Post new topic Reply to topic  [ 984 posts ]  Go to page Previous  1 ... 46, 47, 48, 49, 50
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: September 26th, 2019, 15:45
I just want to say thank you !!!!! :D
This script http://www.hddoracle.com/viewtopic.php?f=113&t=1815 worked with hd204ui.
PostPosted: February 16th, 2020, 7:00
Thanks a lot
PostPosted: May 6th, 2020, 7:49
Wanted to say thanks as well, this thread helped me unlock an age old drive from my neighbor.
The drive with the unknown ata password was a WD 2500 bevt from 2009.
Here's a quick write up, of what I did, you can find all the tools mentioned here:
https://github.com/wschopohl/wdatapwd
[On another windows machine] I created a bootable usb stick with HPUSBFW_v2.2.3.exe and copied the unzipped MHDD directory on it.
I disabled AHCI in bios, then I booted from usb without the hdd (bios would freeze on password screen otherwise) and connected the hdd via sata once DOS was booted up.
Started MHDD.exe, selected correct drive with "Shift + F3" (for me it was 6). Then "F2" for scan drive, reported some information about the drive and that it was locked by ATA password. Executed .dump script which created 21.bin and 22.bin. Unplugged the stick (didn't even bother to shut down) and put it in a working laptop. Opened 22.bin with a hexeditor (I put 22.bin in the github repo as well, if you want to follow along). Search for this sequence "01 07 00" and found it at position 0x10F (your position might be different though). The next 32 bytes looked like this: "30 00 16 00 26 00 26 00 1F 00 23 00 17 00 14 00 00 ...". Ignoring all the zeros I got this: "30 16 26 26 1F 23 17 14". Then using MSKeyLog.TXT I converted all the numbers to letters, in my case it spells "BULLSHIT" and used the lower case version "bullshit" successful as user password!
One side note: For whatever reason I wasn't able to use the password with the MHDD unlock command, but the password was accepted by the bios hdd password unlock screen. And don't forget to turn AHCI back on if you turned it off, my Windows wouldn't start otherwise.
PostPosted: May 30th, 2020, 10:53
hddguy wrote:
rockhound wrote:
I have my hard drive locked by ATA password with an unknown reason.
MHDD mentioned, "WARNING : tHIS DRIVE IS LOCKED BY ATA PASSWORD".
The locked Hard Drive is WDC WD2500JB-00GVC0
SN : WD-WCAL78032380
Do you guys have any idea of how to unlock the drive without paying $50?
ALL my important files are buried in there.
If you know the password, use MHDD to remove. If you do not know it, it needs to be unlocked professionally. Send to a specialist. If data is not worth more than $50, then you should consider it lost forever.
As they are people, I ran into a WD disk that had a hardware password (ATA PASSWORD) in my opinion since it could not do anything, not even give it a low format (Low Level Format) to try to break the password and looking for all the forums even in russian language, I came across a program with which I could remove it without problems, as if it were a master key ..
I leave the link of the video for those who still could not solve it ..
https://stfly.io/AFMpVs
I hope it serves you like me .. Greetings
Como están gente, me tope con un disco WD que tenia contraseña por hardaware (ATA PASSWORD) a mi parecer ya que no podia hacer nada, ni siquiera darle un formato bajo (Low Level Format) para intentar romper la contraseña y buscando por todos los foros hasta en idioma ruso, me tope con un programa con el cual pude sacarle sin problemas, como si fuera una llave maestra..
Les dejo el link del vídeo para aquellos que aun no pudieron solucionarlo..
Espero les sirva como a mi.. Saludos
Users browsing this forum: Bing [Bot], Google [Bot], jono-ats, pepe and 45 guests
