i will continue to give some updates just for the sake of anyone whos intrested .
there is some draw backs , BUT i must say HDDSuperClone is really really good and i am glad to know its existent .
after i explained above the situation i remember that when booting the live cd it does not hanged the system, so this is what i did , i rebooted the system to resume/continue where it stoped thanks to the "project" i created , so it continue where i left off after picking up a drive source and a destination file (i selected the one that was already there the 32gb~ file)
and it continued after couple of minutes (some time seconds) and stopped again with the same errors.
https://imgur.com/a/TkRfMpXright after this error, the HDD hangs for a long period of time, then it "calms down" , get out of the timeout (it stops hanging) and u can read from it again by pressing "connect" and "start" , this is what i am doing for the last 2 days .
the draw back are
1, it does not resume by it self with out me pressing connect and start.
2, some time the HDD disconnect and reconnect itself , when this happen, it get a new source lets say from /dev/sda to /dev/sdf , when this happen (and it did happen multiple times) HDDSuperClone cant find the "source" drive because its not in the same path ofc, because ubuntu assign it elsewhere .
this is what i accomplish so far
after non stop connect and start i am pretty happy .
http://prntscr.com/xabt3mi was able to clone this much info because the error did not show for straight up 5:40h~ .
@maximus
thanks alot of all the information that u shared.
1, i did try to power on and off the drive but it was still hanging
2, i do have the option of soft/hard reset , i did try it aswell but that did not work. the hdd was still hanging
3, Q. how come HDDSuperClone dont know where the partion are ? if fdisk , mdme , rstudio , windows, and all other software do know where the partion is.
instead of selecting /dev/sda for the whole drive just select /dev/sda1-2-3... , for example if u have limited backup space it would be usefull to backup by partition and not the whole drive .
i am still trying to understand what is the cause /root of the problem , and how it can be fixed
i forgot to ask , after having the 1tb file , with what can i read it properly ?
with dmde it took 1 hour~ to read 300gb
