
Online ^A: Rev 0012.0000, Flash,   Display Firmware Revision
Online ^B: Rev 0012.0000, Flash,   Get Thermistor Temperature
Online ^C: Rev 0011.0000, Flash,   Firmware Reset
Online ^E: Rev 0011.0000, Flash,   Display Native Interface Configuration
Online ^F: Rev 0011.0000, Flash,   Display Native Interface Read Cache Information
Online ^I: Rev 0011.0000, Flash,   Display Controller Registers
Online ^K: Rev 0011.0000, Flash,   Display DST Status
Online ^L: Rev 0013.0000, Flash,   Display Sign On Message
Online ^P: Rev 0011.0000, Flash,   Toggle Diag Idle Mode
Online ^Q: Rev 0011.0000, Flash,   Resume Interface Task
Online ^R: Rev 0011.0000, Flash,   Enable ASCII Online Serial Port Mode
Online ^S: Rev 0011.0000, Flash,   Pause Interface Task
Online ^T: Rev 0011.0000, Flash,   Enable ESLIP Serial Port Mode
Online ^U: Rev 0011.0000, Overlay, Display Congen
Online ^V: Rev 0011.0000, Overlay, Toggle Interface Command Echo
Online ^X: Rev 0011.0000, Flash,   Display Native Interface and Read/Write Command History
Online ^Y: Rev 0011.0000, Flash,   Display DST Status
Online ^Z: Rev 0011.0000, Flash,   Enable ASCII Diagnostic Serial Port Mode
Online ^\: Rev 0011.0000, Flash,   Toggle Debug Display Enable
All Levels CR: Rev 0011.0000, Flash,   Abort
All Levels '/': Rev 0001.0000, Flash,   Change Diagnostic Command Level, /[Level]
All Levels '+': Rev 0012.0000, Flash,   Peek Memory Byte, +[AddrHi],[AddrLo],[NotUsed],[NumBytes]
All Levels '-': Rev 0012.0000, Flash,   Peek Memory Word, -[AddrHi],[AddrLo],[NotUsed],[NumBytes]
All Levels '=': Rev 0011.0002, Flash,   Poke Memory Byte, =[AddrHi],[AddrLo],[Data],[Opts]
All Levels '@': Rev 0001.0000, Overlay, Batch File Label, @[LabelNum]
All Levels '|': Rev 0001.0000, Overlay, Batch File Terminator, |
All Levels '*': Rev 0011.0000, Overlay, Special Batch File Function, *[FuncId],[FuncParm0],[FuncParm1]
All Levels 'A': Rev 0011.0000, Overlay, Set Test Space, A[OptsOrParmSelect],[ParmValue],[AddrType],[HdForCylLimit]
All Levels 'L': Rev 0001.0002, Overlay, Enable Looping, L[Opts],[CountOrStopOnErrCode]
Level 1 'S': Rev 0011.0001, Flash,   Edit Processor Memory Byte, S[AddrHi],[AddrLo],[MemValue],[NumBytes],[Opts]
Level 1 'U': Rev 0011.0001, Flash,   Edit Buffer Memory Byte, U[AddrHi],[AddrLo],[MemValue],[NumBytes]
Level 1 'e': Rev 0011.0000, Flash,   Spin Down and Reset Drive, e[MsecDelay],[Opts]
Level 1 'm': Rev 0011.0001, Flash,   Edit Processor Memory Word, m[AddrHi],[AddrLo],[MemValue],[NumBytes],[Opts]
Level 1 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 1 'D': Rev 0011.0001, Overlay, Memory Block Display, D[AddrHi],[AddrLo],[CompVal],[NumBytes],[Opts],[SizeInBytes]
Level 1 'G': Rev 0011.0000, Overlay, Generic Read/Write Request, G[Parm0],[Parm1],[Parm2],...[Parm9]
Level 1 'I': Rev 0001.0000, Overlay, Buffer DLL Tune, I[action][DLL]
Level 1 'N': Rev 0015.0000, Overlay, SMART Control, N[SubCmd],[SubCmdParm0],[SubCmdParm1]
Level 1 'c': Rev 0011.0000, Overlay, Buffer Compare, c[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level 1 'j': Rev 0001.0000, Overlay, Display Hardware Jumper Setting, j[HardwareJumperSelect]
Level 2 'J': Rev 0001.0000, Flash,   Particle Sweep, J[ Start Cyl ],[ End Cyl ],[ Duration mSec ],[ Dwell mSec ],[ JIT mode ]
Level 2 'U': Rev 0011.0000, Flash,   Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 2 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level 2 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 2 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level 2 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 2 'F': Rev 0011.0000, Overlay, Modify Track Defect List, F[PSctr/LBA],[Action]
Level 2 'H': Rev 0011.0000, Overlay, Select Logical Head, H[Hd],[SkType],[Options]
Level 2 'I': Rev 0011.0003, Overlay, Display / Modify Adaptive Parameter, I,[GroupId]
Level 2 'K': Rev 0011.0000, Overlay, Set Tracking Offset, K[OffsetValue],[PersOrTempOpt],[UnitsOpt],[ChanReload]
Level 2 'M': Rev 0012.0000, Overlay, Set Diag Idle Mode, M[ModeSelect],[ModeMask],[ResetToPowerOn]
Level 2 'N': Rev 0001.0000, Overlay, Set Direct Write Mode, N[EnableDirWrtModeOpt]
Level 2 'O': Rev 0011.0000, Overlay, Seek Repeatedly Between Physical Cylinders, O[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 2 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level 2 'Q': Rev 0011.0000, Overlay, Write, Read, Read CHS, Q[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'R': Rev 0011.0000, Overlay, Read CHS, R[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 2 'T': Rev 0013.0000, Overlay, Measure Throughput, T[Opts],[CylSkew],[HeadSkew],[MiniZoneSkew],[SkewStep],[LengthInTracks],[OffsetInTracks],[NumberOfRetries]
Level 2 'V': Rev 0011.0000, Overlay, Read Verify CHS, V[Sec],[NumSecs],[CompareBlk],[Opts]
Level 2 'W': Rev 0011.0000, Overlay, Write CHS, W[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'X': Rev 0011.0000, Overlay, Display Track Information, X[LogCyl],[Hd],[SysAreaOpt],[Opts],[RowsPerPage]
Level 2 'Y': Rev 0011.0000, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],[OtcTLevel],[Options]
Level 2 'a': Rev 0001.0000, Overlay, Measure Optimum Skew, a
Level 2 'c': Rev 0011.0000, Overlay, Buffer Compare, c[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level 2 'h': Rev 0011.0000, Overlay, Translate Physical Sector, h[Sec],[NumSecs]
Level 2 'i': Rev 0011.0000, Overlay, Display Defects On Current Track, i
Level 2 'j': Rev 0011.0000, Overlay, Read Wedge, j[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opts],[RegAddr0],...,[RegAddr13]
Level 2 'k': Rev 0001.0000, Overlay, Set User Cylinder/Head/MiniZone Skew, k[CylSkew],[HeadSkew],[MiniZoneSkew]
Level 2 'l': Rev 0011.0000, Overlay, Translate Logical Sector, l[Sec],[NumSecs]
Level 2 'o': Rev 0001.0000, Overlay, Corrupt LBA, o[Lba],[NumBlocks],[BurstSpan],[BurstOffset],[NumberOfRandomCorrupt],[Flags]
Level 2 'r': Rev 0011.0000, Overlay, Read Long CHS or Read System CHS, r[LongSec],[LongSecsOrSysSec],[SysSecs],[LongPhySecOpt],[LongOpts],[SysOpts]
Level 2 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 2 't': Rev 0011.0000, Overlay, Translate Wedge, t[Wdg],[NumWdgs]
Level 2 'u': Rev 0011.0000, Overlay, Enable/Disable Channel/Preamp Register Display, u[EnableDisableOpt]
Level 2 'v': Rev 0011.0000, Overlay, Convert Data Track Percentage To Servo Offset Count, v[Percentage]
Level 2 'w': Rev 0011.0000, Overlay, Write Long CHS or Write System CHS, w[LongSec],[LongSecsOrSysSec],[SysSecs],[LongPhySecOpt],,[SysOpts]
Level 2 'x': Rev 0013.0000, Overlay, Display Zone Information, x[Partition],[Hd],[Zone],[Options]
Level 2 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level 2 'z': Rev 0011.0001, Overlay, Write Wedge, z[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opt],[RegAddr0],...,[RegAddr13],[TSpacing]
Level 2 '7': Rev 0011.0000, Overlay, Write Verify CHS, 7[Sec],[NumSecs],[WrBufBlk],[Opts]
Level 3 'U': Rev 0011.0000, Flash,   Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 3 'V': Rev 0011.0000, Flash,   Read or Write Power ASIC Register, V[RegAddr],[RegValue],[WrOpt]
Level 3 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level 3 'D': Rev 0011.0000, Overlay, Measure Seek Access Time, D[SkLength],[SkType],[NumSks]
Level 3 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 3 'H': Rev 0011.0000, Overlay, Select Logical Head, H[Hd],[SkType],[Options]
Level 3 'O': Rev 0011.0000, Overlay, Seek Repeatedly Between Physical Cylinders, O[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 3 'Q': Rev 0011.0000, Overlay, Write, Read, Write, Read CHS, Q[Sec],[NumSecs],[Opts]
Level 3 'R': Rev 0011.0000, Overlay, Read Current Servo Destination, R
Level 3 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 3 'c': Rev 0001.0000, Overlay, Measure Latch Force, c[NumberOfSamples]
Level 3 'f': Rev 0013.0000, Overlay, Real Time Servo Trace, f[SubCmd],[SubPrm0],[SubPrm1],[SubPrm2]
Level 3 'p': Rev 0011.0000, Overlay, Translate Physical Sector, p[Sec],[NumSecs]
Level 3 'q': Rev 0011.0000, Overlay, Translate Logical Sector, q[Sec],[NumSecs]
Level 3 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 4 'B': Rev 0011.0000, Overlay, Enable / Disable RVFF, B[NewRvffControlMode]
Level 4 'D': Rev 0011.0000, Overlay, Measure Seek Access Time, D[SkLength],[SkType],[NumSks]
Level 4 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 4 'H': Rev 0011.0000, Overlay, Select Logical Head, H[Hd],[SkType],[Options]
Level 4 'K': Rev 0011.0000, Overlay, Set Tracking Offset, K[OffsetValue],[PersOrTempOpt],[UnitsOpt],[ChanReload]
Level 4 'O': Rev 0011.0000, Overlay, Display Micro Jog for Logical Cylinder and Head, O[LogCyl],[Hd],[Opts],[SysAreaOpt]
Level 4 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 4 'U': Rev 0011.0000, Overlay, Servo Batch Test sub commands, U[SubCmd],[SubCmdParm0],[SubCmdParm1],[SubCmdParm2]
Level 4 'c': Rev 0001.0000, Overlay, Find Min Or Max Cylinders c[Head],[Mode],[RangeMultiplier],[RetryCountLimit],[FilterTimeConstant]
Level 4 'd': Rev 0001.0000, Overlay, Display Servo Disc Slip
Level 4 'e': Rev 0011.0000, Overlay, Enable / Disable PES Output, e[PesLeftShiftCnt],[DisablePesOut]
Level 4 'g': Rev 0001.0000, Overlay, Display Servo Sector Error Log, g
Level 4 'k': Rev 0001.0000, Overlay, Get VGA Data, k[OpType],[StartHt],[EndHt],[HtInc]
Level 4 'l': Rev 0011.0000, Overlay, Scan Track for Servo Defects and ZAP, l[RdPositionOpt]
Level 4 'q': Rev 0001.0000, Overlay, Display Servo Event Log, q
Level 4 's': Rev 0001.0000, Overlay, Display Servo Sector Error Count, s
Level 4 't': Rev 0011.0000, Overlay, Display / Modify ZAP Table, t[EntryNum],[EntryValue]
Level 4 'u': Rev 0011.0000, Overlay, Set Seek Speed, u[Opts],[SkSpeed]
Level 4 'v': Rev 0011.0000, Overlay, Butterfly Seek Test, v[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 5 'S': Rev 0011.0000, Flash,   Enter Servo Matlab Shell, S
Level 5 'B': Rev 0011.0000, Overlay, Servo Bode Plot, B[BodeType],[InjAmp],[Fmin],[Fmax],[NumFreq],[NumSamples],[EnableTracing]
Level 5 'C': Rev 0011.0000, Overlay, Generic Servo Command, C[CmdNum],[Parm1],...[Parm7]
Level 5 'D': Rev 0011.0000, Overlay, Read / Unlock DDR Buffer, B[OperateCode]
Level 5 'E': Rev 0001.0000, Overlay, Measure Disc Eccentricity
Level 5 'G': Rev 0011.0000, Overlay, Select Servo Controller, G[Head],[Controller],[InputShift]
Level 5 'K': Rev 0001.0000, Overlay, Servo Disc Slip, K [OperationSelectId]
Level 5 'R': Rev 0011.0000, Overlay, Read Servo RAM at Address, R[Addr],[NumBytes]
Level 5 'U': Rev 0011.0000, Overlay, Enable / Disable Servo Updates, U[VcmDacUpdateOpt],[AToDUdateOpt]
Level 5 'W': Rev 0011.0000, Overlay, Write Servo RAM at Address, W[Addr],[NumBytes],[Data]
Level 5 'Z': Rev 0011.0000, Overlay, Read Zap from Disc to Table, Z
Level 5 'd': Rev 0011.0000, Overlay, Disable / Enable Servo ZAP coefficients and ZAP read, d[ZapControlMode]
Level 5 'e': Rev 0001.0000, Overlay, Enable / Disable Shock Sensor, e[Operation]
Level 5 'i': Rev 0011.0000, Overlay, Read Servo Symbol Table at Index, i[Index]
Level 5 'r': Rev 0011.0000, Overlay, Read Servo RAM at Index, r[Index],[NumBytes],[ByteOffset]
Level 5 'w': Rev 0011.0000, Overlay, Write Servo RAM at Index, w[Index],[NumBytes],[Data],[ByteOffset]
Level 6 'B': Rev 0011.0000, Overlay, Run Batch File, B[BatchFileNum],[DisplayOpt]
Level 6 'D': Rev 0011.0000, Overlay, Display Batch File, D[BatchFileNum]
Level 6 'E': Rev 0011.0000, Overlay, Enter Batch File, E[BatchFileNum]
Level 7 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level 7 's': Rev 0011.0000, Flash,   Write Peripheral Register - channel or preamp, s[OpType],[RegAddr],[RegValue],[RegMask],[RegPagAddr]
Level 7 't': Rev 0011.0000, Flash,   Write Peripheral Register - channel or preamp, t[OpType],[RegAddr],[NumRegs],[RegMask],[RegPagAddr]
Level 7 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 7 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level 7 'D': Rev 0012.0000, Overlay, Display Temperature, D,[DevSelect]
Level 7 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 7 'H': Rev 0011.0000, Overlay, Select Logical Head, H[Hd],[SkType],[Options]
Level 7 'I': Rev 0011.0003, Overlay, Display / Modify Adaptive Parameter, I,[GroupId]
Level 7 'K': Rev 0011.0000, Overlay, Set Track Format, K[UserAreaTrkFormatType],[SysAreaTrkFormatType]
Level 7 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level 7 'Q': Rev 0011.0000, Overlay, Write, Read, Read CHS, Q[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'R': Rev 0011.0000, Overlay, Read CHS, R[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 7 'U': Rev 0011.0001, Overlay, Channel Temperature Adjust, U[TweakTemperature],[Partition],[Hd],[Zone],[Opts]
Level 7 'W': Rev 0011.0000, Overlay, Write CHS, W[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'X': Rev 0011.0000, Overlay, Display Preamp Head Resistance
Level 7 'Y': Rev 0011.0000, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],[OtcTLevel],[Options]
Level 7 'b': Rev 0011.0000, Overlay, Erase Track, b[AdjacentTrkCnt],[EraseCntPerTrk],[AcEraseOpt]
Level 7 'c': Rev 0011.0000, Overlay, Off Track Capability, c[Sec],[NumSecs],[SecIncrement],[Offset]
Level 7 'h': Rev 0011.0001, Overlay, Mark Media Flaw, h[PhyCyl],[Hd],[PhySec],[UndisturbedRadius],[EraseBandTrks],[PtrLen],[WgSpec],[Od/Id]
Level 7 'i': Rev 0011.0000, Overlay, Generic Read/Write Request, i[Parm0],[Parm1],[Parm2],...[Parm9]
Level 7 'm': Rev 8003.0000, Overlay, Display Single Track Directed Offline Scan Information, m[clr,min scn]
Level 7 'r': Rev 0011.0000, Overlay, Read Non-Volatile Adaptive Parameters, r[Opts]
Level 7 'u': Rev 0011.0000, Overlay, Enable/Disable Write Fault, u[Op]
Level 7 'w': Rev 0011.0000, Overlay, Save Adaptives To Flash, w[Seg],,22
Level 7 'x': Rev 0013.0000, Overlay, Display Zone Information, x[Partition],[Hd],[Zone],[Options]
Level 7 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level 8 'U': Rev 0011.0000, Flash,   Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 8 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level 8 'C': Rev 0011.0000, Overlay, Servo Diag Sub Cmds, C[SubCmd],[Parm0],[Parm1],[Parm2]
Level 8 'R': Rev 0011.0000, Overlay, Read Current Servo Destination, R
Level 8 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 8 'd': Rev 0001.0000, Overlay, Head Smash Test, d[HeadDirection],[AccelerationDuration],[DecelerationDuration],[AccelerationCurrent],[DecelerationCurrent]
Level A 'C': Rev 0011.0000, Overlay, Translate PBA, C[PbaHi],[PbaLow],[NumPbas]
Level A 'D': Rev 0011.0000, Overlay, Translate Symbols From Index, D[PhyCyl],[Hd],[Sfi],[NumSfis]
Level A 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level A 'F': Rev 0011.0000, Overlay, Translate LBA, F[LbaHi],[LbaLo],[SysAreaOpt],[NumLbas]
Level A 'M': Rev 0011.0000, Overlay, Set Controller Test Port, M[Port],[Value]
Level A 'P': Rev 0012.0000, Overlay, Merge Alt List into Slip List, P
Level A 'Q': Rev 0011.0000, Overlay, Write, Read, Read LBA, Q[Lba],[NumLbas],[Opts]
Level A 'R': Rev 0011.0000, Overlay, Read LBA, R[Lba],[NumLbas],,[Opts]
Level A 'S': Rev 0011.0000, Overlay, Seek to LBA, S[LbaHi],[LbaLo],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level A 'W': Rev 0011.0000, Overlay, Write LBA, W[Lba],[NumLbas],,[Opts]
Level A 'Y': Rev 0011.0000, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],[OtcTLevel],[Options]
Level A 'c': Rev 0011.0000, Overlay, Translate Logical Cylinder, Logical Head and Logical Sector, c[Cyl],[Hd],[Sec],[SysAreaOpt],[NumSecs]
Level A 'd': Rev 0011.0000, Overlay, Translate Physical Cylinder, Logical Head and Physical Sector, d[Cyl],[Hd],[Sec],[NumSecs]
Level A 'e': Rev 0011.0000, Overlay, Translate Nominal Cylinder and Logical Head, e[Cyl],[Hd],[Sec],[SysAreaOpt]
Level A 'f': Rev 0011.0000, Overlay, Translate Physical Cylinder, Logical Head and Physical Wedge, f[Cyl],[Hd],[Wdg],[NumWdgs]
Level A 'l': Rev 0011.0000, Overlay, Display Track Information, l[LogCyl],[Hd],[SysAreaOpt],[Opts],[RowsPerPage]
Level A 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level C 'Q': Rev 0001.0000, Overlay, Display ASCII Command Information, Q[CmdLevel],[Cmd]
Level C 'T': Rev 0011.0000, Overlay, Goop Plot, T[Hd],[StartTrk],[EndTrk],[ECCLvl],[NoFrcSync],[SkipCnt]
Level E 'B': Rev 0011.0001, Overlay, Write Wedge, B[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opt],[RegAddr0],...,[RegAddr13],[TSpacing]
Level E 'C': Rev 0011.0000, Overlay, Read Wedge, C[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opts],[RegAddr0],...,[RegAddr13]
Level E 'G': Rev 0001.0000, Overlay, HeadDegradation, G[OperationControlOptions],[MeasurementControlOptions]
Level E 'd': Rev 0001.0000, Overlay, SQMS Dibit Optimization, d[OptiAlgorithm],[LATE01 NOMR/F],[SweepStartVal],[SweepEndVal],[IterationCnt],[Verbose]
Level E 'm': Rev 0011.0000, Overlay, Fast MSESER Measurement, m[]
Level E 'n': Rev 0001.0000, Overlay, Dibit Extraction, n[sctr],[cnt],[dibit],[dibit],[dibit],[skip],[trim],[dsply]
Level E 'o': Rev 0011.0000, Overlay, Fine RW Offset Measurement, o[NumAvgs],[TrkStepSize],[NumGuardTrks]
Level E 'w': Rev 0011.0001, Overlay, Slow Write CHS, w[Sec],[NumSecs],[ConSec],[Skip],[UnitOfSkip]
Level F 'U': Rev 0011.0000, Flash,   Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level F 'Z': Rev 0011.0000, Flash,   Spin Down Drive, Z
Level F 'b': Rev 0011.0000, Flash,   Set Baud Rate, b[BaudRate],[MsecDelay]
Level F 't': Rev 0011.0000, Flash,   Write Peripheral Register - channel or preamp, t[OpType],[RegAddr],[RegValue],[RegMask],[RegPagAddr]
Level F 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level F 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level F 'D': Rev 0011.0001, Overlay, Memory Block Display, D[AddrHi],[AddrLo],[CompVal],[NumBytes],[Opts],[SizeInBytes]
Level F 'E': Rev 0001.0000, Overlay, Symbol Error Map, E[trk],[hd],[srt sctr],[sctr cnt],[action],[mx err]
Level F 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level F 'V': Rev 0011.0000, Overlay, Buffer Compare, V[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level F 'Y': Rev 0011.0000, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],[OtcTLevel],[Options]
Level F 'r': Rev 0011.0000, Overlay, Read System CHS, r[LogSec],[NumSecs],[Opts]
Level F 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level F 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level F 'z': Rev 0011.0000, Overlay, SataDebug, z[SubCmd],[Parm1],[Parm2],[Parm3]
Level G 'B': Rev 0011.0000, Overlay, Fill Correction Buffer, B[StartAddr],[EndAddr],[Pattern],[Opts]
Level G 'C': Rev 0011.0000, Overlay, Copy Correction Buffer, C[SrcAddr],[DestAddr],[NumSyms]
Level G 'D': Rev 0011.0000, Overlay, Display Correction Buffer, D[StartAddr],[EndAddr],[CompareData]
Level G 'F': Rev 0011.0000, Overlay, Fill Super Parity RAM, F[StartAddr],[EndAddr],[Pattern]
Level G 'G': Rev 0011.0000, Overlay, Display Super Parity RAM, G[StartAddr],[EndAddr]
Level H 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level H 'D': Rev 0001.0000, Overlay, Field Adjust Fly Height, c[Flags],[NumCollectionsToAvg],[PctOfBpiLowFreq],[PctOfBpiHighFreq],[PctOfTgtClr],[CTFFR],[ATT2R],[VgaLowFreq],[VgaHighFreq],[StartHtr],[EndHtr],[HtrIncr],[StartPreHtr],[ContactDac],[NumPreHeatSects],[NumPreChanCollectHeatSects],[NumChanCollectHeatSects],[NumPostChanCollectHeatSects],[HscIntgLength],[ChannelPreheatRevs]
Level H 'F': Rev 0002.0002, Overlay, Modulation Detection Contact Detect, F[Flags],[NumRevsToAvg],[PctOfBpi],[HscIntgLength],[PatternSelect],,[CTFFR],[ATT2R],[VGA],[StartHtr],[EndHtr],[HtrIncr],[StartPreHtr],[NumPreHeatSects],[NumPreChanCollectHeatSects],[NumChanCollectHeatSects],[NumPostChanCollectHeatSects],[CoarseSearchStartClr],[FineSearchStartClr],[ContactSearchLimitClr]
Level H 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level H 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level H 'b': Rev 0013.0000, Overlay, Contact Detect, b[Flags],[Revs],[BaselineRevs],[StartWedge],[A],[B],[C],[D],[E],[StartHt],[HtInc],
[FixedPESThresh],[FilterDelta],[RangeStart],[RangePts],[AdjThreshSigmaLimit],[VarContactThreshBackup]
Level H 'c': Rev 0003.0000, Overlay, Calibrate Clearance Coefficients Adjustment, c[Flags],[NumRevsToAvg],[PctOfBpi],[PctOfTgtClr],[LowerHIWPLimit],[UpperHIWPLimit],[CTFFR],[ATT2R],[VGA],[StartHtr],[EndHtr],[HtrIncr],[StartPreHtr],[NumPreHeatSects],[NumPreChanCollectHeatSects],[NumChanCollectHeatSects],[NumPostChanCollectHeatSects],[HscIntgLength]
Level L 'C': Rev 0011.0000, Overlay, Copy Log File, C[SrcLog],[DestLog],[AppendOpt]
Level L 'D': Rev 0012.0000, Overlay, Display Log File, D[Log],[ErrCode]
Level L 'E': Rev 0011.0001, Overlay, Enable / Disable Logging, E[ErrLoggingOpt],[AsciiLoggingOpt],[RwStatsLoggingOpt]
Level L 'I': Rev 0011.0000, Overlay, Display Log FileInfo, I[Log]
Level L 'c': Rev 0011.0000, Overlay, Create Log File, c[Log],[LogType],[BufferOrDiskOpt],[NumBytes]
Level L 'd': Rev 0011.0000, Overlay, Delete Log File, d[Log]
Level L 'i': Rev 0011.0000, Overlay, Initialize Log File, i[Log]
Level M 's': Rev 0001.0000, Overlay, Serial Port Test Results, s[Sub-command],[SptIndex],[ValidKey]
Level T 'B': Rev 0011.0000, Flash,   Set Baud Rate, B[BaudRate],[MsecDelay]
Level T 'm': Rev 0012.0803, Flash,   Format Partition, m[Partition],[FormatOpts],[DefectListOpts],[MaxWrRetryCnt],[MaxRdRetryCnt],[MaxEccTLevel],[MaxCertifyTrkRewrites],[ValidKey],[DataPattern]
Level T 'E': Rev 0012.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level T 'F': Rev 0011.0000, Overlay, Display / Modify Congen, F[ValueRef],[Data],[ResetEnable]
Level T 'J': Rev 0011.0001, Overlay, Display / Modify CAP, J[ParmValue],[ParmId],[ParmArrayBytes],[ParmByteArrayOffset]
Level T 'O': Rev 0001.0000, Overlay, Select Data Output Mode, O[Mode],[VerboseOpts]
Level T 'P': Rev 0011.0000, Overlay, Download Generic File, P[FileBytes]
Level T 'R': Rev 0011.0000, Overlay, Read Non-Volatile Adaptive Parameters, R[Opts]
Level T 'T': Rev 0011.0000, Overlay, Odd Even Encroachment Test, T[strt tk],[end tk],[hd],[rtry thrshld][ECC thrshld
Level T 'V': Rev 0015.0000, Overlay, Display Defect Lists, V[ListMask],[Hd],[StartCyl],[NumCyls],[Summary],[FlagsMask]
Level T 'W': Rev 0011.0000, Overlay, Save Adaptives To Flash, W[Seg],,22
Level T 'i': Rev 0011.0002, Overlay, Initialize Defect List, i[DefectListSelect],[SaveListOpt],[ValidKey]
Level T 'r': Rev 0001.0000, Overlay, Read File, r[FileId],[VolumeNum],[CopyNum],[ByteOffset],[Length],[OutputFmt]
Level T 'w': Rev 0001.0000, Overlay, Write File, w[FileId],[VolumeNum],[CopyNum],[ByteOffset]
Level T '[': Rev 0011.0000, Overlay, ASCII Log Control, [[LogFunction],[Log]
F3 C>
September 5th, 2019, 4:40
Does anyone have any idea/clue/whispered-codeword-advice where I could start investigate the problem? Just a lead...
September 5th, 2019, 16:57
Try the "F" commands in the following thread:
http://www.hddoracle.com/viewtopic.php?f=59&t=1842&start=60
Hopefully they will stabilise the drive enough so that you can clone it.
WARNING: The commands are Case Sensitive.
September 7th, 2019, 8:03
Thank you a lot fzabkar!! I will have a look at it asap.
September 9th, 2019, 17:35
A small success!!
@fzabkar, to you my sincerest thanks for your help.
On the right way! Hard to believe.. my hopes were almost entirely gone.
maximus wrote:Try cloning/imaging with HDDSuperClone for about 5 minutes or so, stop it and attach the log here.
Sweat and blood went into this :lol:
# Disk progress log file created by HDDSuperClone version 2.1.13_20190804
# 2019-09-09_23.18.42.663669
# command= hddsuperclone
# Logfile: /media/lubuntu/Storage/HddSuper/okk
# 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ................
#      Source:   /dev/sdb (STM3320418AS, 6VMAFKDM)
# #Destination: /media/lubuntu/Storage/HddSuper/image (, )
#   Total LBA:  625142448        LBA to read:  625142448
#    Run time: 0:00:05:28        Remaining:   0:13:32:23
#        Rate:          0 B/s    Recent: 6525 KB/s  Total: 6137 KB/s
#   Skip size:       4096  Skips: 7  Slow: 6  Runs: 0  Resets: 0  Run size: 0
#    Position:    3969664        Status:    Phase 1
#    Finished:    3931648 (14 areas 0.628920%)
#   Non-tried:  621210672 (8 areas 99.371063%)
# Non-trimmed:        128 (1 areas 0.000020%)
# Non-divided:          0 (0 areas 0.000000%)
# Non-scraped:          0 (0 areas 0.000000%)
#         Bad:          0 (0 areas 0.000000%)
################ START CONFIGURATION DATA ################
# startconfig
# logfile     /media/lubuntu/Storage/HddSuper/okk
# source     /dev/sdb
# destination     /media/lubuntu/Storage/HddSuper/image
# verbose     0x0
# debug     0x0
# forcemounted     0
# forcedangerous     0
# importdd     0
# exportdd     0
# dodomain     0
# domaindd     0
# domainfile     /media/lubuntu/Storage/HddSuper/okk.domain
# repairlog     0
# nologbackup     0
# phaselogs     0
# softtimer     8000000
# hardtimer     800000
# busytimer     20000000
# initbusytimer     8000000
# resettimer     8000000
# generaltimer     60000000
# phasetimers     0
# p12softtimer     250000
# p3softtimer     350000
# p4softtimer     500000
# tdsofttimer     800000
# d2softtimer     800000
# scsofttimer     800000
# rtsofttimer     8000000
# usbbulkreset     1
# usbsoftreset     1
# usbhardreset     1
# usbportreset     1
# imagesource     0
# genericsource     0
# atapass     1
# scsipass     0
# skipfast     0
# skiptimer     1000000
# direct     0
# ahci     0
# usb     0
# resetstatus     0
# nophase1     0
# nophase2     0
# nophase3     0
# nophase4     0
# notrim     0
# nodivide1     0
# dodivide2     0
# notrim     0
# noscrape     0
# markbadhead     0
# readbadhead     1
# clustersize     128
# blocksize     1
# sectorsize     512
# blockoffset     0
# retries     0
# retried     0
# inputoffset     0
# outputoffset     -1
# size     625142448
# rateskip     50000
# exitonslow     -1000
# exitonslowtime     -1000
# minskip     4096
# maxskip     6251424
# reverse    0
# fillmode     0
# fillmark     0
# findserial
# quiet     0
# forcestupid     0
# model     STM3320418AS
# serial     6VMAFKDM
# skipsize     4096
# skips     7
# slowskips     6
# skipruns     0
# skipresets     0
# stoponerror     0
# callcommand     0
# commandtocall
# primaryrelayonerror     0
# callpowercommand     0
# powercommandtocall
# primaryrelaypowercycle     0
# writebufferdisable     0
# writebufferenable     0
# driverreturnerror     0
# driverreturnzeros     0
# driverreturnmarked     0
# driverdiskname     sdv
# driverminclustersize     1
# piomode     0
# enableprocesschunk     0
# enablescsiwrite     0
# sectorsizeadjust     0
# usephysicalsectorsize     0
# colorstatusbar     0
# primerelayactivatetime     3
# primerelaydelaytime     15
# primerelaysettings     0xff00
# endconfig
################ END CONFIGURATION DATA ################
################ START IDENTIFY DEVICE INFO ################
# 0: 5a 0c ff 3f 37 c8 10 00 00 00 00 00 3f 00 00 00 Z..?7.......?...
# 10: 00 00 00 00 20 20 20 20 20 20 20 20 20 20 20 20 ....
# 20: 56 36 41 4d 4b 46 4d 44 00 00 00 80 04 00 43 43 V6AMKFMD......CC
# 30: 38 33 20 20 20 20 54 53 33 4d 32 33 34 30 38 31 83    TS3M234081
# 40: 53 41 20 20 20 20 20 20 20 20 20 20 20 20 20 20 SA
# 50: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 10 80               ..
# 60: 00 00 00 2f 00 40 00 02 00 02 07 00 ff 3f 10 00 .../.@.......?..
# 70: 3f 00 10 fc fb 00 10 01 ff ff ff 0f 00 00 07 00 ?...............
# 80: 03 00 78 00 78 00 78 00 78 00 00 00 00 00 00 00 ..x.x.x.x.......
# 90: 00 00 00 00 00 00 1f 00 06 05 00 00 48 00 40 00 ............H.@.
# a0: f0 01 29 00 6b 34 01 7f 63 41 29 34 01 be 63 41 ..).k4..cA)4..cA
# b0: 7f 40 1f 00 1f 00 00 00 fe ff 00 00 00 fe 00 00 .@..............
# c0: 00 00 00 00 00 00 00 00 b0 ea 42 25 00 00 00 00 ..........B%....
# d0: 00 00 00 00 00 00 00 00 00 50 00 c5 17 1f fc 19 .........P......
# e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1e 40 ...............@
# f0: 1c 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .@..............
# 100: 29 00 b0 ea 42 25 b0 ea 42 25 20 20 02 00 40 01 )...B%..B%  ..@.
# 110: 00 01 00 50 06 3c 0a 3c 00 00 3c 00 00 00 08 00 ...P.<.<..<.....
# 120: 00 00 00 00 4f 00 80 02 00 00 00 00 08 00 00 00 ....O...........
# 130: 00 00 00 00 00 00 00 00 00 00 00 00 00 3f 00 98 .............?..
# 140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 190: 00 00 00 00 00 00 00 00 00 00 00 00 3f 10 00 00 ............?...
# 1a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1b0: 00 00 20 1c 00 00 00 00 00 00 00 00 10 10 00 00 .. .............
# 1c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
# 1f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 a5 1e ................
# lba supported = yes
# 48 bit supported = yes
# smart supported = yes
# smart enabled = yes
# security locked = no
################ END IDENTIFY DEVICE INFO ################
# current position         status
0x3c9280               0x0
# position    size        status    info    err/status/time
0x000000    0x005880    0x7f    0x0    0x0
0x005880    0x000080    0x7f    0x80    0x5002
0x005900    0x001000    0x0    0x0    0x0
0x006900    0x00a880    0x7f    0x0    0x0
0x011180    0x000080    0x7f    0x80    0x5001
0x011200    0x001000    0x0    0x0    0x0
0x012200    0x043980    0x7f    0x0    0x0
0x055b80    0x000080    0x10    0x80    0x3110405
0x055c00    0x001000    0x0    0x0    0x0
0x056c00    0x235a80    0x7f    0x0    0x0
0x28c680    0x000080    0x7f    0x80    0x5003
0x28c700    0x001000    0x0    0x0    0x0
0x28d700    0x003080    0x7f    0x0    0x0
0x290780    0x000080    0x7f    0x80    0x5001
0x290800    0x001000    0x0    0x0    0x0
0x291800    0x000800    0x7f    0x0    0x0
0x292000    0x000080    0x7f    0x81    0x5001
0x292080    0x001c01    0x0    0x0    0x0
0x293c81    0x000400    0x7f    0x0    0x0
0x294081    0x000080    0x7f    0x82    0x5001
0x294101    0x0027ff    0x0    0x0    0x0
0x296900    0x132980    0x7f    0x0    0x0
0x3c9280    0x25065830    0x0    0x0    0x0
September 9th, 2019, 19:26
Initial analysis is that it does not show a dead or totally weak head. But it may be reading a bit slow, maybe in one head. There is good recovery potential, as long as any physical damage does not get worse. It could die at any time, or it could be a very productive recovery.
