Forum rules
No new topics are allowed in this forum. Please use other forums to create topics.
Post new topic Reply to topic  [ 96 posts ]  Go to page Previous  1, 2, 3, 4, 5
 Post subject: Re: HowTO How To replace Maxtor Calypso III board
PostPosted: May 9th, 2008, 10:30
Rameez, Can you suggest anyplace where i can buy some of these 'smooth' chips? I often need them for Maxtor and WD drives with burnt motor controller chips.
Thanks.
PostPosted: January 31st, 2010, 14:52
Hi everyone!
I have a fried DiamondMax Plus 9 200GB ATA 133 (disks not spinning at all)
YAR41BW0 Firmware F8FYA
I tried to swap with a pcb of a DiamondMax Plus 9 80GB ATA 133 but with another firmware version
The fried disk now is "alive", it starts spinning but after let's say 10-20 seconds it starts to click and Bios doesn't recognize it at all
So I restored the working pcb back to its orginal owner (the 80GB one) and it worked, this pcb has not been damaged.
Does this mean I have no preamp problems with the dead hard disk and should only be a pcb problem?
Just to know, since I already ordered a new matching pcb
Thanx!
Pietro
PostPosted: January 31st, 2010, 14:57
Hi
This test doesn't shows exactly your preamp's condition.
If you want to get a compatible pcb, you should match this:
F8FYA + the 4 letter code on the top lid.
No more needed.
If your drive still clicking, then the preamp is dead.
Janos
PostPosted: February 1st, 2010, 4:01
Sorry for my noob question but I AM a noob with HDs...
I'm worried about the reason why my HD looks dead. If I have any chance to recover data.
This is exactly what happened...
I wrongly plugged the power connector, and 'till that moment the disk was fully functionally
After that, platters didn't spin anymore, so I thought about a power fault.
I swapped the pcb, but I don't remember the firmware version, so I can't confirm right now if it was compatible or not.
By the way platters started to spin again, with bad click noises, but not fast repeating clicks.
I read lots of post but I preferred to directly show my issue.
Can a power failure like mine damage head and/or preamp? HD was fully functionally before I wrongly connected the power molex.
I'm scared of the click of death O_O
Thanx thanx thanx
PostPosted: February 1st, 2010, 4:38
Online
yes, in your case it is highly probable that preamp is dead since when you pluged the power connector reversed(if it is what you meant by 'wrongly'), the preamp received 12V instead of 5V alimentation and this causes fatal damage surely.
If the data is important you should stop DIY right now and take it to a pro.
No bitcoin donations :)
PostPosted: February 1st, 2010, 5:36
exactly, as you said, I meant reversed.
I thought there was some kind of protection circuit which prevents damage to the inner circuits.
I'll prepare a grave for my poor HD
thank you guys for your help
PostPosted: February 5th, 2010, 6:16
Yesterday I gave a try swapping 2 not compatible PCBs between 2 Maxtor DiamondMax Plus 10
Donor (the working one)
6L200M0
BANC1G10
F/W: R3GLA
SABRE/ROHS
Receiver (with spinning platters only, head doesn't move at all, hdd not detected)
6B250S0
BANC1980
F/W: R6GBP2
SABRE/RC2
Receiver's platters started to spin, after that the head started to move and make the EXACT noise I hear from my not working DiamondMax Plus 9 of some post above.
Having this situation, can I suppose (not be sure, just suppose) the problem of my DiamondMax Plus 9 is just the pcb (since I could only try a not compatible pcb, and the head was clicking, trying to setup, or whatever) and not some internal damage?
PostPosted: February 8th, 2010, 10:20
try to be sure about your donor pcb before trying it on the patient drive.
PostPosted: February 13th, 2010, 13:13
Hi guys here I am again
I'm going crazy trying to get more info from my dead hdd...
The bios recognize it as MAXTOR CALYPSO
If I set the drive as master, it starts clicking
When slave, no clicks
I read posts regarding how to check the preamp with a multimeter in diode mode and this is my case:
3/9 GND
4/9 -5 --- 0 ohm
5/9 +5 --- 166 ohm
So I guess I have a dead preamp.
But still I read from the various posts if the preamp is dead, each donor pcb I try to swap will be burned...
But my donor pcb still works
Should I definitively give up?
PostPosted: February 14th, 2010, 2:16
Go to a pro.
PostPosted: February 14th, 2010, 4:12
You should give up DIY, and seek for a pro as Mr.Rameez said.
Would suggest you contact
the forum member: dobrevjetser
He is from your country and a highly recommended pro.
PostPosted: February 14th, 2010, 6:37
Yes, agree.
Contact dobrevjetser
PostPosted: July 27th, 2015, 10:30
PostPosted: May 25th, 2020, 8:39
I know this topic is rather somewhat too old
However I couldnt start a new topic
I have a Maxtor DiamondMax 16 80GB ATA/133 HDD
Code RAMB1TU0
SN:R2124TRE
4R080J0220211
I attached the power cable while the PC was powered on
and I beilive that the pcb is fired and I need to replace it please help me what numbers are the most important for a replacement
thx
PostPosted: May 25th, 2020, 11:03
woshka,
Dear Mr. Robert,...
here is the paragraph that deals with your model type (DiamondMax Plus 9):
For the following Maxtor hard drive models: Fireball 3, DiamondMax 16, DiamondMax Plus 8, DiamondMax Plus 9, Diamond Max 10 and all MaxLine products there is also a GTLA Number on the model (next to barcode on the bottom of the drive). Format 1Y222J2223322. 1, 2 and 3 stand for numbers, Y and J for letters.
The numbers 1 and 3 as well as the letter Y need to be identical to be able to replace the PCB on these drives.
This number can be found on the large sticker on the top of the drive.
Unfortunately we can not give you any more information than this. Any of your DiamondMax Plus 9 drives could possibly have a matching PCB, however it is most likely to be an older one as the drive in question is almost 3 years old.
Kind regards,
Gisela Schubert
Technical Support
Maxtor Ireland Ltd.
Users browsing this forum: No registered users and 0 guests
