 Post subject: Truly professional method!
PostPosted: November 9th, 2020, 3:20
This is truly professional extraction of Data from HDD Israeli method. 8) :D
 Post subject: Re: Truly professional method!
PostPosted: November 9th, 2020, 17:34
Online
Yes, it is always important to precisely identify the problem and find the proper tool for handling it. That's what a pro differs from DIY :P
No bitcoin donations :)
PostPosted: November 23rd, 2020, 6:53
This does not look like a good idea to me, the ballistic dust will likely de-certify your cleanroom!
PostPosted: December 9th, 2020, 15:21
Normally you don't have to actually use the gun, only act like you intend to use it and you really really mean it with a really really mean voice.
"WHERE ARE THE BYTES?!?"
A cleaner DIY method courtesy of Jack Bauer :
“Russians didn't have hi-tech equipment, so they kinda had to make do with what was around. Sort of like what I'm doin' right now. You probably don't think I could force this towel down your throat. But trust me, I can. All the way. Except I hold onto this one little bit at the end. When your stomach starts to digest it... I pull it out, taking your stomach lining with it. Most people, they take about a week to die. It's very painful.”
