Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Advice with ROM swap on 2T FireCuda SSHD ST2000LX001 ...
PostPosted: August 10th, 2019, 4:34
but Doomer is correct, this particular drive is not recoverable.
I would argue with that.
No bitcoin donations :)
PostPosted: August 12th, 2019, 15:09
I ran two tests where I incrementally increased the mechanical pressure to the top of the nand chip. This test was to rule out that there was a bad solder joint under the nand. The device behavior was unchanged so I am ruling out a bad nand bga solder joint as the cause of failure.
PostPosted: August 12th, 2019, 16:56
you should be very careful with donor rom...i had some chips what have exactly same text,but diffrent data writen on them..thx to this i accidentally destroyed few hdd data recovery chances completely..always read chip with reader,i do it..
PostPosted: September 11th, 2019, 5:59
Regarding PC3000 support of Firecuda LX, I enquired with Ace TS as I have a ST1000LX015 in which requires access to the SA. The standard unlock functions within PC3000 do not currently allow access to TechMode/F3 T.
The response from Ace on 2 September 2019 was simply:
Hello John,
Unfortunately this model is not supported via PC-3000 yet.
Nothing to advise at the moment. Thanks for understanding.
Best regards,
Sergey
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
PostPosted: September 25th, 2019, 4:41
I am in the exact same place as the OP.
Drive does not spin, same board revision, serial port gives me the exact same message
Boot 0x80M
           DensityList:0x0000
PrgF
LED:0x000000BD FAddr:0x000059D8
Any updates on this?
PostPosted: September 25th, 2019, 14:43
i doubt anybody will tell you the precise cause of that error, it needs to be researched on my side. I won't do any research unless i do the recovery. This probably applies to the few people able to deal with these drives...
PostPosted: September 25th, 2019, 16:53
Same as before
Some people can fix, some can't.
No commercial tools available so far.
Outsource is your friend
PostPosted: September 25th, 2019, 21:16
I have most of my important data backed up so I don't really mind losing the drive.
Doing this just for fun and getting some insider knowledge so I don't mind trying something potentially destructive.
PostPosted: September 26th, 2019, 6:34
I think you are alone then... Nobody would invest time in your entertainment.
PostPosted: September 26th, 2019, 11:49
Let us know how it goes
PostPosted: February 11th, 2020, 6:07
johnnyBrandom, Hey mate do you recover successfully your st2000lx001 drive?
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 66 guests
