grevan wrote:
Which Linux distro you advice to work with HddSuperClone? I would like to have one installed not a portable version. I noticed you disabled auto mount in the livecd, does HddSuperClone mounts the drives automatically when cloning?
Just curious if whatever Linux I choose if I disable auto mount, it will work without any problem.
I'm new to Linux, so sorry for noob questions.
It is always best to clone/image a drive when it is not mounted, as you don't want the OS interfering. And is always best to have automount disabled when working with failing disks, again to keep the OS from interfering. HDDSuperClone does not mount the drive at all. Whatever Linux flavor you choose should work, but you should know how to turn off automount for it as a best practice. The worst case is you can manually unmount a drive if needed, but it is best to not have it mount in the first place. I prefer Xubuntu, but that is my personal preference. There are other reasons for my choice, but they involve the program building and compiling process, not program operation.
http://www.sdcomputingservice.comHome of HDDSuperClone and HDDSuperTool
