LarrySabo wrote:
@bledaone, the message you replied to is 4 years old! However, yes, SRP can work on USB drives connected to a PC that SRP is also connected to -- if the USB drive is detected and doesn't cause Windows to freeze. If it is unstable, it would be best to transfer the USB drive's ROM to a compatible SATA PCB and fix firmware issues and clone the drive. The clone will likely be encrypted but the SRP can usually decrypt it directly.
Yes, because I just researched Deepspar USB Stabilizer and found your post in your blog recently, hehe. This answer clears my doubt, thanks a lot, Larry
